Utente della settimana: megthebest con ben 14 Thanks ricevuti negli ultimi sette giorni
[ROM][LP][5.1.1] CleanROM 6.0 [NEXUS 7 2013]
    Senior Droid L'avatar di Albe89
    Localitą
    Lucca
    Note 4 / Nexus 7 2013
    Ringraziato 56 volte in 52 Posts
    • CleanROM is designed with a purpose in mind; Be Fast, Be Smooth, Be Stable, Be CLEAN!
    • CleanROM is based on the latest Google Stock Lollipop 5.1.1 ROM Base!
    • CleanROM uses the powerful Aroma Installer!
    • CleanROM is powered by SuperSU by Chainfire
    • CleanROM is targeted at the user that wants a stock ROM experience but demand higher performance and expect stability!
    • Utilizes Aroma Installer with the following options:
      • Launcher: Nova Launcher, Stock Launcher
      • Google Apps: Gmail, YouTube, Hangouts, Maps, PlusOne and Photos, Movies and TV, Music
      • Misc Apps: ES File Explorer, Ad Away, Reboot Manager, AOSP Gallery, AOSP Music
    • FS TRIM on install and reboot
    • init.d support
    • Minor file system performance enhancements
    • Undeniable stability and performance!
    Version 6.0.0 - 5/3/2015
    • Rebuild: Complete Rebuild on Lollipop 5.1.1 / LMY47V!
    • Changed: Changed file structure to place google Apps in the /data partition. Easier to update and remove if desired.
    Download: Download Here!
    Considerazioni :Utilizzo questa rom da molte settimane, molto fluida! Nessun lag! La consiglio a tutti
    thanks to scrosler from XDA
    Immagini allegate
    Device: Samsung S7 Edge / Nexus 7 2013
    Rom: Stock / Stock
    Kernel: Stock / Stock
    Localitą
    Lucca
    update in arrivo!
    Rom: Stock / Stock
