esistono alri codici da inserire tramite tastierino numerico sul nexus s tipo questo *#*#4636#*#*??
se si me li potete postare ?
grazie mille
EDIT: codici trovatii
ma sembra che nn a tutti funzionino provateli
*#*#3282#*#* Data Programming(Data Profile, DDTM, Roaming Orig. Vocoder, EVRC-B, Home SID, USB Charging, RTSP/HTTPPD ports & addresses, Browser Gateway, MMSC URL)
*#*#33284#*#* Debug Menu(1x/EVDO Engineering, , Data Status,Debug Screen, Test Calls, RC Data, HDR/1x Selection, Voice Privacy, DTMF Set, Korea Mode Set)
*#*#786#*#* Hard Reset(Wipes/Resets Data/Profile & internal storage!)
*#*#(your msl)#*#* Service Menu(Phone Number Change)
*#*#8778#*#* Phone Utility(UART/USB Modem & PDA Selection)
*#*#4772579#*#* GPS clear(reset)
*#*#4636#*#* Testing menu(Phone, Battery & Wifi Info, Usage Statistics)
*#*#8255#*#* Gtalk Monitoring(Monitor Gtalk Activity)
*#06# MEID number(Display's your IMEI)
*228 Phone activation(Activate your phone)
*#*#2432546#*#* Checkin(Manually check for System Updates)
*#*#72786#*#* SCRTN(Factory default value for DSA selection)
Keywords: dialer codes, hidden codes, epst codes
