certo a me halo manca ...ma la proverò
puoi verificare oltre la durata della batteria se il kernel di defualt supporta il il touch control?
tutto il resto si risolve con xposed...xD
Oneplus 9
Oneplus 5 6/64
ROM: Pixel Experience 9.0
Nexus 5
Galaxy Nexus (venduto)
Da quando ho cambiato i suoni di sistema(blocco, sblocco schermo e gli altri), all'avvio mi ottimizza sempre 39 applicazioni.
Ho riflashato la ROM e niente, il problema persiste.
Ultima modifica di shocker94; 07-05-14 alle 13:26
New build is up!!
TREX-KK-Stable-20140509-1424-maguro.zip
android_frameworks_base
-FWBase Restylen fix AOSP recents panel
-resume: fix recents showing up when waking the device with the home button
-update animation scale defaults with the new slim/ios ones
-Add the calling package name to requestRouteToHost
-Only allow System apps to make VPN exempt routes
-Update LinkProperties with MTU value
-Connectivity: Set TCP delayed ACK and User Configuration Flag
-services: change default sampling interval to -1
-frameworks: import AppOpsManager
-Revert "FWBase Restylen fix AOSP recents panel"
-Revert "Update Circular Memory indicator for recents panel [1/2]"
-Revert "Circular Memory indicator for recents panel [1/2]"
-FWBase Restyle fix AOSP recents panel
-QS: add theme switcher tile (TRDS) 1/2
-Circular Memory indicator for recents panel [1/2]
android_frameworks_native
-Add OMX_AUDIO_CodingAPE and OMX_AUDIO_CodingDTS
android_vendor
-Build Stagefright FFMPEG plugin
android_packages_apps_Settings
-Settings - Few Performance Control Fix
TREX Settings
-Fix some derps
-Revert "Circular memory indicator for recents panel [2/2]"
-Circular memory indicator for recents panel [2/2]
-QS: add theme switcher tile (TRDS) 2/2
android_packages_apps_InCallUI
-MSIM: Use operator name instead of SUBS for InCallUI
android_packages_services_Telephony
-MSIM: Use operator name in Select subscription settings
-Holoize multi-SIM call target selection dialog.
-MSimDialerActivity: actually dial when an option is selected
Oneplus 9
Oneplus 5 6/64
Nexus 5
fedelamb (09-05-14),leonardodettoileo (09-05-14),LuCiolla90 (10-05-14)
Stò provando questa Rom, mi riservo un giudizio dopo un uso prolungato, per ora sembra all'altezza (fino ad ora un solo bug che però non mi infastidisce: non si attiva il led quando il telefono è sotto carica), solo mi servirebbe aiuto per trovare i tasti per la navbar da poter sostituire a quelli di default. Potreste indicarmi un link da dove poterli scaricare?
Un po di consumi con questa rom + kernel fancy
Oneplus 9
Oneplus 5 6/64
Nexus 5
New build is up!!!
TREX - maguro 13.05.2014
-Revert "FWBase - Adding old-school (JB like) battery percents style due to its better visibility [1/2]"
-UserTile: Fix displaying user information for multi-user devices
-MediaFile: support more media types
-CM11 Themes: Ensure customTheme is not null.
-CM11 Themes: Include alarms in mixnmatch.
-CM11 Themes: Properly handle SystemUI theme package name.
-CM11 Themes: Common overlay for sharing resources. [1/2]
-Set themes to install internal only
-[1/2] Slims Hardware Key Rebinding
-PEEK [1/2]
-cleanup RecentsPanelView
-FWBase - Recents stock fix again
-CamcorderProfile: Add 4k timelapse encoder constants
-CM11 Themes: Common overlay for sharing resources. [2/2]
-SF: Reduce size of DisplayFrame according to "transparent region"
android_vendor
-cm-11 themes: Build new ThemesProvider
-Integrate duplicated NTT DOCOMO carrier labels
-fix typo for True-Move carrier
-Move FFMPEG codecs builds from common_full.mk to common.mk
-cm: policy for ipv6 tethering
android_build
-build: core: Parameterize recovery with a variant
-releasetools: Fix whitespace error for INSTALLED_DTIMAGE_TARGET
-tools: getb64key - print the base64 version of a PEM public key file
-releasetools: Properly handle boot images that use dt
-Store the base64 release key in the OTA zips
-fix error building
-build: use /usr/bin/env to call python
-releasetools: bring back boot.img handling
android_device_samsung_tuna
-tuna: Add default value for display color control
-TOUCHBOOST_FREQUENCY
-update TOUCH_BOOST
android_kernel_samsung_tuna
-omap2: overclock ram.
