New Zopo P5000
[Modding thread]
Tutte le domande generiche fatele nel Thread generico qui:
https://www.androidiani.com/forum/al...opo-p5000.html
New Zopo P5000
[Modding thread]
Ultima modifica di ghost45; 19-12-17 alle 20:07
Usate il tasto "thanks" se vi sono stato d'aiuto non usate posts per ringraziare....contribuiamo a mantenere puliti i threads!!
Specifiche Dal Sito Web Ufficiale Zopomobile
Performance
CPU MT6750T,Helio P10
Clock Speed / Cores 1.5GHz / Octa-core
ROM 64G ( SAMSUNG DDR3 )
RAM 4G ( SAMSUNG DDR3 )
SD Card Slot Micro SD
Expandable Memory Up to 32GB
SIM Slot Hybrid
SIM1 Type Nano SIM
SIM2 Type Nano SIM
OS Android 7.0, Nougat
Network
2G GSM Bands (MHz) GSM: B2/B3/B5/B8
3G (WCDMA) WCDMA: B1/B2/B5/B8
LTE Bands (MHz) FDD-LTE:B1/B3/B7/B8/B20
Display
LCD size 5.99"
Display Type IPS
Display Resolution 1440x720 (HD)
268 PPI
Touch Panel
Full Lamination Yes
In Cell Yes
Color Red
Black
Curved Yes, 2.5D
Camera
Rear Camera HW Resolution: 13MP AF+5MP,
Type: Auto Focus,
Sensor: Sony IMX258 13MP
Dual Rear Camera
Aperture: F/2.0
Front Camera HW Resolution: 16MP FF,
Face Beauty Mode
Type: Fixed Focus,
Sensor: SAMSUNG 3P3,
Flashlight: Yes, Soft light LED flash,
Aperture: F/2.0
Audio
Audio Jack 3.5mm Standard
Speaker 9*16mm single
Box Speaker Yes
Vibrator Yes
Connectivity
Bluetooth Support: Yes,
Version: 4.0
Sensor Type: 3D-G Sensor,
Proximity & Light Sensor,
Gyroscope,
E-compass
Wi-fi 2.4GHz / 5GHz,
Type: 802.11 a/b/g/n
GPS Yes, also support A-GPS With EPO assistance to speed up postioning
FM FM Antenna via earphone
NFC Not Supported
Hotknot Not Supported
I / O Mirco
Battery
Type Non-removable,
Technology: Li-polymer
Capacity 5000mAh
Standby time 480 Hours
Talk time 40 Hours
Certification Main Device Certification: BIS, RoHS, SAR & CE
Charger Certification: BIS
Battery Certification: BIS
Charger Type: USB 2.0 (Type C ),
Input: 100~240V,50/60Hz,Support PE+ , Support: 15W,5/7/9V~1.67A,12V~1.25A
Output: 5V, 2A
Others
USB Cable Yes
Earphone Yes,
Type: Stereo
Protective Cover Yes,
Type: Silicon
Special Function 1. 0.2s, 360 degree sensible Finger Print Scanner
2. Metal body design
Ultima modifica di ghost45; 19-12-17 alle 20:11 - Motivo: Specifiche Zopo p5000
Come fare il Flash del Firmware Ufficiale nello Zopo P5000
Installazione del Firmware:
Drivers Installazione :
http://www.mediafire.com/file/crvpl6...s_20160804.exe
PROCEDURE
1) download del nuovo firmware.
Unzip del file compresso
Telefono spento senza cavo usbcollegato .....
Guardate qui la pagina ufficiale per scaricare l'ultimo firmware disponibile:
Donwload firmware section
2) download della nuova versione di flashtool per octacore
Eseguite Flashtool versione octa-core ..... selezionate lo scatter file nella cartella del firmware e andate a selezionare firmware upgrade, successivamente eseguite il tasto Download ......
SOLO ORA COLLEGATE IL CAVO USB non prima!
Aspettate la fine del processo di flash e staccate il cavo usb e riavviate il device!
Questa e' una procedura semplificata per installare il firmware ufficiale con flashtool
SP_Flash_Tool_v5.1744.rar
Ultima modifica di ghost45; 19-12-17 alle 20:18
Come Ricevere i diritti di Root nello Zopo P5000:
Procedura:
1) installare la recovery twrp tramite flashtool
a)Download della twrp dal link in prima pagina
b) Eseguire flashtool selezionando lo scatter file nella cartella del firmware e flaggare solo il file recovery
selezionare il file recovery twrp nella cartella dove avete eseguito l'unzip del file e fate download al programma
c) connettete il cavo usb ed aspettare il processo di flash
Come Ricevere i diritti di root :
entrare nella modalità di recovery con i tasti power e level volume + allo stesso tempo
È necessario FORMATTARE i dati DUE VOLTE una semplice cancellazione non è sufficiente sembra nelle versioni di android 7.
Seguire questa procedura in questo ordine esatto e dovrebbe risolvere la maggior parte dei problemi.
1). Installare TWRP e quindi avviare direttamente in modalita' recovery .
2). Selezionare Cancella se viene richiesta la password di encrypt
Poi Avanzate Format DATA dire Sì per confermare. Al termine, scegliere Riavvia, e rientrare nella recovery NON nel Sistema android.
3). Scegli Wipe Advanced Format DATA di nuovo digitare Si per confermare Quando termina scegliere Riavvia e poi recovery di nuovo.
4). Seleziona Wipe e seleziona cache e Dalvik scorri per confermare Quando termina scegliere Riavvia e poi recovery di nuovo.
5). Ora installa SuperSU v2.82 ufficiale
6. Riavvia e rientrate nel sistema.
Verrà visualizzato il logo di avvio, quindi si fermerà e il riavvio di nuovo è normale.
Attendi che il telefono si avvii completamente, questo può richiedere 10> 15 minuti
New Twrp for P5000
link1
Ultima modifica di ghost45; 29-12-17 alle 19:58
Riservato uso futuro 4
Inviato dal mio P5000 usando Androidiani App
Nuova custom rom in arrivo...
Inviato dal mio ZP952_Flash_X_Plus usando Androidiani App
Ultima modifica di ghost45; 11-01-18 alle 07:24
