[ROM] ICE - EYE | Sense 8 Android M | Tweaks
    Androidiano VIP L'avatar di fabriziobonanno69
    CATANIA
    HTC DESIRE EYE MATTER BLUE
    Ringraziato 80 volte in 71 Posts
    Lightbulb
    ROM ANDROID INSERT COIN ICE - EYE ICE - EYE 2.0.0 MARSHMALLOW CON SENSE 8 PORTING DEL NUOVO MODELLO HTC 10
    ROM INFO:
    latest HTC NEW ONE (M8) Sense 7 Base & Android 6.0.1 WWE Base - 6.12.401.4
    more languages enabled (FULL WWE)
    root, busybox and init.d support
    persistent ADB enabled
    ramdisk improvements
    battery life, performance and memory improvements
    sysro / sysrw binaries
    openvpn / sqlite support
    disabled logging & removed bloatware
    stripped debugging info for improved performance
    optimized with latest sdk for improved performance
    trimmed partitions for improved performance
    zipaligned apps for improved performance
    flar2's Write Protection MOD to allow S-ON users fully writeable /system partition
    advanced power menu
    Sense Launcher Menu Support
    Fast fixes / updates
    Sweep2Sleep props @flar2 - if you wanna disable it just remove /system/etc/init.d/40s2w
    [B]
    InsertCoin Configurator
    AROMA Options:
    optional Exchange Email Hack (disable EAS Pin Requirement)
    Center Clock in Status Bar Mod
    Enable Disable Boot Audio
    AOSP NavBar Buttons
    Awesome NavBar Buttons
    Selection of A9 or HTC 10 Camera Apps ( Slow Motion & Hyperlapse Enabled )
    THREAD ROM INSERT COIN XDA: [ROM] ICE - EYE 2.0.0 | Sense 8 Android M | … | HTC Desire Eye
    THREAD KERNEL RELOADED: [KERNEL][AROMA][MM] Minis ReLoAdEd Kernel v1… | HTC Desire Eye
    THREAD HTC DESIRE EYE XDA: HTC Desire Eye
    INSERT COIN WEB SITE DOWNLOAD: HTC Desire EYE - InsertCoin - Android Custom Roms
    ISTRUZIONI:
    -Si consiglia vivamente,prima di compiere queste operazioni, di fare un backup dei dati o della rom
    -Scaricare e copiare la rom e il kernel reloaded 1.0.1 nella memoria esterna
    -Riavvia in recovery
    -Full wipe della memoria
    -Flashare la rom e dopo il kernel
    -Riavviare ( il primo avvio è sempre più lungo perchè bisogna attende l'ottimizzazione di android)
    -Finito
