New build is up!!!
Cataclysm-Sep_10_2015-HAMMERHEAD-Lollipop-5.1.1_r14_Beta.zip
Changelog:
Sep 09, 2015: Sources updated to android-5.1.1_r14 (LMY48M)
Sep 06, 2015: Clear all notifications button on status bar.
Sep 06, 2015: Layers 2.1 support.
The new clear all notifications button will appear of course only when you got notifications and will replace the default one.
It will also temporarily replace the Sleep button if enabled (as that's the best place for it) till notifications are cleared.
It will allow you to clear all notifications while on lockscreen aswell.
New translations merged, thanks for all your hard work.
