Utente del giorno: Varioflex con ben 2 Thanks ricevuti nelle ultime 24 ore
☠ [APK][Tweaks & Mods] Pimp My Rom {Any Device // Any Rom} ☠
    Senior Droid L'avatar di Uzumaki99
    Galaxy Nexus
    Ringraziato 568 volte in 246 Posts
    FONTE XDA: ☠ [APK][Tweaks & Mods] █ PIMP MY ROM █ BETA v1.0 {Any Device // Any Rom} ☠ - xda-developers
    ScreenShot
    Caratteristiche Attivabili
    Bisogna tenere presente che questo progetto è ancora in una fase molto precoce di sviluppo, quindi, la maggior parte delle funzioni sono ancora da verificare ed i risultati possono variare da dispositivo a dispositivo e da rom/kernel a rom/kernel.
    Network & Internet
    • Wifi Scan Interval in seconds
    • TCP Congestion Algorithm selection
    • Media streaming tweaks
    • Use Google DNS servers
    • Enable/Disable HSUPA
    • Protect against SYN attacks by hardening your TCP stack
    • Avoid Time-Wait state
    • Block all redirects
    • Block source-routing
    • Various IPv4 tweaks
    Multitasking
    • 3 presets of OOM Groupings (lom/mid/high)
    • 3 presets of Minfree values (low/mid/high)
    • 2 presets of zRam compression (64mb/128mb)
    • Adjust Dalvik VM to new OOM & Minfrees
    • Adjust kernel to new OOM & Minfrees
    • Renice low consumption processes to a softer value
    Dalvik VM
    • VM Heap Size selection
    • VM Heap Growth-limit selection
    • VM Heap Start Size selection
    • Optimization Flags selection, any combination of verification, optimization & register mapping
    • Force dex optimization on /data only
    • Enable/Disable Just in Time Compiler (JIT)
    • Enable/Disable JNI Error Checking
    • Enable/Disable bytecode verification for Dalvik
    Kernel
    • Governor tweaks
    • I/O Scheduler tweaks
    • Disabling I/O stats
    • Enable/Disable Vertical Synchronization (Vsync)
    • Disable Normalized Sleepers
    • Disable New-Fair Sleepers
    • Disable Gentle-Fair Sleepers
    Toggle Android Features
    • Hardware Acceleration
    • Force GPU rendering
    • Surface Dithering
    • Purgeable Assets
    • 16bit Transparency
    • Kernel JNI Error Checking
    • Android Logger
    • Locking launcher in memory
    Telephony
    • Call Ring Delay
    • Proximity Sensor delay
    • In-Call amount of volume steps
    • SMS & MMS retry timer if failed sending
    • SMS & MMS amount of retries if failed sending
    • Enable/Disable AMR Wideband (a.k.a HD Voice)
    Touchscreen & Display
    • Amount of fingers recognized by the screen (multitouch)
    • Minimum amount of time between 2 touch events (Pointer Duration)
    • Maximum amount of events per second WindowsManager can handle
    • SurfaceFlinger's minimum velocity
    • SurfaceFlinger's maximum velocity
    • Enable/Disable FPS Capping
    Miscellaneous
    • Optimize sqlite3 databases at each boot
    • I/O Tweaks for ext4 file-systems
    • Internal & External sdcard tweaks
    • Zipalign all apks at each boot
    • Various battery saving tweaks
    • Various camera quality tweaks
    • Raising jpg quality to 100%
    • Enable quickpoweron
    Rescue Package
    Questo strumento permette di "pimpare" la vostra rom in totale sicurezza.
    Sarà il backup di tutti i file di sistema originali e crea un zip flashabile che contiene tutto. In questo modo, se qualche ritocco causa problemi, basta semplicemente flashare ol proprio pacchetto di salvataggio per rimuovere tutte le modifiche apportate da Pimp My Rom, lasciando tutte le vostre applicazioni e dati intatti.
    Universal Init.d Support
    Abilita il supporto init.d con tutti i kernel.
    Questo strumento è il primo metodo completamente universale per il supporto del init.d, per il semplice motivo che tutto ciò accade sul lato app.
