[ROM] [JB] Andromadus Test builds - Jelly Bean - CyanogenMod 10
    E' ancora una rom in fase beta, ma ne parlano già bene. A quanto pare stanno per portare sul nostro vetusto cell addirittura Jelly Bean!!
    So you may be asking what this is since we already have an Andromadus thread.
    To start with it's going to be test versions of Andromadus, think of them along the same concept as nightly builds just not every night
    These are not intended for standard end users, if you want to run bleeding edge development ROM's and at least know how to use adb and logcat then you might find something of interest here.
    1. New versions will be added as and when I feel there are enough changes to warrant one, don’t ask when the next version is coming.
    2. Stable releases will still be published in the main Andromadus thread, nothing has changed in that sense.
    Direct all your queries with release versions to that thread and in the same vain do not discuss these releases anywhere but here.
    3. I will offer very little/bordering on no support as my time is precious to me and I would rather spend what I do have on working on the ROM rather than supporting test builds, all uploads will at least have been flashed by somebody before hand but you use them at your own risk.
    4. Don't ask for what's changed since the previous version, have a look at the recent submits on the Andromadus github if you want to know.
    5. If there is something in particular to test it'll be mentioned
    6. As always if you didn't wipe between installations then at least verify that the problem exists on a clean install before posting here. Nandroid/superwipe/install/check at the end of the day you can always restore your nandroid if the problem is reproducible on a clean installation. If you can't be bothered to try this then I really can't be bothered to try to help you :>
    7. All that said ensure you make a nandroid/backup before hand. I take no responsibility for what you do to your phone with these ROM.
    8. PLEASE DO NOT USE THESE RELEASES AS A BASE FOR ANY ROM/MOD/ETC.
    9. These will be test version's! Tell us what works/what's worse/what's better but don't bitch when something breaks or isn't fixed yet, report it and move on.
    10. Sometimes people forget that we do this for fun, for ourselves, without payment and that sometimes your super important issue is way down on our personal list of things to be fixed.
    If you ignore any of the above you will in turn be ignored.
    Now that's all out of the way as always have fun
    As usual you need to flash the ROM then GAPPS.
    Checkout Andromadus for links/files/changelog's
    GAPPS - Goo.im Downloads - Downloading gapps-jb-20121011-signed.zip
    Known Issues :-
    1: - Occasionally the panoramic preview in Camera will glitch, switching back to camera then panorama again usually fixes it.
    2: - Sometimes when the phone is rebooted all volumes are "muted" until you change a volume level even though they look like they are fine. Any help with this one would be appreciated. Even a way of reproducing the fault every time would help
  2. Il seguente Utente ha ringraziato robypiro per il post:
    iLuke (17-11-12)
    Administrator L'avatar di iLuke
    Jan 2011
    Ringraziato 5,314 volte in 3,364 Posts
    L'ho installata, tenuta tutta la giornata di oggi, non è male gli sviluppatori stanno facendo un ottimo lavoro.
    Vedere jelly bean sul nostro cell fa uno strano effetto ho installato anche le app di android 4.2 funzianano tutte tranne la photosphere purtroppo.
    Però nonostante giri fluidamente a volte si impunta e questo mi da molto fastidio, non penso che è già pronta per essere usata quotidianamente attendiamo sviluppi
    Inviato dal mio HTC Vision con Tapatalk 2
    :::::::::::: REGOLAMENTO DEL FORUM | FAQs | TAG BBCode ::::::::::::
    Ringraziato 29 volte in 28 Posts
    Per quanto mi riguarda funziona benissimo.
    La uso quotidianamente e non ho particolari imputamenti.
  6. #4
    Zof
    Zof non è in linea
    Androidiani Power User L'avatar di Zof
    Parma
    One Plus 3
    Ringraziato 891 volte in 595 Posts
    La sto provando ora, molto fluida e funzionale credo che la terrò per un po e poi adoro google now /)
    Senior Editor @ Androidiani.com -> Stefano
    Follow me on Twitter-> Stefano
    Follow me on Instagram-> Stefano
    Follow me on Spotify-> Stefano
  7. #5
    Avete provato qualche dispostivo bluetooth? Mi piacerebbe provare questa rom, ma necessito di un bluetooth perfetto
  8. #6
    No, io al momento non ho provato dispositivi bluetooth. Magari sul thread ufficiale di xda qualcuno ne parla....
  9. #7
    Jan 2011
    Uscita una prima versione di Android 4.2
    Quote Originariamente inviato da http://www.flinny.org/
    THESE ARE NOT DAILY DRIVERS YET!
    MAKE SURE TO DO A NANDROID BACKUP
    FULL WIPE
    INSTALL ROM
    PLAY
    RESTORE BACKUP
    What's working
    Wifi,
    Sound,
    Phone,
    Text,
    USB mounting,
    Data (once you enter an APN as I've not included any APN lists),
    Headphones,
    Bluetooth (I can't get it to pair my headset but others have.. so give it a try...it might be that it's working on saga but broken on vision...)
    Not working
    Web pages/anything using webkit get's corrupted (tile rendering/cpu upload crap again need to merge a load of framework patches for this)
    Signal Strength bar doesn't work.
    Video playback etc is all software at the moment.
    Tethering seems to broken/slightly iffy...
    Camera... applied many patches it looks like it's going to start then doesn't, may be missing something I'll investigate
    As you can see much still to fix but I think you'll agree not bad for a first release.
    Links
    HTC Vision / Desire Z
    http://flinny.iskrembilen.com/flinny..._vision_01.zip
    MD5 9f829537f715b8a00ecc69b1a532fecd
    GAPPS 4.2
    http://flinny.iskrembilen.com/gapps-...40C-121116.zip
    MD5 598a152b4b7044b7bf07e86b47d7fd65
    Fonte
    Senior Droid L'avatar di JackTheJoker
    Cervia
    S7 edge
    Chiedo scusa; nel caso uscissero aggiornamenti della rom, si potrebbe aggiornare direttamente dal telefono, o bisognerebbe riflashare?
    Inviato dal mio HTC Desire Z usando Androidiani App
  11. #9
    Jan 2011
    Il team Andromadus non prevede ancora aggiornamenti OTA..
    Comunque il thread nuovo per questa rom è questo: LINK. Se guardi, il post sopra al tuo risale all'anno scorso.
