Toc toc :d
Toc toc :d
Nexus 7 2013 32gb
Xiaomi Redmi Note 3 Pro - Gold
Dopo aver piallato tutto e ribloccato il bootloader mi esce ancora l'avviso del "device corrupted" qualcuno sa perché?
Aspettando uno top gamma con tastiera qwerty!
Si certo puoi anche se io preferisco i comandi adb
Inviato dal mio HTC One M9 utilizzando Tapatalk
Mi pare che a partire dal N5 sia stato introdotto un contatore che una volta sporcato occorre una azione diversa per ricordarlo Quando sono a casa trovo la guida e ti saprò dire
Ecco la miniguida
Si parla di TAMPER FLAG:
Inviato dal mio HTC One M9 utilizzando TapatalkThe Nexus 5 has a thing implemented in the bootloader called a tamper flag. This shows if the bootloader was ever unlocked, kind of like the flash counter with Samsung devices. You can check it out by using this command
Code:
fastboot oem device-info
. If the tamper flag value is "true", then you'll have to reset it. The following steps will reset this flag, and lock your bootloader.
•So, first, go here:
http://forum.xda-developers.com/show....php?t=2239421
(Thanks @osm0sis for the wonderful script)
Under "Flashable Zips", you will find the Nexus BootUnlocker script. Download it.
It runs for all NEXUS but not for N7 2012
•Put the zip on your internal storage.
•Download the latest TWRP recovery image for the Nexus 5 from here: http://techerrata.com/browse/twrp2/hammerhead. Rename it to TWRP.img.
Now boot it. You do this by booting your phone in fastboot, and typing the following command:
Code:
fastboot boot path\to\TWRP.img
*Replace path\to\TWRP.img with the path to where you placed the TWRP.img. For example: C:\Users\X\Desktop\TWRP.img
TWRP recovery should boot.
•When TWRP finished booting, select "Install", then navigate to the Nexus Bootunlocker zip, select and install it. After it finished, use the back arrow at the bottom of the screen to go back, and reboot.
Now your bootloader should be locked, and your tamper flag should show "false".
Ultima modifica di paolocorpo; 25-08-16 alle 21:31
Se non uccide fortifica
FIGLIO - PIXEL45GStock11
FIGLIA - IPHONE7
MOGLIE - MiA1Stock9
IO - S205G Stock11-TabSamA-TicwatchPro
SPARE- GNEXOMNI 4.4.4, N4Stock4.4.4,Moto360 2nd,N7 3G, N5XGZSOP9.0, Mi6 6/64MIUI10 GloDev 9.6.27
<-- Se ti sono stato utile, ricordati il THANKS
Buongiorno ho guardato in tutti i siti e non si spiega come mai quando accendo il telefono che ho riportato originale con nexus root toolkit mi si blocca subito l'animazione dei pallini colorati e si riavvia all'infinito, ho fatto tutti i wipe, provato a cambiare firmware rimettendo MM 6.0.1 adesso su ho android 7 l'ultima pubblicata ufficiale. Non so davvero cosa fare perche se fosse bootloop mi partirebbe dopo i wipe. non ho nandroid backup qualcuno può aiutarmi?? graizie in anticipo
Ciao si ho formattato anche data da twrp. è strano come bootloop perche non va l'animazione dei pallini colorati si blocca subito dopo un paio di secondi e poi riparte da google.. cosi all'infinito
Non ho capito la seconda frase scusa.. il adesso ho la factory + recovery stock e bootloader bloccato. piallare da adb che senso ha se non va fatto da root toolkit?
Da quello che ho capito... piu di qualcuno sta avendo i tuoi stessi problemi dopo aver usato toolkit. Io l'ho usato solo una volta per lo sblocco, poi ho usato sempre adb e non ho mai avuto problemi. Per curiosità, che versione di toolkit hai usato?
Nexus H791 using Tapatalk