    Pimp My Rom in grado di rilevare quando il dispositivo viene riavviato ed esegue automaticamente lo script init.d, che agisce proprio come un kernel.
    Questo strumento ti dà anche un modo per gestire velocemente i vostri script int.d. Modificare, eliminare e eseguire script con il semplice tocco di un tasto!
    Pimp My CPU
    • Minimum & maximum CPU frequencies management
    • Overclocking if your kernel supports it
    • Governors management
    • Schedulers management
    • Voltage control
    Density Changer
    Potete in 3 step modificare la densità del display
    Entropy Generator
    Un'interfaccia grafica per la Random Number Generator Daemon (RNGD).
    Impostare in modo indipendente:
    • Feed Interval
    • Feed Timeout
    • Amount of Random bytes
    • Fill-watermark
    • Kernel random read wakeup threshold
    • Kernel random write wakeup threshold
    Dual Bootanimations
    Permette di avere due differenti animazioni di avvio che saranno alternativamente visualizzate, un boot per ciascuno.
    Lock Apps in Memory
    Bypass incorporato che blocca qualsiasi applicazione installata nella memoria, incluse le applicazioni di sistema!
    Navigation Bar Toggle
    Spiega da sé, attiva la barra di navigazione on & off
    Gps Configuration
    Scegli tra i 79 Paesi + 5 continenti dal file gps.conf:
    Avere il file gps.conf giusto per il vostro paese è essenziale per la precisione e la velocità del blocco del GPS)
    Device Hidden Menu
    Accede alle impostazioni nascoste del tuo dispositivo senza dover comporre codici.
    Pimp My Beats
    • Modified DSPManager
    • Beats Audio binaries, libs, framework & other assets
    • Dolby Mobile binaries, libs, framework & other assets
    • SRS binaries, libs, framework & other assets
    Bravia Engine 2
    Installa il popolare Bravia Engine 2 Sony su qualsiasi dispositivo con il semplice tocco di un tasto!
    xLoud & ClearAudio+
    Installa il popolare xLOUD, insieme con il nuovo marchio ClearAudio +.
    Sony Album
    Installa la Sony Gallery & Photo Editor per una piena esperienza multimediale Sony.
    OpenVPN Support
    Aggiunge il supporto OpenVPN al dispositivo.
    Set of Settings
    Pimp My Rom viene fornito con una propria serie di impostazioni.
    1. Select among 12 different transition animations to apply independently to each section of the app
    2. Select the type of reboot used by the "Reboot Required" Notification (Hot reboot/Normal reboot)
    3. Clear all the app's preferences
    Ne io ne il forum, ne l'autore ci assumiamo la responsabilità di ciò che può accadere al vostro terminale
    Ultima modifica di Uzumaki99; 29-06-13 alle 19:49
    My G.Nexus
    Rom: Firework
    Kernel: Fireworks Kernel
  2. I seguenti 5 Utenti hanno ringraziato Uzumaki99 per il post:
    fedelamb (29-06-13),galaxy4ever (29-06-13),Pelide (30-06-13)
    Galaxy Nexus
    Download
    • Esegui un nandroid backup
    • Scarica l'applicazione
    • Installala come si farebbe con qualsiasi apk
    • Fare clic sulla sezione pacchetto di salvataggio e crea un nuovo pacchetto di salvataggio
    • Scegliere e applicare le modifiche desiderate, assicuratevi di leggere le descrizioni e le istruzioni in-app
    Google Play Link: https://play.google.com/store/apps/d...uide.pimpmyrom
    Aroma Version Link: http://goo.im/devs/Androguide/Pimp%20my%20Rom
    Ultima modifica di Uzumaki99; 29-06-13 alle 19:13
  5. Il seguente Utente ha ringraziato Uzumaki99 per il post:
    galaxy4ever (30-06-13)
  6. #3
    Galaxy Nexus
    Multitasking Section
    ¤ OOM groupings :
    Android, like any other Linux system, has a built-in task killer, called the LowMemoryKiller (a.k.a LMK).
    The LMK analyses the RAM usage of all applications in real-time, and when the system has too many apps open, or too much RAM consumption, the LMK will start killing apps to free-up some memory.
    To determine which app to kill first, the LowMemoryKiller distinguishes 10 categories of apps, which are called the Out-Of-Memory (OOM) Priorities.
