Utente della settimana: 9mm con ben 7 Thanks ricevuti negli ultimi sette giorni
Pagina 35 di 35 primaprima ... 25333435
Visualizzazione dei risultati da 341 a 350 su 350
[ROM][KK - 4.4.x][HALO][PIE][Wifi Display]CM-REMIX-Burst-Kernel-KANG
  1. #341
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    New build !!!!!!!!
    11th August 2014 (ver 3.0.2 bl3) [/URL]
    fix webview issue
    10th August 2014 (ver 3.0.2 bl2)
    - fix compatibility issue with Google Camera.
    Previously I am using the Linaro toolchain optimize jpeg library which breaks google camera.
    - add back change wallpaper permission with systemui to fix blackscreen issue with google home launcher installed.
    - Remove Touch Slop in Scrolling settings which cause hampering
    bld1
    - fix call delay and fc with sound settings
    Ultima modifica di morfances; 11-08-14 alle 12:44
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
    Sep 2010
    ROMA
    New build is out!
    25th August 2014 (ver 3.0.3)
    This project will be postponed after this build.
    I have been working hard and concentrated on polishing some details and bring
    in some theming component as an alternative choice for a rom with no new theme engine.
    Thx to the beta tester from Chinese forum to help me out with this (final) release.
    Add Custom Color support (credits darkKat)
    - Slim Recents header
    - Navbar and statusbar background
    - Statusbar: system and notification icon
    - Notification panel : wifi and carrier label
    - Settings menu (root list) : icon and titles
    Custom Boot Animation (AOKP and darkKat)
    Statusbar
    - Taffic Meter style revamps (Omni)
    - notfication counts on statusbar
    Notification :
    - Settings buttons (configurable)
    - Tiles edit buttons (shown by default with quicksettings panel)
    - consistent animation effect when swiping
    Quicksettings :
    - enable equalizer for wifi display
    Active Notification :
    - fix quiet hours logic (Vanir)
    - rework settings menu : Corresponding settings option display according to notification service selected.
    Battery :
    - Circle Battery : add Dot length, offset and interval settings (darkKat)
    Dialer :
    - add popup menu with enabler option when selecting headsup notification
    Others
    - Increase Cpu Boost time to Scrolling
    - Catch possible FC with statusbar recreation
    - Soft Reboot mode (CM)
    Ultima modifica di morfances; 18-09-14 alle 11:56
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  4. #343
    Ma è normale che l'unica lingua disponibile sia l'inglese ed il cinese? Parlo di questa ultima versione
    Avevo scaricato la prima versione e rispetto a quella che sto scaricando adesso mancava qualche mb, probabilmente le varie longue
    Ultima modifica di matogrosso; 25-08-14 alle 13:03
  5. #344
    Sep 2010
    ROMA
    Piccolo update tra cui fix per la lingua
    cm-11-REMIX-20140827-maguro-BURST-KERNEL-KANG_RELEASE_3.0.3bld2.zip
    27th August 2014 (ver 3.0.3bld2)
    1. Fix Density changer derp (white line under action bar)
    2. PA Pie cleanup and fixes :
    - borrow some code from DU and AICP which fix PIE Stick
    - fix swipe action target and notification layout.
    3. rearrage notification button order, move clear button to the right side.
    Ultima modifica di morfances; 29-08-14 alle 10:31
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  6. #345
    Sep 2010
    ROMA
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  7. #346
    Sep 2010
    ROMA
    Scusate il ritardo nella comunicazione
    E' uscita la STABLE !!!!
    DOWNLOAD
    3rd Sep 2014 (ver 3.0.4 STABLE)
    Fix notification keep showing up in several case
    Fix Volume Panel overlay time not sticking.
    PA PIE :
    - add torch, omniswitch, gesture panel button
    - not showing search button by default, and option not lights out if google search is not install.
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  8. #347
    Sep 2010
    ROMA
    RAGAZZI,E' USCITA LA STABLE FINAL !!!!
    Come comunico a suo tempo il dev, infatti, lo sviluppo della rom doveva fermarsi gia alla scorsa versione...ma è continauto fino alla 3.0.4
    Speriamo non sia vero...voi lamentatevi...magari su XDA!!!
    cm-11-REMIX-20140917-maguro-BURST-3.0.4-STABLE-FINAL.ZIP
    17th Sep 2014 (ver 3.0.4 STABLE Final)
    Fix screen turn on dim issue with Stable kernel
    Headsup Custom Background
    sync slim translation
    sync CM aosp patches
    Adaptive backlight support (CM)
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  9. #348
    Androidiano L'avatar di street21
    Samsung Galaxy Nexus
    Ma magari implementasse il theme engine che penso che sia "d'obbligo" ormai al posto del theme chooser.
  10. #349
    Sep 2010
    ROMA
    Ragazzi ...è uscita la FINAL definitiva!!Piccoli fix
    15th Nov 2014 (ver 3.0.5 Maintainance Build)
    Fix Camera Tile with Chervon action from PA Pie
    Merge latest CM repo update.
    Fix minor FC issue with Settings.
    Custom HeadsUp text color
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  11. #350
    Sep 2010
    ROMA
    Ragazzi pare che burstlam non voglia fermarsi....
    26th Nov 2014 (ver 3.0.5 Maintainance Build2)
    LINK DOWNLOAD
    hope to address the strange power drain issue with last build
    Wifi notifications (vanir)
    fix possible fc with headsup (crdroid)
    dialer : Speaker proximity support (slim)
    settings: fix statusbar double tap to sleep not sticking
    settings: squashed latest translation from Slims and CM
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
