Utente del giorno: bluflight13 con ben 98 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: bluflight13 con ben 223 Thanks ricevuti negli ultimi sette giorni
Utente del mese: Sfattucci con ben 1156 Thanks ricevuti nell'ultimo mese
Pagina 1 di 12 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 115
Rom android revolution hd...√
    Androidiano VIP L'avatar di miseusegau
    Thanks
    360
    [Rom][JB ]android revolution hd....√
    UProudly presenting you the most popular ROM for Samsung Galaxy Nexus...
    >>> Very fast | rock stable | stock look | great support
    System details:
    Android 4.2.2 (Jelly Bean) - official Samsung Galaxy Nexus GSM firmware JDQ39
    This is improved version of stock ROM - no visual changes!
    Very fast, clean & stable!
    Multi-language (WWE)
    Full Arabic and Hebrew languages support! (ICS feature)
    For Samsung Galaxy Nexus GSM
    Thanks to Google for the base firmware
    Included kernel details:
    Stock kernel (the most stable)
    ROM details:
    Removed software (CPU) rendering - full PowerVR SGX 540 (GPU) rendering
    Fully optimized and tweaked
    ROOT (su + SuperSu Permissions - Thanks to chainfire)
    Unsecured boot.img
    Newest BusyBox
    RAM optimizations
    System signatures check enabled for system security and safety
    Improved virtual memory management
    Speed optimizations
    Enabled GPU UI rendering
    Data, cache and system partitions mounting tweaks
    Bloatware applications removed
    All /system applications updated to latest available
    All /data applications updated to latest available
    Improved camera performance
    Improved CPU governors performance
    Most optimal system scheduler
    Disabled kernel debugging for better performance
    ZRAM ready!
    Zipaligned (Improved RAM management)
    Zipalign on boot (for user applications on data partition)
    Fully de-odexed
    init.d scripts (BusyBox run-parts) support
    Auto init.d permissions set on boot
    sysro/sysrw commands support
    Excellent battery life!
    Improved EXT4 performance
    You can replace boot animation with any custom one (or use ICS default)
    OpenVPN support
    4EXT Recovery (Thanks to madmaxx82)
    Most up-to-date system files permissions
    Adobe Flash Player support for Ice Cream Sandwich
    Support almost 24h a day
    ...and many more!
    You need:
    Samsung Galaxy Nexus GSM unlocked with fastboot oem unlock command
    ClockworkMod Touch Recovery GSM
    How to flash:
    Download ROM and place it on your virtual SD card
    Boot your phone in recovery mode (vol down + vol up + power)
    In main menu, select "install zip from sdcard"
    Select "choose zip from sdcard" and browse to the location of Android Revolution ROM
    You can use data wiping option in AROMA (optionally if coming from earlier version of my ROM, obligatory if coming from stock or other custom ROM)
    After flashing process is complete, reboot the device
    » Performance Tweaks, % battery mods, & other add-ons: http://goo.gl/ja1kj
    » You can easily customize my ROM and make it LITE by removing some components with ROM Cleaner: http://goo.gl/dDisT
    » If you want to flash different custom kernel, you can do it easily using Kernel Update Utility by jkoljo: http://goo.gl/IOj2D
    ....CHANGELOG....
    Fixed progress bar not moving in AROMA installer
    Added cleaning script to the installer to avoid doubled apps on /data
    Other minor fixes in AROMA installer
    Updated BusyBox to 1.21.0
    Replaced Chainfire's SuperSu with SuperUser from Koush
    Extended AROMA with possibility to choose more applications
    Other minor changes and fixes
    Included and updated components:
    --- Data partition ---
    Adobe Flash Player 11.1.115.48
    Adobe Reader 10.5.1
    Dropbox 2.3.4
    ES File Explorer 1.6.2.5
    Facebook 2.2.1
    Maxthon 4.0.3.3000
    Twitter 3.8.0
    --- System partition ---
    Google Play 3.10.14
    Gmail 4.1.2
    GmsCore 3.0.25
    SuperUser 1.0.1.5
    --- Aroma installer ---
    Google Maps 6.14.3
    Google Plus 3.5.3.42448346
    Google Street 1.8.1.1
    Google YouTube 4.3.9
    Google Chrome 25.0.1364.169
    Google Music 4.5.914I.590354
    Google Now 2.3.11.575405 (Only for Android 4.1+)
    Google Search 1.3.3.247963 (Only for Android 2.3.5)
    Google Search 1.4.1.338691 (Only for Android 4.0.3)...