    As the name implies, the LMK will create a kind of ordered list based on the determined priority of the apps.
    Those categories are as follow :
    • Foreground App
    • Visible App
    • Secondary Server
    • Backup App
    • Home App
    • Hidden app
    • Empty App
    • Perceptible App
    • Heavy-Weight App
    • Content Provider App
    For each of these categories, Pimp my Rom will modify the memory threshold for LMK to start killing processes and adjust the priority of the categories to match three preset levels of multitasking :
    • Low : Your device will be able to handle less opened apps at once, but consume less RAM and less battery
    • Mid : An average good level of both Multitasking and not too much RAM drain/Battery drain
    • High : Your device will be able to handle a big bunch of opened apps at once without being killed
    The OOM settings in PmR also takes care of the ADJ, but I might add a separate 3 levels radiogroup for ADJ too
    ¤ Minfree Values :
    The LowMemoryKiller isn't only about OOM groupings, the Minfree values are very important as well :
    The Minfree module of the Low Memory Killer is here to set the minimum amount of free RAM that should always be available.
    If the free RAM level goes below the Minfree value, the the LMK starts killing apps (based on the OOM priorities, remember ? )
    In other terms, if the LMK is the gun for killing apps, then the Minfree module is the trigger ^^
    Again, PmR will allow you to choose between 3 preset levels (for the purpose of clarity for the user, the levels are inverted from the actual values. i.e : High Level in the app wil set a low minfree value, allowing for more multitasking) :
    • Low : The minimum amount of free Ram (minfree) will be set high, allowing apps to get killed by the LMK quickly. = Not much multitasking, but good battery/less lags as you always have a good amount of free ram
    • Mid : Balanced Level, good multitasking, not much lags and average battery
    • High : Big multitasking hog
    ¤ zRam (Zero Capacitor Ram) :
    Taken from Wikipedia :
    zRam is an experimental (staging) module of the Linux kernel. It was previously called "compcache". zRam increases performance by avoiding paging on disk and instead uses a compressed block device in RAM in which paging takes place until it is necessary to use the swap space on the hard disk drive. Since using RAM is faster than using disks, zRam allows Linux to make more use of RAM when swapping/paging is required, especially on older computers with less RAM installed.
    To make it simple, zRam allows to virtually increase the amount of RAM your device has by using the Swap spaces in your device memory.
    This is mostly profitable for low-end devices that come with few ram (512mb generally).
    PmR offers 2 levels :
    • 64 mb : virtually adds 64mb of RAM
    • 128mb : virtually adds 128mb of RAM
    zRam settings requires a kernel that includes this module.
    I hope these little explanations will help you understand how to use those settings, and help you find the right combination for your device and use
    Ultima modifica di Uzumaki99; 05-07-13 alle 19:37
    My G.Nexus
    Rom: Firework
  7. Il seguente Utente ha ringraziato Uzumaki99 per il post:
    fedelamb (29-06-13)
  8. #4
    Galaxy Nexus
    Developer's Guide on Implementing PmR in your Roms
    1) Implementing PmR with a custom preset & playstore OTA updates working
    1. Flash your Rom & apply the tweaks and options you want to be included in your preset
    2. Create a /data folder at the root of your Rom's zip package, and in this folder create a /app folder (so you now have a /data/app path
    3. Download this version of the PmR apk and place it in the freshly created /data/app folder in your Rom's zip
      (this is the playstore-signed version, which will allow your users to receive OTA updates as if they installed it from the playstore)
    4. Grab the following files from your device and place them at the corresponding locations in your Rom's zip package :
      (If some of those files are missing on your device, don't worry, this simply means they are not needed in your preset)
      codice:
      - /system/etc/init.d/99Pimp_my_Rom
      - /system/etc/init.d/98Entropy
      - /system/etc/init.d/S90zipalign
      - /system/etc/init.d/04dual_bootanim
      - /system/etc/install-recovery.sh
      - /system/etc/hosts
      - /system/bin/entropy-gen
      - /system/xbin/rngd
      - /system/xbin/openvpn
      Note : this does not include the Apps & Mods section, except for the Adblock & OpenVPN Support
    5. Create the following path of folders in your Rom's zip : /data/data/com.androguide.pimp.my.rom/shared_prefs/
    6. On your device, navigate to /data/data/com.androguide.pimp.my.rom/shared_prefs and copy all the content of this folder to your Rom's zip freshly created /data/data/com.androguide.pimp.my.rom/shared_prefs/ folder
    7. Open your Rom zip's /system/build.prop in a text editor
    8. Now open your device's /system/build.prop in a text editor, and copy everything from the first occurence of "### Pimp my Rom : xxx" to the end of the file, then paste it at the end of your Rom's build.prop (Do not forget to save the modifications)
    Ok, now we have added all the required assets for Pimp my Rom and your custom preset, let's pass-on to the updater-script modifications in order to install those assets properly and set the right permissions to them.
