Utente del giorno: 4eyes81 con ben 2 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: elmegio con ben 7 Thanks ricevuti negli ultimi sette giorni
Utente del mese: bluemask con ben 43 Thanks ricevuti nell'ultimo mese
riflashare rom originale asus
    Sicilia
    Xiaomi redmi note 9
    ciao a tutti,possiedo un tf300tg con bootloader sbloccato e rom liquid scaricata da xda. adesso vorrei ritornare alla rom originale scaricabile dal sito asus. quali sono i procedimenti da effettuare? voglio far tornare il tablet con la memoria vuota comr appena acquistato. grazie
    Sicilia
    Xiaomi redmi note 9
    Quote Originariamente inviato da savio84 Visualizza il messaggio
    trovata la soluzione:
    How to Restore ASUS Transformer Pad TF300T to Stock Firmware
    [Important] Backup everything on your tablet to your computer as this process will wipe everything on your tablet. Use this Android backup guide to find out how you can back up apps and data such as contacts and messages.
    Download the stock firmware from ASUS’s official website. On the website, select Android in the OS drop down menu, then select Firmware, and download the latest firmware for your SKU.
    [Important!] Download the firmware that matches the SKU of your device. To check your device’s SKU, do this:
    On the tablet, go into Settings » About tablet. Then, check the Build number.
    If the build number starts with “TW”, your SKU is TW. Similarly, if your build number starts with “US”, you must download the firmware for the US SKU.
    Extract the downloaded firmware file. You will get another archive file. Extract this one as well to get several files. One of these files will be named “blob”, which is the one we need to use.
    Install the Android SDK by following the guide → here.
    Download fastboot.
    Download Fastboot | Filename: Fastboot.zip
    Extract the Fastboot.zip file to the C:\ drive on your computer to get a folder named Fastboot with four files inside it.
    Copy the blob file obtained in step 3 (after extracting firmware file) to the Fastboot folder on C drive. You should have 5 files in the Fastboot folder now.
    Shut down the tablet. Hold Power + Vol Down buttons until a message appears saying “Press Vol. Up to enter RCK (5s)”. However, DO NOT press the Volume Up button. Instead, wait for 5 seconds till a new menu appears. Then, in less than 10 seconds, press Volume Down once to highlight the USB icon, then press the Volume Up button to validate. Remember, you must do this in 10 seconds otherwise the tablet will boot into Android and you’ll have to redo the step.
    Open Command Prompt on your computer from Start » All Programs » Accessories (or open Start menu, type cmd and press the Enter button).
    Now, type the following commands in command prompt to flash the stock ROM, pressing Enter after each command.
    cd c:\Fastboot
    fastboot devices (this is to ensure the phone gets detected. A string of numbers and letters should appear if the phone is properly detected)
    fastboot -i 0x0B05 flash system blob
    NOTE: The flashing procedure may fail a few times. If it does fail, simply redo step 10.3 i.e type in the same command again, till it works and flashes the firmware.
    After the stock firmware is flashed, you’ll get a finished/OKAY message in command prompt.
    Now, type fastboot -i 0x0B05 reboot in the command prompt to reboot the tablet into the newly flashed stock firmware.
    Your ASUS Transformer Pad TF300T is now running a stock firmware and has been fully restored to stock, with working 3G (in case it wasn’t working before due to a custom ROM). Let us know how it works!
    Porto Viro, RO
    Samsung Galaxy S4
    È possobile invece tornare alla stock senza usare il fastboot? Tipo una stock rom in .zip da flashare in recovery? Grazie
    Inviato dal mio GT-I9505
    Sep 2013
    Bologna
    LG G2 32GB - LG Watch R W110
    I firmware su XDA sono tutti US e si possono comunque usare su un dispositivo europeo? Nel caso la SKU del firmware moddato che c'è ora a bordo sia US il firmware stock da ripristinare dovrà essere ancora US o posso mettere WW?
    Ho seguito la guida e flashato un firmware WW stock della stessa build che avevo prima. In questo modo ho rimosso la CWM e ripristinato il tab allo stato originale con 4.0.3
    Ultima modifica di pepe80; 16-09-13 alle 02:23
    Jan 2015
    ciao a tutti ,mi date una mano ?
    sto ripristinando la vecchia rom originale,
    scaricato fastboot , e scaricato rom 4.20 ww originale,
    i comandi con fast boot " fastboot -i 0x0B05 " non vanno bene , danno errore
    ho poi flashato con fastboot flash system blob
    e andato tutto bene , scrittura avvenuta,
    ho fatto il reboot ed ora cè il logo asus che continua a ciclare con un cerchio sottostante , ma quanto dura ?
    Jan 2015
    ragazzi, ce l'ho fatta !
    ho eseguito i seguenti comandi :
    fastboot erase system
    fastboot erase recovery
    fastboot erase userdata
    fastboot erase boot
    fastboot erase misc
    fastboot erase cache
    ho aspettato che il firmware fosse caricato poi
    fastboot reboot
    dopo circa 10 minuti il tablet è partito in prima configurazione.
    ciao
  8. Il seguente Utente ha ringraziato ataru1 per il post:
    DreamReaper (05-08-20)
  9. #7
    S22 Ultra,Find X2 pro,Mi 10
    Ringraziato 13,117 volte in 10,479 Posts
    Quote Originariamente inviato da ataru1 Visualizza il messaggio
    fastboot erase boot
    fastboot erase misc
    fastboot reboot
    ciao
    Ottimo! Felicissimo che ci sei riuscito. Postando la procedura hai senza dubbio aiutato gli altri utenti a risolvere il problema.
    Sto Guidando (cit. Dieguccio)