    My thread (GSM) is also at RootzWiki.com,.... http://goo.gl/BIPNT where you are more then very welcome!
    Android Revolution HD 10.0
    --- release date: 17 February 2013 ---
    Based on official Samsung Galaxy Nexus GSM firmware JDQ39
    Added Seeder 2.0.0 in AROMA tweaks section (Thanks to lambgx02)
    Modified zipalign script to run minimum every 2 days (Thanks to mcbyte_it)
    Modified VACUUM/REINDEX script to run minimum every 2 days (Thanks to mcbyte_it)
    Zipaligned using latest SDK 21.0.1
    Updated SuperSU
    ....LINK XDA.... http://forum.xda-developers.com/show...php?p=19665446
    DOWNLOAD-----
    Firmware package
    --- http://goo.gl/lB0ha
    Android revolution HD 10.1... http://android-revolution-hd.blogspo...-site-var.html
    --- http://android-revolution-hd.blogspo...-site-var.html
    Questa rom e' indirizzata a chi vuole mantenere un impostazione molto simile alla stock il che si traduce in poche personalizzazioni ma una velocita', fluidita e durata notevolmente migliorate....
    NON MI ASSUMO NESSUNA RESPONSABILITA' SU FLASH ERRATI ECC.....
    UN GRAZIE FA SEMPRE PIACERE...
    BUON FLASH A TUTTI.......
    Ultima modifica di miseusegau; 16-03-13 a 10:04
  2. I seguenti Utenti 2 hanno ringraziato miseusegau per il post:
    CalegaR1 (31-01-13),furious81 (05-04-13)
    Thanks
    360
    Reserved...
    Ultima modifica di miseusegau; 24-11-12 a 12:54
  5. #3
    Thanks
    360
    Reserved...
  6. #4
    Senior Droid L'avatar di PurpleWeed
    Thanks
    12
    Che kernel mi consigliate per questa fantastica rom?
    Terminale: Google Galaxy Nexus
    Ex possessore di Htc Incredible S *_* il mio primo android phone
  7. #5
    Thanks
    360
    Quote Originariamente inviato da PurpleWeed Visualizza il messaggio
    Se la stai gia testando ti posso consigliare il lean, se la devi ancora montare provala col suo kernel e poi decidi
    Ce anche il franco r281....nuovo nuovo ma col lean vai sul sicuro tra prestazioni e durata...
    Edit...se ti va di postare un po di screen e impressioni di questa nuova 6.1.0 mi fa piacere....
    inviato da anonymous
    Ultima modifica di miseusegau; 03-10-12 a 19:13
  8. #6
    Thanks
    12
    Allora l'ho montata da 2 giorni devo dire che la batteria dura mooolto di piu a paritá d'uso io prima usavo la android hd peròper htc incredible s ho sempre pensato sia la migliore.. comunque domani provo a cambiare kernel anche se con quello stock mi sto trovando da dio 0 lag buona durata..
  9. #7
    Thanks
    360
    Fantastico..non avevo dubbi comunque questa e' una delle rom piu importanti e conosciute che ci siano.....hai voglia di postare qualche screen delle varie schermate menu, opzioni varie durata batteria ecc...? Grazie
    inviato dalla commotio.....√
  10. #8
    Thanks
    12
    Okok domani faccio qualche screen ora mi sto preparando per uscire
  11. #9
    Thanks
    360
    Ok buona serata.
  12. #10
    Thanks
    12
    Eccomi allora parto dal presupposto che il telefono l'ho usato abbastanza e che di solito mi faceva 12 ore al max con jelly stock ecco gli screen
    Però devo anche dire che quando l'ho staccato non era al 100% e che l'ho lasciato acceso durante la notte con dati accesi però... quindi per un test piú affidabile aspettate a domani però comunque si vedono miglioramenti rispetto alla stock..
  • Non puoi inserire repliche