    1. In your Rom's zip package, navigate to /META-INF/com/google/android and open updater-script in a text editor
    2. Copy the following lines near the end of the file, but before "unmount("/system");" :
      codice:
      ui_print("Installing Pimp my Rom with a custom preset...");
      package_extract_dir("data", "/data");
      set_perm_recursive(0, 0, 0755, 0755, "/system/etc/init.d");
      set_perm_recursive(0, 0, 0771, 0660, "/data/data/com.androguide.pimp.my.rom/shared_prefs");
      set_perm(0, 0, 0644, "/data/app/com.androguide.pimp.my.rom-1.apk");
      set_perm(0, 0, 0644, "/system/etc/hosts");
      set_perm(0, 0, 0755, "/system/etc/install-recovery.sh");  <<< Do NOT include this line if you didn't activate init.d through PmR in your preset
      set_perm(0, 0, 0755, "/system/bin/entropy-gen");  <<< Do NOT include this line if you didn't use the Entropy Generator in your preset
      set_perm(0, 0, 0755, "/system/xbin/rngd");  <<< Do NOT include this line if you didn't use the Entropy Generator in your preset
      set_perm(0, 0, 0755, "/system/xbin/openvpn");  <<< Do NOT include this line if you didn't activate OpenVPN support in your preset
      ui_print("Done installing Pimp my Rom - by Androguide.fr@xda");
    2) Adding a Pimp my Rom entry to your Rom's Settings.apk - Coming Soon
    Ultima modifica di Uzumaki99; 05-07-13 alle 19:36
    My G.Nexus
    Rom: Firework
  9. Il seguente Utente ha ringraziato Uzumaki99 per il post:
    leonardodettoileo (17-08-13)
  10. #5
    Galaxy Nexus
    Changelog
    Alpha v3.3 (18/12/2012)
    • Added a new Tool : Density Changer. Allows you to modify your device's LCD density easily and safely, avoiding the usual playstore compatibility issues after dpi changes
    • Fixed Voltage Control set-on-boot function
    Alpha v3.2 (17/12/2012)
    • New Telephony Tweaks section (all values are automatically detected)
    • Call Ring Delay : Define the interval of time in seconds between the dialing and the ringing
    • Proximity Sensor Delay : Define the delay between your sensor's detection and the screen being lit off/back-on
    • In-Call Volume Steps : Define the maximum amount of volume steps while in call. Only working on froyo & gingerbread (Android 2.2.x & 2.3.x)
    • SMS/MMS Retry Timer : Define the amount of automatic retries when an SMS or MMS fails to be sent as well as the delay between those retries
    • AMR Wideband : improve in-call audio quality by enabling Adaptive Multi-Rate encoding
    Improved the Camera Quality tweak (in the Miscellaneous section) by adding more build.prop modifications :
    • Set maximum capture resolution to 8 megapixels (ro.media.capture.maxres)
    • Set panorama resolution to 3264x1840 (ro.media.panorama.defres)
    • Set panorama frames resolution to 1280x720 (ro.media.panorama.frameres)
    • Enabled VideoModes (ro.camcorder.videoModes)
    • Set video media encoder maximum fps to 65 (ro.media.enc.hprof.vid.fps)
    Alpha v3.1.1 (17/12/2012)
    • Hotfix for the Network & Internet section FC when the current wifi scan interval value couldn't be detected by the app
    Alpha v3.1 (16/12/2012)
    • Added Wifi Scan Interval control to the Network & Internet section, set the interval in seconds between which the system automatically checks for available wifi networks. A high value will save more battery, a low value will help if your wifi disconnects often.
