Ciao a tutti ,
ma l'utilità della funzione layers ? , non l'afferro ????
Ciao dade, in che senso? c'è qualche funzione specifica?
Il progetto layers, è questo qui: https://www.androidiani.com/forum/th...-apps-rro.html
dadenet (23-06-15)
Adesso ci siamo ! , mi sono perso questa parte
grande @fabi_92 !
Nuova release ! : http://downloads.sonic-developers.com/hammerhead/
morfances (28-06-15)
Changelog bello corposo :
Added visualizer to lock screen
Added Dolby QS Tile.
Added SonicLauncher [ Based On Slim Launcher with some extra changes]
Added Backup and restore option to SonicLaucher
Added Show/Hide Status Bar Option to Sonic Launcher
Added Landscape Support to Sonic Launcher .
Added Kernel Adiutor as performance manager along with CM Performance Profiles
Updated Layer Manager to Latest [Thanks to Layer Development Team]
Integrate mobile network settings into SIM settings for MSIM
Re-add SIM color settings
InCallUI: SmartMute [Mute the incoming call by flipping the phone]
Fix call recorder exception on unknown number / conference call
Show waiting state in call title also for MSIM.
InCallUI: Bring back vibrate on call waiting
Add an option in the InCall UI to perform call recording.
Screen Recorder: Add Share and Delete options
Oneplus 9
Oneplus 5 6/64
ROM: Pixel Experience 9.0
Nexus 5
Galaxy Nexus (venduto)
dado70 (29-06-15)
Build RC 6.0 is out!
AOSP VERSION : Android L5.1.1-R6
SOKP VERSION : SOKP-L-5.1.1-LMY48G-R6.0
DOWNLOAD LINK
HIGHLIGHTED CHANGE LOG:
Compiled with Saber- Mod [Both rom and kernel]
Floating Window [ Like M or like Samsung ...what ever you imagine ]
Updated to Android L5.1.1-R6
Changed Rom & Kernel compilation tool chain to Saber-Mod
Floating Window with Multitasking [ Can be enabled vis appcircle bar,slim recents....]
Chrome floating issue fix
Gesture Lockscreen
Lockscreen weather/icons/text customization
Add Lock Clock,Weather Settings
Fix overflow/underflow problem in comparison logic in alarm
Added keyguard wallpaper functionality to WallpaperManager
Clean up keyguard carrier text handling.
improve DISMISS_KEYGUARD_SECURELY_ACTION behavior
Fix Photosphere/Camera FCs
Added option to disable lock screen shortcuts
Fix ro.telephony.default_network setting parsing
long press lock screen lock icon to sleep
fix device sleeping with lid with incoming call
Added option for lock screen visualizer to be disabled
Disabled visualizers during power save mode
Moved keyguard visualizer behind notifications
Fix for visualizer flash on track change
Added dynamically generate visualizer color
Fix LiveDisplay notification
Added option to Display cursor buttons in navigation bar while typing
Volume Button Long Press Skip Tracks
Allow disabling adjusting volume sounds
launch default music player on headset connect
AudioService: fix crash when no music player found
Fix volume key music controls and wake up
Map long press of MUTE to KEYCODE_MEDIA_PLAY_PAUSE
Add Weather display to status bar header
Fix "ghost" weather display in expanded status bar
SmartPullDown to SlimActions.
Add ability to ignore interruptions while active media playback
Chamber of Secrets
Hide secondary icon and divider on expanded panel.
Always show ZenPanel when showing expanded volume panel
Implement linked volumes
fix Notification volume slider linking
Fix notification sounds for wifi only devices
Fixed broken link in UiAutomation
fix heads up snooze button
Battery saver enhancements
Slim action float tile
Materialize Gesture everywhere close button and improve layout
Breathing missedcall/sms/voicemail [ Not tested]
Added Option to re start system ui in development settings
Restart SystemUI tile
Added restart systemui to slim actions
Left clock
Added timeout and instant lock option to slide lock
Fixed non-intrusive incoming call
SlimHeadsUp: Add a global 3-way switch
Non-intrusive InCall UI switch
Screen Security settings
Fix pattern visibility settings
Fix FC when adding shortcut to launcher
Add a 2 sec timeout for heads up notifications
Add toggle for captive portal check
HWKeySettings: Don't enable NavBar when disabling hw keys
Settings: fix BT switch enabling discoverable mode
Fix memory leak issue in application settings
Settings: add setting for default alarm tone
USB Settings: Warn before enabling UMS mode
Settings: fix bad MTP uncheck behavior
Fixed Network activity arrow andd removed option to hide
healthd: allow custom charger
fix Deadlocks
Fixed incoming call handling while heads up off : CM defects.
