[JB 4.2.1] RufDROID 0.9X by Team Shogun
    Super Droid L'avatar di ANDROIDPC
    Mar 2010
    Ringraziato 526 volte in 374 Posts
    Smile
    FEATURE:
    - Based On JOP40D Factory Image [JB 4.2.1]
    - Rooted (SuperSu)
    - Busybox 1.20
    - init.d Support Enabled
    - Unsecured boot.img
    - Disabled adb Debug Icon
    - Fully Deodexed
    - Fully Zipaligned
    - Super Battery Life
    - Build.prop Carefully Tweaked
    - Optimized
    - Smooth
    - Gapps Baked In
    - Back to Portrait Lockscreen
    - GooManager for OTA updates
    - Stock Launcher
    - More Tunes for Alarms, Ringtones and Notifications
    - Inverted Gapps [Music, Google+, Gmail, Youtube, Google Now]
    - Quick Toggles Mod [See MODs Dowloads] [Flashable .zip thanks to @kevdliu!]
    - Home Landscape Mod [See MODs Downloads]
    - Stock Google's Look
    - Multi Reboot Menu
    - Audio Improvement Patch
    - Replaced CMFileManger with the GREAT EsFileExplorer!
    - ThunderBolt! Scripts Modified by Me for RufDroid's Needs [The ScreenState Scaling will work only if you don't change some parameters!] [See "KERNEL & ROM INFO"!]
    - Zipalign Script that zipalign apps at boot!
    - SQlite Script that optimize apps at boot!
    - TCP Buffers Script
    - Faux123 024 Mainline Kernel - CPU Max 1800 Mhz - GPU Max 384 Mhz IMPORTANT: See "KERNEL & ROM INFO" Before change Kernel stuffs!!! It's below - Screenshots!
    - TricksterMOD Baked In for Kernel Customization (Clock, Colour Profile, Voltages etc.)
    - Google Gears Bootanimation
    - Adfree Hosts Updated Today [1 DEC]
    - Apps Baked In: Facebook (Inverted), Instagram (Inverted), WhatsAppPlus (Inverted in the way you like! Customizable Colours!), Chrome, StickMount, Flash Player Downloader.
    - Email.apk and Exchange2Google.apk Baked In again for who use it.
    - Full Support [Until i can, i'm not a rocked dev]
    IMPORTANT:
    So this is the most important part to read, cause explain how the rom works. I keep some scripts from ThunderBolt! package created by @pikachu01 and, as he said, i have to say which changes i've done. So i only included in the rom TCP Buffer + Zipalign + SQlite Scripts (without changes) and, the most important, the "Screenstate Scaling Script", but what it does? First i clean the script leaving only Governor tweaks and the main script job. Second, this script makes the phone able to switch between two governors automatically when phone is in wake mode and in sleep mode. So i have setted 2 governor, one for wake and one for sleep. Now if you change the default governor (that is the same i choose for WAKE) you'll be make a BIG mistake and the script will not work anymore or will work in conflict with other stuffs! So, don't change the governor!! If you follow me and rom's job, you will have a super battery life! if you will change the governor, i'll not able to help you. Anyway you can change CPU,GPU clocks, I/O Scheduler, Contrast profile with TricksterMOD, but DON'T CHANGE THE GOVERNOR!, i've done that for you for the best battery life & performance
    INSTRUCTIONS:
    - Put ROM and Choosed Mods (POST#2) on sdcard [Can be downloaded with GooManager too]
    - *Full Wipe Needed*
    - Wipe Data + Wipe Cache + Wipe Dalvik
    - Flash ROM .zip
    - Boot the ROM
    - Reboot In Recovery and Flash Quick Settings Mod
    - Enjoy!
    - After Install open GooManager for activating the service
    Rinvio al 3ad su XDA per il download e maggiori chiarimenti:
    [ROM][24 NOV][JB 4.2] TEAM SHOGUN RufDroid v0.91 [ Stable | Cool | More ] - xda-developers
    SI RINGRAZIA IL TEAM SHOGUN
    Ultima modifica di ANDROIDPC; 02-12-12 alle 09:50
    Smartphone: Samsung Galaxy NeXuS i9250
    ROM: Stock JOP40D - JB 4.2.1 Rooted
    Kernel: Stock 3.0.31
  2. Il seguente Utente ha ringraziato ANDROIDPC per il post:
    markusssss (27-11-12)
    Mar 2010
    Come da prima pagina sembra una ROM molto interessante, stabile e completa.
