Pagina 5 di 5 primaprima ... 345
Visualizzazione dei risultati da 41 a 47 su 47
[Guida] Root con Nexus 7 Toolkit
  1. #41
    Androidiano VIP L'avatar di paolocorpo
    SAMSUNG S20+5G
    Ringraziato 1,766 volte in 1,666 Posts
    ASUS NEXUS 7 TOOLKIT PUBLIC RELEASE V5.0.0 AVAILABLE!!
    mskip May 4, 2013 Google Nexus 7
    DONWLOAD LINK: http://goo.im/devs/mskip/toolkit/goo...Kit_v5.0.0.exe
    ChangeLog:
    +Completely restructured Toolkit code
    +FULL Support upto JellyBean 4.2.2 (all models)
    +Added model zip file download system after model selection to reduce download size
    +Default driver installation is now koush’s Universal driver pack which works upto and including Windows 8
    +Check md5 of stock image to make sure downloaded file isn’t corrupted before flashing
    +Downloaded stock image file is copied to the ‘backups’ folder before flashing for future use
    +Added adb sideload for auto flashing zip files
    +All stock images now downloaded from goo.im so the link won’t be broken if google delete the file
    +Latest CWM and TWRP Recovery images included
    +Lots more minor improvements and changes to nearly all procedures
    Thread Link: [Google Nexus 7 TOOLKIT V5.0.0] Drivers, Backup, Unlock, Root, Recovery, Flash + MORE - xda-developers
    Enjoy.
    Mark.
    Ultima modifica di paolocorpo; 05-05-13 alle 07:50
    Se non uccide fortifica
    FIGLIO - PIXEL45GStock11
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
    IO - S205G Stock11-TabSamA-TicwatchPro
    SPARE- GNEXOMNI 4.4.4, N4Stock4.4.4,Moto360 2nd,N7 3G, N5XGZSOP9.0, Mi6 6/64MIUI10 GloDev 9.6.27
    <-- Se ti sono stato utile, ricordati il THANKS
    SAMSUNG S20+5G
    GOOGLE NEXUS 7 TOOLKIT AUTO UPDATE V5.1.0 [8TH MAY 2013] AVAILABLE!!
    mskip May 8, 2013 Google Nexus 7
    Changelog:
    +Split model/build files into much smaller sizes to reduce download time (only files needed for the build you select are downloaded)
    +Added Clockworkmod Root 1.0.1.8 to replace ChainsDD method for better support
    ALL root methods in the Toolkit now include Clockworkmod Superuser method
    +Added TWRP NAND backup/restore procedures to backup/restore section
    +FIXED all NAND backup/restore procedures so locations are detected by recovery
    +Added Sideload another zip file whilst in Recovery to save time [user request]
    +Added Toolkit Hard Reset option in Toolkit Settings screen
    +Added text in driver install screen to test drivers properly
    +Added more stability
    [Auto Updates are only accessible if you have donated to the Toolkit project, received an activation code and unlocked the professional features. Auto Updates are a much faster and easier way of pushing small updates that would otherwise not be worth doing. I can push a single textual change or add support for a new build without having to go through the whole process of building a full version and uploading a large file. IF you are not able to or do not want to donate to unlock the Auto Update feature (and other professional features) then all the smaller updates are collated and a full build made when I have time or if there are enough updates to warrant it. This is the easiest way to make sure all the Toolkits are as up to date as possible. IF you have any views about this please email me at toolkit.support@skipsoft.net about them and do not post in the open thread]
    Toolkit Thread Link: [Google Nexus 7 TOOLKIT V5.0.0] Drivers, Backup, Unlock, Root, Recovery, Flash + MORE - xda-developers
    Mark.
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  4. Il seguente Utente ha ringraziato paolocorpo per il post:
    Robfratt (17-05-13)
  5. #43
    Androidiano L'avatar di Robfratt
    Napoli
    Galaxy nexus, Nexus 4
    ragazzi ho provato e riprovato ma non riesco a far leggere il dispositivo come mtp, ho installato i driver universali, in gestione dispositivi vedo il nexus 7 tra gli sconosciuti ma i driver adb che funzionano perfettamente!! come posso fare??? sto impazzendo! ho disinstallato i driver e riavviato poi ho provato con il debug ma nnte non mi esce più neanche il pop up per l'autorizzazione del pc ! uffff
    nexus 7 32 gb NO 3g
    eppure con il mio nex 4 mai problemi
    NEXUS 4 MAKO!!
    ROM: LOLLIPOP 5.0.1 STOCK
    KERNEL: STOCK + ROOT
    Launcher: Nova launcher prime
  6. #44
    Androidiano VIP L'avatar di lebrac
    LG P990, Nexus 7
    Ringraziato 782 volte in 578 Posts
    Quote Originariamente inviato da Robfratt Visualizza il messaggio
    nexus 7 32 gb NO 3g
    installa usbdeview con il nexus coolegato, apri e disinstalla tutto quello che ha a che fare con asus o nexus 7 (sarebbe meglio anche le voci che hanno a che fare con google ma dato che hai il nexus 4...)
    poi tramite https://www.androidiani.com/forum/go...-versioni.html che è ottimo, installi i driver.
    Alla fine avrai mtp funzionante ( con debug usb attivo)
    GUIDE UTILI:
    - MULTIROM NEXUS 7
    - GUIDA AL WUG'S TOOLKIT
    - GUIDA WIPE/FORMAT
    NON FACCIO SUPPORTO VIA PM, POSTATE NEI THREAD.
  7. Il seguente Utente ha ringraziato lebrac per il post:
    Robfratt (17-05-13)
  8. #45
    Napoli
    Se lascio collegato quando disinstallo l'ultimo drive nexus 7 ritenta di ri installarlo da solo!
    che faccio lo stacco e disinstallo anche quello?
    Cmq anche se attivo il debug sul tablet e poi lo collego al pc, installando i driver, non mi fa apparire quel pop up dove autorizza il mio pc all debugging....bah io non ci sto a capi perchè adesso sta afa le bizze
    p.s con il wugs toolkit nella guida dell'installazione dei driver inizialmente mi fa fare una prima disinstallazione simile a quella che ho fatto con usb deview precedentemente, devo seguirla lo stesso o devo passare allo step successivo?
    Ultima modifica di Robfratt; 17-05-13 alle 17:35
    NEXUS 4 MAKO!!
  9. #46
    LG P990, Nexus 7
    Allora stacca e disinstalla
    Col wugs passa allo step dopo
    GUIDE UTILI:
    - MULTIROM NEXUS 7
    - GUIDA WIPE/FORMAT
  10. Il seguente Utente ha ringraziato lebrac per il post:
    Robfratt (17-05-13)
  11. #47
    Napoli
    P E R F E T T O
    ho appena finito il full driver test, ed è andato tutto correttamente!
    Grazie infinite sei stato gentilissimo !!!!!!
    Non ci dormivo la notte per i mille tentativi sui driver!
    NEXUS 4 MAKO!!
  12. Il seguente Utente ha ringraziato Robfratt per il post:
    lebrac (17-05-13)