    • Fixed Init.d support verification process that was returning false everytime in v3.0
    • Fixed Hardware Acceleration enabler tweak that was commented-out by mistake in v3.0
    • Fixed Purgeable Assets toggle state not being saved
    • Fixed SYN Attack protection checkbox state not being saved
    • Minor text modification
    v2.1.2
    • Fixed conflicting tweaks that caused bootloops and/or were breaking network on some devices
    • Please report if these kind of issues persist ~
    • Made the package lighter by removing some unused left-over files from previous versions
    v2.1.1
    • Fixed missing chmod script which was preventing init.d scripts from running
    • Possible fix for the apps that aren't installed properly on some devices
    v2.1
    • Introducing a new tweaks selection screen : Pimp my Kernel
    • --> Tweak 6 of the most common CPU Governors : Ondemand//OndemandX//Interactive//SmartassV2//Lulzactive//Conservative
    • --> Tweak your default I/O Scheduler & Disable I/O Stats
    • --> Disable & Re-Enable VSync
    • --> Disable Normalized Sleeper // Gentle Fair Sleepers // New Fair Sleeper (just moved, was already there before)
    • -->Misc. Kernel Tweaks : Disable kernel error checking (already there before) // Sysctl kernel msgmin & msgmax tweak
    • Added an option to revert Adblocking
    • Fixed the issue where beats audio and walkman options would be displayed for gb roms when it shouldn't
    • Various bugfixes (a few swapped selections and unworking tweaks)
    • Removed the extra apps screen, this wasn't really matching the mainline of this project, since you can grab those apps from the market. Plus this makes the whole package lighter.
    • Switched to miui installer theme
    v2.0
    ø New Tweaks selection screen : Multitasking
    ==> Choose between :
    • 4 levels of OOM Priorities
    • 4 levels Minfree settings
    • 2 levels of ZRAM compression
    • Tweak your kernel and dalvik cache to behave well and be stable on hard multitasking conditions
    ø New Tweaks selection screen : Networks & Internet
    ==> Security tweaks :
    • Reinforce your TCP/IP Stacks to make them resist to SYN attacks which cause a DoS (Denial of Service) on your device. Now those lame-ass blackhat hackers won't harm you with this.
    • Block redirects : auto website redirections will be blocked
    • Block source-routing : source-routing can be used to hack into your device as it allows full tracing of packets.
    ==> Stability & Speed tweaks :
    • Increase the buffer and queue size of each tcp socket to give more stability on high broadband consumption conditions
    • Allow the system to re-use the Sockets on TIME-WAIT state. In clear time-wait causes memory-loading, memory-loading causes internet lagg, internet lagg sucks.
    • Various IPv4 protocol speed tweaking scripts using sysctl
    • DNS and ppp0 tweaks for faster name-resolution, which means faster connections to websites.
    ø New Tweaks selection screen : GPS Configuration
    • ==> Choose between 79 countries (and 5 continents) of gps.conf files: those files are essential for the accuracy and lock-speed of your device's gps. (Thanks to gangsterjoop for the files)
    ø New Adblock file of over 200 000 hosts ! (100x more than before) (Thanks to BSDgeek_Jake for the host file) --> added to extra features screen
    ø New init.d scripts :
    • Move Dalvik-cache to /cache to increase data storage
    • Bind-mount dalvik-cache to allow a device to boot without sdcard (useful for devices with damaged internal sdcard)
    • Touchscreen responsiveness improvement tweaks
    ø New Enable/Disable features :
    • Disable and Re-Enable Android logger
    • Disable Gentle Fair Sleepers
    • Disable New Fair Sleepers
    ø Rewritten every single init.d script :
    • This allowed me to realize many of them were not working, so I added a lot of missing values, and fixed a countless number of errors, redundant values and typos. So there should be some big improvement on the effects of init.d tweaks.
    • I also set an order of execution of init.scripts to avoid conflicts.
