NEW RELEASE
Aug/29/2016: 20160829 (alpha)
Rebase device tree from @zaclimon V2
Primo post aggiornato con link per il download
NEW RELEASE
Se non uccide fortifica
FIGLIO - PIXEL45GStock11
FIGLIA - IPHONE7
MOGLIE - MiA1Stock9
IO - S205G Stock11-TabSamA-TicwatchPro
SPARE- GNEXOMNI 4.4.4, N4Stock4.4.4,Moto360 2nd,N7 3G, N5XGZSOP9.0, Mi6 6/64MIUI10 GloDev 9.6.27
<-- Se ti sono stato utile, ricordati il THANKS
Il dev @zaclimon continua a lavorarci ed è arrivata alla V3 della AOSP:
V3: (30/08/16)
- Fixed sensors (For you Pokemon Go people )
- Semi-Fixed Camera (Taking pictures works but video recording not saving and I'm a bit clueless. See below for details)
- Fixed MPDecision
- Enabled Doze
- Used GPU drivers from Flo's N developper preview
About sensors, as some of you may know, it looks like the use of Clang broke the use of our sensors, however we can force the part responsible of it to be compiled with GCC. The patch for you builders can be found here:
https://github.com/xyyx/android_bion...1bd527231d9302
About camera, I don't know what's happening since I have 2 possible theories. I can see that the OMX encoder has some issues. That said, it could be possible that our HAL needs to be modified for Nougat support as seen here:
https://source.android.com/devices/c...html#hardening
If we use API1 HAL1, that's where it could get a bit tricky and can go harder than what I can possibly do. Flo doesn't have the same issue since it uses Camera2.
@ganachoco What's your insight regarding this? I know you had some issues with getting Google Camera because of Camera2.
Anyways enough talking. The build is available in the OP and I hope you'll be happy enough for the moment. Time for a little break now.
FIGLIA - IPHONE7
MOGLIE - MiA1Stock9
NEW UPDATE
Aug/31/2016: 20160831 (alpha)
Rebase device tree from @zaclimon V3
Primo post aggiorato con link
FIGLIA - IPHONE7
MOGLIE - MiA1Stock9
NUOVA RELEASE
PRIMO POST aggiornato con changelog e LINK per downloadSep/03/2016: 20160903 (beta)
Enable cpuset
implement exclusive core feature with simple mpcpusetd. @xenyz hints to me how to implement. Thanks.
Tune cpu governor while booting
FIGLIA - IPHONE7
MOGLIE - MiA1Stock9
AL momento @ganachoco non ha ancora incorporato la V4 di @zaclimon che ha il seguente changelog:
Update/Future
Hi guys! Another day, another update for the Nexus 4. I don't know if it'll be enough but anyway here it is:
V4 (02/09/16):
- Fixed H/W video decoding for the most part (can see YouTube 60 FPS videos/Was able to play some local video files using it as well)
- Kernel: SDCard FS enabled (I leave the discretion to the custom roms whether to really enable it or not)
- Attempt to fix permissions for GApps
- Enabled Navigation Bar tweaks and Night mode in SystemUI Tuner.
If YouTube is somewhat posing a problem with 60 fps playback, I compiled a test version of Quanta V19 which is compatible with Nougat. Please note that I won't be offering any support for this version as it is mostly experimental stuff.
It has been a somewhat challenging two weeks trying to get everything working, I definitely won't have a lot of time to be on this project anymore starting next Tuesday. School is beginning for me and I want to focus on some other projects (Quanta stuff mostly) Though, It's nice to see that there are still a lot of people interrested in flashing new updates and that's what is somewhat the heart of XDA. I wanted to get mostly everything working and I believe that it has been mostly accomplished. (minus some minor stuff like the flashlight and notification light) I'll leave out all the source required to build for the N4 + some patches I used. (GApps/Navigation bar + night mode)
At the same time I take the time to remind to some people here that might have some hope of features coming to this rom. Sorry to say it to you bluntly but I'll crush these dreams right away. This rom is meant as a way (even more as a proof of concept more than anything else really for this device) to get Android 7.0 running. As such it will act as a base for the custom roms that will have all your favorite feature.
FIGLIA - IPHONE7
MOGLIE - MiA1Stock9
NEW VERSION
Changelog:
Sep/05/2016: 20160905 (beta)
Rebase device tree from @zaclimon V4
Remove w/r permission from vidc encoder device to all
It seems while mediacodec server open vidc encoder, camera server cannot use hardware encoder, and cannot record video stream.
Fix facelock funtion
Update widevine drm binary blobs from bullhead.
It might prevent to crash mediadrm and media service. But I cannot be sure it can play drm contents.
Switch to user build.
Primo post aggiornato con link e tutto
FIGLIA - IPHONE7
MOGLIE - MiA1Stock9
NEW VERSION
Sep/07/2016: 20160907 (beta)
update to NRD90S (android-7.0.0_r4)
Turned on sdcardfs
Primo post aggiornato con link e changelog
FIGLIA - IPHONE7
MOGLIE - MiA1Stock9
Dai dai che stiamo per arrivare alla definitiva. 😁
Inviato dal mio Nexus 4 utilizzando Tapatalk
FIGLIA - IPHONE7
MOGLIE - MiA1Stock9
Qualcuno che la sta provando?? o devo fare da cavia io?