-input: remove old boostpulse fd write crap.
-input: touchboost: add the same generic input time driver from my other Kernels.
-cpufreq: interactive: add changes to allow for input boost events.
-cpufreq: Break out early if freq equals to target_freq
-mm: vmscan: If kswapd has been running too long, allow it to sleep
-selinux: add a ugly workaround to bail early when selinux tries to free a socket that is still in use and it ends in a Kernel panic. These lines are from opensource.samsung.com. While this will most likely put a bandaid over this Kernel panic it does not fix the bug so it might occur somewhere else if the same conditions are met but since I have only seen panics from this hook then we may as well sleep in peace.
-SELinux: Fix memory leak upon loading policy
-SELinux: Fix kernel BUG on empty security contexts.
-irq: Set CPU affinity right on thread creation
-Add Joe's RCU. Original patch from Joe Korty.
-tuna: no need for 16mb reserved for the framebuffer.
-rename to TREX-SaberMod-Kernel-kkr2
-Show "Eject card" for usb storage
-PEEK [2/2]
-MSim Settings: Update UI/UX with user friendly strings
-MSIM: Update icon for Multi Sim Settings category
-Add back notification light settings
-settings: Remove "mobile plan"
-Bluetooth: Release pan proxy object while coming out from tethering menu
-Bluetooth: Ignore the second button if one already pressed
-Fixes error message during pairing of HOGP devices
-Bluetooth: Increase allowed duration to connect to a profile
-P2PSetting:Avoid p2p_find on group removal event
-Packages : Fix for Softap turn ON/OFF fail issue.
-Themes: List ThemeSettings as a valid fragment
-Add new themes items to personalization menu
TREX Settings
-Slims Hardware Key Rebinding
-Ram circle: set correct value
-Underp the dialpad buttons
-Revert "Underp the dialpad buttons"
-InCallUI: Code cleanup
-Telephony: Set X-Divert as untranslatable.
-MSim: always enable activity disabler
android_packages_apps_Dialer
-Dialer: Code cleanup
Download
Oneplus 9
Oneplus 5 6/64
Nexus 5
leonardodettoileo (13-05-14),LuCiolla90 (13-05-14)
State "attenti" a questa versione della rom...
A parte che io l'ho spremuta a fondo questa T-rex (non è altro che una brutta copia della Carbon rom) e dire che non mi ha convinto è un eufemismo ! Comunque ho visto nel changelog che nel kernel (che non è altro che un Vanir con 4 modifiche) hanno inserito dei commits Selinux che stanno dando alcuni problemi (ad esempio problemi all'app drawer .. alcune icone apps spariscono) .. se ne parla nel topic del franco kernel su XDa, Franco kernel dal quale il team T.rex ha apportato quei commits... il problema si presenta su alcune roms, non su tutte eh...
Le cose che non mi piacciono del kernel "stock" di questa rom sono:
- smartreflex MPU, core e IVA OFF tutti e tre imposti di default...
- F.sync su off (state molto attenti alla perdita dati) imposto di default
- Temperature più alte della media (SR era meglio tenerlo su On)
- il kernel da init.tuna.rc impone il settaggio Cpu-max freq a 729600 Mhz..
- caricamento al boot di 3 scripts oltre ad un loro file cfg che modidicano i valori di altri kernel (dovreste usarla con il loro kernel) se non si ha l'accortezza di rimuoverli manualmente...
Per i miei gusti (come Vanir) impongono troppe cose, senza dare la possibilità all'utente di rimuoverle facilmente
Ultima modifica di Alkemix; 13-05-14 alle 17:36
Il duro lavoro condiviso gratuitamente va rispettato, non calpestato !
SuperMIUI ROM 4.2.2 modificata e convertita a F2FS e resa compatibile con TWRP: kernel dfk 1.5 F2FS MIUI edition inside !
Kainen (21-05-14),LuCiolla90 (13-05-14)
Vabbè che c'entra tu provala , giacchè l'hai pure scaricata, mica è detto che nel tuo Nexus giri male eh.. a me non è piaciuta per niente .. riavvii sporadici abbastanza repentini ... non capisco come possa essere etichettata come stabile, francamente... bisogna diffidare dai team improvvisati spuntati dal nulla... meglio andare sui più blasonati ...
Ultima modifica di Alkemix; 13-05-14 alle 20:59
Kainen (21-05-14)
