Oneplus 9
Oneplus 5 6/64
ROM: Pixel Experience 9.0
Nexus 5
Galaxy Nexus (venduto)
19venom89 (14-02-14)
build 6 is out!!
Changelog
- Several updates from CyanogenMod repositories (in line with all of them until February 18);
- Open source Google dialer and more;
- Configurable volume panel timeout;
- Fix white background in dialer when TRDS is enable;
- Fix icons overflowing status bar view in center clock and date layout;
- Handle navbar heights correct on dpi changes (i'm including this because of a possible upcoming DPI changer feature!) ;
- TRDS fix possible UI freeze on auto mode change;
- Some OmniSwitch updates;
Link download in OP
Oneplus 9
Oneplus 5 6/64
Nexus 5
build 7 is out
Changelog - 02.03.14
- Several updates from CyanogenMod repositories (in line with all of them until March 2);
- Lockscreen notifications;
- Lockscreen blur radius customization;
- Screen recorder;
- Wakelock blocker;
- Added incoming call in background from SlimRoms;
- Removed non intrusive call;
- Media scanner behavior on boot;
- Notification reminder;
- Build with SlimRoms camera app (bunch of more features than CM - Let's test);
- Build with Linaro toolchain 4.8.3;
Download in OP
una cortesia: chi la installa mi puo fornire degli screenshots aggiornati?
grazie in anticipo
Ultima modifica di morfances; 03-03-14 alle 09:22
Oneplus 9
Oneplus 5 6/64
Nexus 5
build 8 is out!!!
12.03.14
- Several updates from CyanogenMod repositories (in line with all of them until March 12);
- New Slim Roms recents panel;
- Ability to switch between stock or slim roms recents panel (SystemUI restart is required);
- Smart Pulldown;
- Improved scrolling cache;
- Update UI guide lines (blue to holo);
- LatinIME: make secondary chars better visible at TRDS dark keyboard;
- Fix status bar clock actions;
- Frameworks: Ability to Enable/Disable Smart Wake covers ;
- Frameworks: Notification Reminder Interval && Fixes;
- SystemUI: Notification Reminder New Layout && Fixes;
- DownloadProvider: Add transfer speeds in notification;
Download in OP
Oneplus 9
Oneplus 5 6/64
Nexus 5
Qualcuno l'ha provata?
Se ti ho aiutato a risolvere il problema clicca sul tasto Thanks qui sotto ↓
Io la ho su da svariate ore e va una meraviglia abbinata alle banks minimal gapps (altre gapps scaricate quindi ibernabili), al burst kernel pgm settato stock del 20/2 con runtime dalvik.
Si comporta bene sempre, le temperature sono abbastanza basse, nessun problema.
Il thanks rende sempre felici: datelo!
Ogni messaggio di assistenza sarà cestinato!
DEVICE: Asus Zenfone 2 ZE551ML
ROM: Stock MM
KERNEL: Stock
MODS: No
LAUNCHER: Nova Prime
RECOVERY: TWRP
Oneplus 9
Oneplus 5 6/64
Nexus 5
markusssss (14-03-14)
Build 9 is out
- Several updates from CyanogenMod repositories (in line with all of them until March 20);
- Keyboard: toggle to enable/disable fullscreen on landscape
- Keyboard: force autorotation on IME
- Keyboard: force to show always enter key
- Browser - blue to grey browser's progress bar (follow new kitkat UI);
- Browser - fix browser blue textfield;
- Connection manager (TeloRadio);
- Slim recent with option to show in left side and switch sizes (100, 85 and 70%);
- Slim recent add favorite mode (click on app icon in recent panel to choose as favorite);
- Reverted SlimRoms location tile and switched with new CyanogenMod one;
- Live volume steps;
- Custom navbar recent long press (none, last app, screenshot, kill app, notifications panel, QS panel, power menu);
- Option to enable notifications light with screen on;
- Removed Google revert lookup;
- Added people lookup settings;
Oneplus 9
Oneplus 5 6/64
Nexus 5
LuCiolla90 (20-03-14)
Con la build 8, dopo qualche giorno di utilizzo, cade la linea e quando vado ad utilizzo dati o altro il processo android phone si interrompe ma sempre senza linea rimango. Risolto flashando un'altra rom, giusto per cambiare. Le darò un'altra possibilità tra un po' di tempo.
ROM: Stock MM
KERNEL: Stock
MODS: No
RECOVERY: TWRP
Build 10 is out
- Several updates from CyanogenMod repositories (in line with all of them until April 03);
- Long press back to kill configurable timeout (2, 1, 1.5 or 0.5 seconds) ;
- Removed CM updater, statistics and changelog (avoid users updating from stock cm);
- Move wakelock blocker to Advanced in settings headers;
- Slim recent: Frameworks: notify array adapter early that data has changed on clear all;
- Slim recent: Frameworks: do not kill favorite recent apps;
- Option to disable widget frames in lockscreen;
- Custom lockscreen wallpaper;
- Take date into account to not overflow icons in stock or center clock;
- General fixes in lockscreen notifications;
- Lockscreen blur: disable if music is playing;
- Back with CyanogenMod camera app;
Download
Oneplus 9
Oneplus 5 6/64
Nexus 5