    ø Removed themes and S-Voice
    • The S-Voice flaw that allowed other devices to use it appears to be patched and it was heavy, and themes were heavy and not really useful, you can download a countless number of them for free on the market
    ø Changed installer theme to Sense
    • I realized that the options subtitles were not readable with ics theme, so most of the tweaks effects explainations were hidden.
    ø Pimp My Rom will now come in two versions :
    • One will include the latest version of Aroma (with touchscreen working out-of-the-box, but issues on some devices) and One using Aroma v2.51 (With touchscreen calibration, and this version appears to fix the weird texture/ghost-input/moving screen/vibration issues people have with some devices with aroma v2.56)
    ø Major code clean-up, various bugfixes
    • Re-organized and cleaned-up both aroma-config and updater-script
    • Fixed the way the installation process input displays sections and sub-sections
    • Fixed some tweaks getting installed instead of others when they shouldn't, and some other bugs
    I'm pretty sure I forgot some stuff, I'll add it when it comes back in mind
    Ultima modifica di Uzumaki99; 29-06-13 alle 19:35
  11. I seguenti 2 Utenti hanno ringraziato Uzumaki99 per il post:
    fedelamb (29-06-13),leonardodettoileo (17-08-13)
  12. #6
    Galaxy Nexus
    Smartphone Testati
    • - Acer Liquid Metal (codename ?)
    • - Asus Infinity (TF700)
    • - Asus Eee Pad (TF101)
    • - Asus Transformer Pad (TF300T)
    • - Cube U30GT-H (Chinese Tab)
    • - Google-Asus Nexus 7 (Grouper)
    • - HP Touchpad (codename ?)
    • - HTC Amaze (codename ?)
    • - HTC Desire C (codename ?)
    • - HTC Desire S (S510E)
    • - HTC Desire HD (codename ?)
    • - HTC Desire Z (codename ?)
    • - HTC Droid Incredible (codename ?)
    • - HTC Evo 3D (codename ?)
    • - HTC Evo 4G (Supersonic)
    • - HTC Explorer (A310e)
    • - HTC HD2 (T9193)
    • - HTC Incredible S (S710e)
    • - HTC MyTouch 4G Slide (codename ?)
    • - HTC One V (Primo)
    • - HTC One X (Endeavour)
    • - HTC Thunderbolt (ADR6400L)
    • - HTC Tattoo (Click)
    • - HTC Vision (T-mobile G2)
    • - Huawei Ascend (g300)
    • - Huawei Honor (U8660)
    • - Huawei U8030 (codename ?)
    • - Huawei u8800pro (codename ?)
    • - Le Pan II Tablet (codename ?)
    • - LG Eclypse (C800)
    • - LG G2x (P999 DW)
    • - LG Optimus Black (codename ?)
    • - LG optimus one (P500)
    • - LG Optimus 3D (P920)
    • - LG Optimistic V (VM670)
    • - Motorola Atrix 2 (MB865)
    • - Motorola Atrix 4G (MB860)
    • - Motorola Bravo (MB520)
    • - Motorola Defy (codename?)
    • - Motorola Droid X (MB810)
    • - Motorola Droid 2 (DW2E)
    • - Motorola Photon Q (codename ?)
    • - Motorola Triumph (Virgin Mobile model)
    • - Samsung Galaxy Ace + (S7500)
    • - Samsung Galaxy Nexus (i9250)
    • - Samsung Galaxy Nexus 4G (Verizon)
    • - Samsung Nexus S (i9020)
    • - Samsung Nexus S (SCLCD - i9023)
    • - Samsung Galaxy Exhibit 4g (Ancora)
    • - Samsung Galaxy Gio (S5660)
    • - Samsung Galaxy Note (N7000)
    • - Samsung Galaxy Note 2 LTE (N7105)
    • - Samsung Galaxy Note 10.1 (N8000)
    • - Samsung Galaxy Player 5 (YP-G70)
    • - Samsung Galaxy S (I9000)
    • - Samsung Galaxy S Advance (I9003)
    • - Samsung Galaxy S Plus (I9001)
    • - Samsung Galaxy S2 (i9100)
    • - Samsung Galaxy S2 (T-Mobile T989)
    • - Samsung Galaxy S2 (AT&T i777)
    • - Samsung Galaxy S2 (SHW M250k)
    • - Samsung Galaxy S2 Epic 4g Touch (SPH-D710)
    • - Samsung Galaxy S3 (I9300)
    • - Samsung Galaxy S3 (ATT 1747)
    • - Samsung Galaxy S3 (T-Mobile)
    • - Samsung Galaxy Tab (P1000)
    • - Samsung Galaxy Tab 2 - 7.0 (P3100)
    • - Samsung Galaxy Tab 7.7 3G (P6800)
    • - Samsung Galaxy Tab 7.7 Wifi (P6810)
    • - Samsung Galaxy Tab 7.7 Verizon (i815)
    • - Samsung Galaxy Tab 8.9 (p7300)
    • - Samsung Galaxy Tab 10.1 Wifi (P5110)
    • - Samsung Galaxy Y (S5360)
    • - Sony Live with Walkman (WT19)
    • - Sony Xperia Arc S (LT18i)
    • - Sony Xperia Mini (ST15i)
    • - Sony Xperia Neo (codename ?)
