| C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\res\values\public.xml:998: error: Public symbol drawable/quality_f declared here is not defined.
C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\res\values\public.xml:997: error: Public symbol drawable/quality_n declared here is not defined.
C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\res\values\public.xml:999: error: Public symbol drawable/quality_sf declared here is not defined.
Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 17, --target-sdk-version, 19, -F, C:\DOCUME~1\HP_PRO~1\IMPOST~1\Temp\APKTOOL28805016 43011037427.tmp, -0, arsc, -I, C:\Documents and Settings\HP_Proprietario\apktool\framework\1.apk, -S, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\res, -M, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\AndroidManifest.xml]
at brut.androlib.Androlib.buildResourcesFull(Androlib .java:358)
at brut.androlib.Androlib.buildResources(Androlib.jav a:283)
at brut.androlib.Androlib.build(Androlib.java:206)
at brut.androlib.Androlib.build(Androlib.java:176)
at brut.apktool.Main.cmdBuild(Main.java:228)
at brut.apktool.Main.main(Main.java:79)
Caused by: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 17, --target-sdk-version, 19, -F, C:\DOCUME~1\HP_PRO~1\IMPOST~1\Temp\APKTOOL28805016 43011037427.tmp, -0, arsc, -I, C:\Documents and Settings\HP_Proprietario\apktool\framework\1.apk, -S, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\res, -M, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\AndroidManifest.xml]
at brut.androlib.res.AndrolibResources.aaptPackage(An drolibResources.java:357)
at brut.androlib.Androlib.buildResourcesFull(Androlib .java:336)
... 5 more
Caused by: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 17, --target-sdk-version, 19, -F, C:\DOCUME~1\HP_PRO~1\IMPOST~1\Temp\APKTOOL28805016 43011037427.tmp, -0, arsc, -I, C:\Documents and Settings\HP_Proprietario\apktool\framework\1.apk, -S, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\res, -M, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\AndroidManifest.xml]
at brut.util.OS.exec(OS.java:89)
at brut.androlib.res.AndrolibResources.aaptPackage(An drolibResources.java:355)
... 6 more
I: Checking whether sources has changed...
I: Checking whether resources has changed...
I: Building resources...
Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 17, --target-sdk-version, 19, -F, C:\DOCUME~1\HP_PRO~1\IMPOST~1\Temp\APKTOOL84628604 97659802987.tmp, -0, arsc, -I, C:\Documents and Settings\HP_Proprietario\apktool\framework\1.apk, -S, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\res, -M, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\AndroidManifest.xml]
Caused by: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 17, --target-sdk-version, 19, -F, C:\DOCUME~1\HP_PRO~1\IMPOST~1\Temp\APKTOOL84628604 97659802987.tmp, -0, arsc, -I, C:\Documents and Settings\HP_Proprietario\apktool\framework\1.apk, -S, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\res, -M, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\AndroidManifest.xml]
... 5 more
Caused by: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 17, --target-sdk-version, 19, -F, C:\DOCUME~1\HP_PRO~1\IMPOST~1\Temp\APKTOOL84628604 97659802987.tmp, -0, arsc, -I, C:\Documents and Settings\HP_Proprietario\apktool\framework\1.apk, -S, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\res, -M, C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\AndroidManifest.xml]
... 6 more
C:\Android\APK-Multi-Tool\other\..\projects\SamsungCamera3ModIlNikV0.0. 4.apk\res\values\public.xml:999: error: Public symbol drawable/quality_sf declared here is not defined. |
