Device : OP11 Grey - 16/256 | Rom : OOS 14 BA | Audio Mod : Dolby Atmos + ViperFX RE | Kernel: Stock | Recovery : Stock
NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
****RISPETTA IL REGOLAMENTO DEL FORUM****
kaos80 (09-06-16)
Viper10 1.5.0 (12th June)
Additions & Updates
- (Fullrom only) Aroma option for SuperSU compatible mode fixed
- (Fullrom only) Aroma option to use decrypted data (needs format data before) - Thx @squid2 for the cleaner solution
- Fade out Page Indicator on Homescreen
- Hide vzw connected wifi notifcation
- Added "Always/Just Once" Option to native USB Configuration Dialog
- Show External SD-Card in Infoline
- SEPolicy Enforce option
- Changing navbar styles work on the fly without rebooting
- Venom and Stock Navbar
- Custom Navigationbar height on the fly
- Auto Hide Navbar after a specified time
- VenomNavbar Background colors
- VenomNavbar Activation area colors
- VenomNavbar Custom Activation area size
- VenomNavbar Activation Type (Touch or Swipe)
- Touch anywhere to hide
- Press Key to Hide
- Longpress Key to Hie- Extended Navbar - add different panels to your navbar, swipe left/right to switch
- Available panels: Music controls, quicksettings, quicklaunch, extended buttons, brightness slider
- Infinite swiping
- Swipe and animation direction
- Swipe distance
- Setup Extended buttons, quicklaunch and quicksettings
Fixes & Cleanups
- Fixed longpress Home/Recent Screen Off action causing next single press to work just on 2nd press
- Fixed Theme Info dialog causing out of memory errors for some icon packs
- Fixed Customize Statusbar per app colors
- Fixed RAM Info line not matching recent apps ram info
Update is available via OTA System as usual (Settings->About->Software Update or VenomTweaks->Advanced->OTA Update
Fullroms will be posted later.
Enjoy everyone
Ultima modifica di sirioo; 12-06-16 alle 19:53
kaos80 (12-06-16)
Mi tocca un istallazione pulita!! Noooooooooo!
Inviato dal mio HTC 10 usando Androidiani App
devo far chiarezza su questi 2 punti
Ora ho scaricato l ota! Quando ho tempo farò un reset completo!
se vuoi queste 2 opzioni si
te le consiglio , decriptare vuol dire anche prestazioni migliori
Qualcuno di voi ha provato dal passaggio da m9 a htc 10 di importare i profili della viper 4.3.0 nella nuova 1.5.0 ?
come da guida il consiglio che vi do' quando cambiate rom ma specialmente da stock a custom fate sempre un fullwipe in questo modo
Full wipe
Andare in Wipe , Selezionare Adavanced Wipe : Fleggare System,Data , swipe verso destra per avviare il wipe .
Tornare nella schermata principale del Wipe e selezionare factory reset
Ora da quello che vedo da aroma nelle rom custom ce l'opportunità di fare il wipe della partizione data per decriptarlo ed il factory reset dovrebbe essere superfluo , cmq farlo non fa male