    • - Sony Xperia Neo V (codename ?)
    • - Sony Xperia P (LT22i)
    • - Sony Xperia Play (R800i)
    • - Sony Xperia Ray (ST18i)
    • - Sony Xperia Sola (MT27i)
    • - Sony Xperia U (ST25i)
    • - Toshiba Thrive (codename ?)
    Crediti
    • - amarullz for Aroma Installer
    • - ...Awesome... for Beats Audio
    • - ImbaWind for Adrenaline Boost
    • - Rizal Lovins for Sony Walkman apps
    • - blunttedsmurf for Hulu+ hacked
    • - pikachu01 for his Thunderbolt scripts
    • - The AOKP Team for some of their source-code
    • - gangsterjoop for All countries gps.conf files
    • - Whitson Gordon from Lifehacker.com for the Thread top image.
    • - Pocketnow.com for the awesome PmR presentation video
    • - Papa Smurf151 for his friendly help and some tweaks found in his SmurfedOut Script
    • - dj_stikes & Boxer145 for Translating PmR to Spanish (Aroma Version)
    • - android1234567 for correcting my spelling mistakes
    • - iurkin for correcting and helping me understand my java mistakes
    • - prabs99 for donating
    • - neckbonest for donating
    • - Timusonchik for donating
    • - beckzz for donating
    • - effooh for donating
    • - chrisrotolo for donating
    • - mutiny for donating
    • - domics for donating
    • - edwardolavarrieta1 for donating
    • - azdavef for donating
    • - Wim de Klerk for donating
    • - chuckenheimer for his donation on Flattr
    • - Nicholas Shake for donating a high performance server that serves your in-app downloads much faster, and allows me to have a full development environment everywhere I go via vnc.
    • - Each and Every users who provided constructive feedback to help improving this project to its current state
    Ultima modifica di Uzumaki99; 29-06-13 alle 19:24
    My G.Nexus
    Rom: Firework
  13. Il seguente Utente ha ringraziato Uzumaki99 per il post:
  14. #7
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    ottima mod!!la proverò appena posso....xD
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  15. #8
    Jul 2010
    Galaxy s4 - Galaxy Nexus
    Ma non ho capito bene, Ciòe è un apk con cui si possono fare un sacco di mod?
  16. #9
    Senior Droid L'avatar di NexusSte91
    Ringraziato 88 volte in 81 Posts
    Quote Originariamente inviato da Crotan Visualizza il messaggio
    Esattamente, puoi applicare molti Tweaks e Mods
    Qualcuno riuscirebbe a darmi due dritte per non applicare qualche mod sbagliata?
    Androidiano VIP L'avatar di giupa87
    Gela, Italy, Italy
    Galaxy Nexus
    Ringraziato 225 volte in 194 Posts
    Semplicemente non applicare Tweaks e Mods a caso senza informarsi sulla loro azione... E comunque quando si usano questi software é sempre bene avere a portata di mano un Nandroid Backup, in quanto alcune modifiche potrebbero mandare in bootloop il telefono.
    E soprattutto provatele prima su una rom stock con soli i permessi di root onde evitare incompatibilità con le mod inserite dai developer delle varie rom
