New build is out
9th July 2014 (ver 2.9.9 )
9th July 2014 (ver 2.9.9bld2 )
1. Fix Floating Window Mode.
- Correct wrong behaviour with back button pressed
- Fix possible NPE with press action outside float window.
2. Email
- auto fetch attachment with POP3 account
- fix save attachment to local disk with POP3 account
1. F2FS &EXT4 all in one support by fallback file system handling support (credits Team Motorola Mobility and MWisBest)
- just flash the rom no matter which file system you are using, no need to use base pack replacement anymore.
2. Quiet Hours Rewrite (Slim)
3. Swipe to lauch Floating Window with Recents (Stock view) and Notification (PA)
- swipe left/down to lauch Floating mode
- swipe helper
4. Hover performance improvements and updates (PA)
- Respect screen limits
- don't treat outside touch event.
- exclude from insecure lockscreen
- fix custom display timeout not showing
5. Quiet Hours Rewrite (slim)
- New Toggle States.
Toggle is now aware of if quiet hours is truly enabled or not.
Enable "force" mode on click: turns quiet hours on / off
Double-click to return to "timed" mode.
- New Features:
Wifi Connected Requirement
Battery Charging Requirement
Individual day times
- Completely rewrote quiet hours to reduce system calls.
No more calendar objects or checking three preferences
and comparing their values on each quiet hours check.
Reduce that to ONE preference check per preference
6. HEADS UP Notification (Slim)
it is a exposed version feature of AOSP L, simply like PA's Hover and modified by Slim.
- seperate control on Mms, Dialer and Email Client
- replace non-intrusive callcard with Incoming Call in background
- snooze timer support.
7. Settings
- Make settings searchable.
- show devices connect to Wifi hotspot
- Use actual storage type of sdcard/usb
- Show notification on adb over network
- App sidebar : fix icon label
8. OmniSwitch: added flat style
9. Keyguard IO and rotation improvement (vanir)
10. External SD card write permission fix
11. Android Lollipop Fonts
12. Apollo: Display the song duration in the queue and info views
