Utente del giorno: Varioflex con ben 2 Thanks ricevuti nelle ultime 24 ore
Wipe battery non servirebbe a una mazza??
    Jan 2011
    Galaxy S - Nexus S
    Today's myth debunking:
    "The battery indicator in the status/notification bar is a reflection of the batterystats.bin file in the data/system/ directory."
    No, it does not.
    This file is used to maintain, across reboots, low-level data about the kinds of operations the device and your apps are doing between battery changes. That is, it is solely used to compute the blame for battery usage shown in the "Battery Use" UI in settings.
    That is, it has deeply significant things like "app X held a wake lock for 2 minutes" and "the screen was on at 60% brightness for 10 minutes."
    It has no impact on the current battery level shown to you.
    It has no impact on your battery life.
    Deleting it is not going to do anything to make your more device more fantastic and wonderful... well, unless you have some deep hatred for seeing anything shown in the battery usage UI. And anyway, it is reset every time you unplug from power with a relatively full charge (thus why the battery usage UI data resets at that point), so this would be a much easier way to make it go away.
    è Dianne Hackborn ingegnere di google a dirlo....
    fonte: https://plus.google.com/u/0/10505198...ts/FV3LVtdVxPT
    che ne dite?
    -Android*
    no non serve a nulla.
    Jan 2011
    Galaxy S - Nexus S
    Quote Originariamente inviato da -Android* Visualizza il messaggio
    che cavolo è un anno che faccio wipe battery stats o calibrazioni varie, non me ce lo potevi dire prima???
    Jan 2011
    Ringraziato 155 volte in 115 Posts
    Quote Originariamente inviato da holden27 Visualizza il messaggio
    non serve a ricalibrare la batteria...ma se cambiando rom, la nuova rom accede a quel file e trova roba strana la interpreta male poi nelle statistiche batteria: è quello il motivo per cui si wippa
    Senior Droid L'avatar di shevuzzo
    Trapani
    galaxy GT-I9505 S4
    beh io posso dire che avendo messo rom aosp con faceunlock son passato dal 95% al 4% in 5 ore..il che era anomalo e la batteria era calda..ho fatto il wipe battery e il consumo è tornato normale forse meglio della rom stock..quindi come è possibile che non servirebbe farlo?