    Io per adesso non la monto ma se la provate fatemi sapere. Presto sarà sfornata la 0.92 con ulteriori FIX sopratutto per quanto riguarda l'audio.
  5. #3
    Ringraziato 10 volte in 8 Posts
    Quote Originariamente inviato da ANDROIDPC Visualizza il messaggio
    L'avevo notata un mesetto fa su xda..sembra bella, ma aspetto che qualcuno la provi..
    E' un team italiano, il che è un grosso vantaggio per noi..
  6. #4
    Mar 2010
    Quote Originariamente inviato da Ginuzzo Visualizza il messaggio
    Si ma quella che avevi visto era basata su JB 4.1.2.
    Questa è stata sviluppata il 24/11 su base 4.2.
    Secondo me dovremmo aspettare almeno la versione 0.92 per essere completa al 100% anche se questa è stata già dichiarata stabile, completa e fluida!
  7. #5
    Androidiano VIP L'avatar di markusssss
    Scafati
    Xiaomi Redmi Note 3 Pro
    Ringraziato 90 volte in 78 Posts
    interessante..
    Inviato dal mio Galaxy Nexus
    Se ti ho aiutato a risolvere il problema clicca sul tasto Thanks qui sotto ↓
  8. #6
    Apr 2011
    Ho preso il Galaxy Nexus per non aver sorprese (passo da un Optimus Black con cm 7 e 10 incomplete) ed avere android puro e funzionante, ma non sapevo del bug audio.
    Ci tenevo ad avere tutto pulito e funzionale, ma nemmeno più della Google ci si può fidare, visto che non hanno fixato il big con la 4.2
    Beh, pazienza, anche con questo farò root e tutto e via di custom rom.
    Sono italiano, perciò se posso avere una rom italiana tanto meglio, anche per i bug sappiamo a chi chiedere.
    Penso di mandargli una mail ed invitarlo qui.
    Mail mandata, io la monterò appena fanno il fix audio.
    Vi farò sapere.
    Ultima modifica di Thomas; 27-11-12 alle 14:33
  9. #7
    Mar 2010
    Quote Originariamente inviato da Thomas Visualizza il messaggio
    Vi farò sapere.
    Non è un vero e proprio BUG.. ..è proprio il Gnexus che è uscito con l'audio ridotto e questo già dalla prima versione.
    Certo con le ROM moddate il volume viene aumentato ma alle volte ciò significa anche distorsione dell'audio.
    Resta inteso che ROM perfette non esistono anche se a mio avviso la 4.1.1/4.1.2 è una delle migliori. .
    Inoltre per quanto riguarda l'audio NON c'è solo questa ROM. La rilevanza della Rufdroid stà nei FIX sulla 4.2, ma la patch audio è già stata implementata per diverse ROM.
  10. #8
    Apr 2011
    Si lo so, il fix audio ce l'ha la cm10 ed altre, ho scritto così solo perchè con la 4.2 Google non ha messo una pezza mettendo il boost all'altoparlante, e visto che mi decido a mettere una rom custom, metto una italiana, dato che la Cyanogenmod mi ha deluso con le varie 7 e 10 per LG Optimus Black (che ho seguito, e sono state uno strazio, ad oggi ancora non funziona il gps con queste)
  11. #9
    Mar 2010
    Nuova versione 0.92 basata su JB 4.2.1 oltre a contenere diversi BUG FIX della versione 0.91!!
    IMPORTANTE: Leggere informazioni su Kernel e ROM contenuti nella prima pagina di XDA. NON modificare il Kernel e lo stato GOVERNOR per garantira un ottima durata della batteria.!
  12. #10
    Androidiano L'avatar di CrazyDunky
    Jan 2010
    Modena
    Ciao ANDROIDPC , mi puoi dire come ti trovi con questa rom?
    io vengo dalla Paranoid e mi sto trovando molto bene, ma avevo voglia di cambiare e visto che questa è di un team italiano mi interessava il suo sviluppo.
    a personalizzazioni e a batteria come siamo messi? ha qualche bug importante? fluidità?
    grazie in anticipo ^^
