Release : 20131111
Caratteristiche
Launcher Features
· Folder icon styles: stacked, grid, or carousel
· Folder sorting: alphabetically, reverse alphabetically, or by usage
· Icon scaling in app drawer and on homescreen
· Home screen previews, rearrangable homescreens
· Set default screen from previews layout
· Add or remove homescreens from previews layout
· Slide homescreens with a second finger while holding widgets and icons
· Gestures: Pinch to show previews, spread to show launcher settings
Theme Manager
· Based on MIUI's theme engine
· Mix and match different themes on the fly
· Theme options: Icons, Status Bar, Boot animation, Font (requires reboot), Messaging, Framework, and Ringtones
· Applies native ctz files, but also will apply MIUI mtz files, not all elements will theme properly with mtz packages
· Animated boot animation preview
· Boot animation resolution scaling
Status Bar
· Customizable toggles, compact or page view (or off)
· Extended volume panel in page view toggles
· Access status or navigation bars while in fullscreen apps by touching the edge of the screen
Messaging
· Reads custom notification tones from Contacts
· Revised layout: Added messaging bubbles, removed avatar icons from conversation and put one in the action bar, quick shortcut for emojis
Security
· Manage installed apps' permissions
...and more!
Altre immagini
QUI
