Blue Spark r128 is out !!
Download
build: use newest and improved blu_naro-7.1, build from developer snapshot Linaro GCC 7.1-2017.05, with updated components and improvements/fixes
makefile: surpress some gcc 7 default warnings
kernel: add support for gcc 7
msm: kgsl: Change %p to %pK in debug messages
msm: vidc: use %pK instead of %p which respects kptr_restrict sysctl.
proc: prevent accessing /proc/<PID>/environ until it's ready
ALSA: usb-audio: Fix NULL dereference in create_fixed_stream_quirk()
msm: camera: Restructure data handling to be more robust
BACKPORT: perf: Fix race in swevent hash
sg: Fix double-free when drives detach during SG_IO
audit: fix a double fetch in audit_log_single_execve_arg()
kernel: Only expose su when daemon is running, Fix potential refcount leak in su check