Fix for InCallUI post app close FC fix.
Browser: Power saving mode
Enable USB OTG settings for yureka
Sonic-launcher fix custom icon pack support
Added Backup restore launcher settings option
Sonic Launcher - Oprion to hide statusbar
Sonic-Launcher fix text label color in appdrawer.
Ultima modifica di morfances; 09-07-15 alle 07:17
Oneplus 9
Oneplus 5 6/64
Nexus 5
marcoidiano (06-07-15)
New build is out!!!
SOKP-L-5.1.1-LVY48C-R8.0
Updated To Android 5.1.1 r8
Changed Headsup options more friendly
Swipe Options - for notifications
Lauch Heads up notifications in floating mode
Lauch Notifications in floating mode
Appcirclebar float mode switch
Clean up floating mode option handling code
Gesture anywhere launch apps in floating mode & switch
livedisplay: Fix issue where settings weren't applied
Fix mounting of non-FAT formatted SD cards
Add multi SIM ringtone support
Add support for default ringtones per sim
Speed up Statusbar and Activity Manager
Mobile data tile: open network settings
WifiTile: Fix wifi toggle state in detail view
msim: Fix saving default sim from select SIM dialog
livedisplay: Round values up
Fix JNI global references leak in AudioEffect
Added SlimDim
Added Lockscreen wallpaper support [see security settings]
fix misaligned ripple for pin-entry backspace button in keygaurd
Fix ClassCastExceptions in systemui
SystemUI: dismiss brightness slider on screen off
livedisplay: Fix outdoor mode detection
improve lock screen wallpaper behavior
Fix a system server crash in backup
StatusBar Ticker
add reboot confirmation dialog for tablets
MediaScanner: Detect folders
KillProcessGroup on background thread
Fix a GL error leak issue
fix CTS DisplayTest.testGetMetrics
Density scaling: scale compatibility apps, wm command support
Rewrite Keyguard Visualizer
Fix keyguard wallpaper issues
Recentsevelopment shortcut
systemui: never show excluded recent task in recents view
Add an option to disable searchbar in recents
recents panel clear all button tweaks
replaced recents clear all button with a fab button
add floating button center option & change clear all button
Add Fade in and Fade out effect to Recents FAB
option to ignore the last app when clearing recents
Add membar to recents options
Show live wallpapers in the recents view on high-end devices
Screen pinning improvements
SlimRecent: Set topmost task to ON
Allow screen unpinning on devices without navbar [Set long press back button to kill task]
Added Extend swipe helper
Added on-the-spot user preference dialog
Stock Recents: Launch apps in Floating mode.
Floating windows update: Fixes and Improvements.
Floating windows: Fix when we close floating window also remove the task
Floating windows: Fix minimize/maximize buttons coloring
SystemUI: fix recents task view height calculation
Add alternate WebView provider package
fix NPE in visualizer tile
Soniclaucher : 75% transparent app drawer
add expanded desktop navbar action
Improve dalvik cache pruning
Allow skipping of dalvik cache pruning if boot marker is in place.
Support QC2.0 type charger
Oneplus 9
Oneplus 5 6/64
Nexus 5
Sembra una ROM spettacolare sulla carta, ad uso quotidiano come va?
Fluidità? Batteria?
Su quale base uno è portato a scegliere AOSP O SOKP?
Vorrei capire se ne vale la pena mollare Euphoria, sottolineo che non sono uno che salta di qua e di la da una ROM all'altra spesso, una volta trovato ciò che mi aggrada la tengo per molto molto tempo, esempio, la Mahdi l'avevo tenuta da quando è uscita fino a quando è uscita Euphoria..
PS
Gli screenshot in op non si vedono..
Ultima modifica di EneaMeeta; 27-07-15 alle 00:42
Inviato dal mio tostapane utilizzando tapatampax 😜
Nexus5 Black
ROM AICP
Kernel ..........
Se pesti una merda ... porta fortuna ... se il giorno dopo ne pesti un'altra ... doppia fortuna ... ma ... un pò meno furtuna non guasterebbe!!! Andrea Moretta
Seguo, anche io interessato alla rom e curioso di sentire pareri..
AOKP l'ho abbandonata per il modo di seguire gli utenti non inglesi..
