le vedi cliccando sul link prima del tuo e appaiono cosi:
[Common]
* ZOMG FOCAL NEMESIS LOUD NOISES!
[Framework]
* Show advanced reboot if using an insecure lock screen
* Call clipboard change listeners outside the setPrimaryClip transaction
* Telephony: fix typo
* Improve notification shade collapse code
[Settings]
* Make notification-shade-collapse-after-dismiss behaviour configurable
* Re-add lockscreen music controls setting
[Apps]
* Dialer: Move over call stats from contacts app
* Dialer: Enable contact photo preloading
