Utente della settimana: 9mm con ben 7 Thanks ricevuti negli ultimi sette giorni
Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 20
Possibile brick Asus Zenpad
    Apr 2019
    Ciao a tutti. Ho un asus zenpad 7 modello p01y.
    Non riesco più a fare boot, resta su logo asus senza la classica rotellina di caricamento. Recovery mode inesistente, finisce di nuovo su logo asus, ma il fastboot è funzionante.
    Ho provato a flashare twrp e clockwork come recovery ma da errore.
    Lo stato del sistema è questo:
    (bootloader) version-baseband: 24832
    (bootloader) version-bootloader: 1715.100_M1S1
    (bootloader) product: SF_3GR
    (bootloader) secure: YES
    (bootloader) unlocked: YES
    (bootloader) off-mode-charge: 1
    (bootloader) ========== parition type ==========
    (bootloader) system parition type: ext4
    (bootloader) userdata parition type: ext4
    (bootloader) cache parition type: ext4
    (bootloader) hypervisor parition type: raw
    (bootloader) boot parition type: raw
    (bootloader) recovery parition type: raw
    (bootloader) splash parition type: raw
    (bootloader) mvconfig parition type: raw
    (bootloader) secvm parition type: raw
    (bootloader) vrl parition type: raw
    (bootloader) psi parition type: raw
    (bootloader) slb parition type: raw
    (bootloader) ucode_patch parition type: raw
    (bootloader) APD parition type: ext4
    (bootloader) ADF parition type: ext4
    (bootloader) factory parition type: ext4
    (bootloader) nvm_static_calib parition type: raw
    (bootloader) nvm_static_fix parition type: raw
    (bootloader) nvm_dynamic parition type: raw
    (bootloader) linux_nvm_fs parition type: ext4
    (bootloader) ===================================
    (bootloader) ========== parition size ==========
    (bootloader) system parition size: 0x0000000090000000
    (bootloader) userdata parition size: 0x00000002f0380000
    (bootloader) cache parition size: 0x0000000017200000
    (bootloader) hypervisor parition size: 0x0000000000100000
    (bootloader) boot parition size: 0x0000000001100000
    (bootloader) recovery parition size: 0x0000000001100000
    (bootloader) splash parition size: 0x0000000002080000
    (bootloader) mvconfig parition size: 0x0000000000080000
    (bootloader) secvm parition size: 0x0000000000c00000
    (bootloader) vrl parition size: 0x0000000000040000
    (bootloader) psi parition size: 0x0000000000020000
    (bootloader) slb parition size: 0x0000000000100000
    (bootloader) ucode_patch parition size: 0x0000000000003000
    (bootloader) APD parition size: 0x0000000009600000
    (bootloader) ADF parition size: 0x0000000000100000
    (bootloader) factory parition size: 0x0000000000900000
    (bootloader) nvm_static_calib parition size: 0x0000000000800000
    (bootloader) nvm_static_fix parition size: 0x0000000000100000
    (bootloader) nvm_dynamic parition size: 0x0000000000100000
    (bootloader) linux_nvm_fs parition size: 0x0000000000500000
    (bootloader) max-download-size: 0x3cc00000
    Ultima modifica di Kooza; 29-04-19 alle 11:37
    JuJu75
    Ciao,
    visto che entra in modalità fastboot puoi provare con un firmware di servizio AFT.
    Prima di cominciare, se stai operando su pc con Windows 8 o superiore, ti consiglio di disattivare la verifica dei driver non firmati.
    Successivamente installa i driver adb - LINK, driver Intel - LINK, installa AsusFlashToolInstaller_1.0.0.17 - LINK
    Fatto questo scarica il pacchetto del firmware - LINK, estrai il contenuto in una cartella e spostala nella partizione principale dell'Hard Disk (per esempio C: )
    Collega il dispositivo al pc in modalità fastboot, apri la cartella ed esegui il file flashall_AFT.cmd
    Ultima modifica di JuJu75; 29-04-19 alle 14:51
    Apr 2019
    Quote Originariamente inviato da JuJu75 Visualizza il messaggio
    Ciao,
    Piccolo passo avanti, ha completato e si è riavviato ma adesso è fermo ai pallini rotanti. Il pc lo vede già come composite adb
    In recovery c'è solo il droidino morto con scritto no command
    Ultima modifica di Kooza; 29-04-19 alle 15:38
    JuJu75
    Quote Originariamente inviato da Kooza Visualizza il messaggio
    Prova a premere insieme tasto Volume Su + Power per qualche secondo.
    Se entra puoi provare il flash anche tramite il comando adb sideload dell'ultimo firmware.
    Apr 2019
    Niente, semplicemente si spegne. La schermata no command blinka ogni tanto come se si riavviasse.
    Tra l'altro anche avviandolo normalmente finisce li.
    Mentre fastboot sempre accessibile
    JuJu75
    Io proverei col firmware di servizio AFT
    Apr 2019
    Ho seguito la tua guida, non è già quello?
  9. #8
    JuJu75
    Si quello è un firmware AFT.
    Se fai una ricerca ne trovi anche altri in rete (di versioni inferiori), l'importante è che siano per il tuo modello.
    EDIT:
    Forse ho trovato l'ultima versione WW_Z170C_V12.26.4.69-user-201704101836-rawdata-131383080017320753.zip - LINK
    EDIT 2: Confermo che è un firmware AFT
    Ultima modifica di JuJu75; 29-04-19 alle 18:18
  10. #9
    Androidiani Power User
    Sep 2014
    Ringraziato 5,286 volte in 4,372 Posts
    Non è la sezione giusta per questo genere di problematiche.
  11. #10
    Apr 2019
    Perdonami.
    Dove era meglio postarlo?
