Io la trovo superiore alla cmRemix come stabilità e fluidità. La sto provando con fancy
Salve, quando riproduco musica, ho il messaggio sistematico che DSP si è bloccato in modo anomalo. Ho tutto stock. Capita a qualcun altro?
Oneplus 9
Oneplus 5 6/64
ROM: Pixel Experience 9.0
Nexus 5
Galaxy Nexus (venduto)
USCITAAAAAAAAAAAAAAAA
AOSB KitKat 1.3.0
Changelog
download in OP
Ultima modifica di morfances; 22-02-14 alle 13:31
Oneplus 9
Oneplus 5 6/64
Nexus 5
fedelamb (21-02-14),LuCiolla90 (21-02-14),Tardis00 (21-02-14)
flashata oggi, per il momento va a bomba
...tutto ok...ma...quando esco da CLASH OF CLANS scompare o la barra inferiore o la superiore e mi tocca riavviare... mahhh
TheAlmighty (23-02-14)
confermo...non mi aggiornava il meteo CHRONUS
TheAlmighty (24-02-14)
nuova build 1.3.1 probabilmente domani :
"If i don't run into more trouble new build wil be up tomorrow " da XDA
edit : per maguro son passati direttamente alla 1.3.2
"we skipped 1.3.1. due to to many compiling errors
already known bug in this one is FC when opening 'about phone' in 'settings'"
Changelog AOSB 1.3.2
AOSB RecentApp : Add HTC Reflection Effect
Settings: Enable or disable Navring make it optional
Settings: Make SlimRecent optional
Settings: Show or hide Navrbar in lockscreen
Notification drawer: full swipe to switch detection
Disable Left NavBar for tablets
Breathing Missedcall
Breathing SMS
Breathing Voicemail
Battery saver mode: Revamp ! huge fixes
Dialer: Fix chinese force close
Base: Dynamic data usage
Merge all CM Multi SIM Support
wide changes to support MSIM
SystemUI: Fix big force close causing support MSIM
SystemUI: Fix displaying of user photo.
SystemUI: Only show H+ if config_hspa_data_distinguishable is set
SystemUI: Navigation bar Allow "right to left" gesture to launch search panel
Fix graphics corruption caused by HWUI caches
Fix for positioning of glyphs within a bitmap
Gallery: New Optimized DarkerUI
Settings: fix force close when receiver is not registered
Marquee text RTL improvements
Fix the screen-off animation ignoring value set in ro.sf.hwrotation
Frameworks: Slimrecents fixes
Telephony(MSIM): Add control flag for SIM app auto provisioning
Mms: Fix random bubble width bug
Mms: Add interface to support sending sms with origination port
Mms: Add configuration for sending and receiving Mms with data disabled
Statusbar(MSIM): Do not display data icon if data is not connected.
Fix for data and roaming icons
add new AOSB stats
Add Android Kernel Tweaker (Rom Performance)
revert wifi name from notification drawer
Telephony: fix reverese lookup gms logic detection
Download in OP
Ultima modifica di morfances; 08-03-14 alle 17:21
Oneplus 9
Oneplus 5 6/64
Nexus 5
Tardis00 (08-03-14)
