sampi81
aprendo fastboot col telefono collegato al pc mi da queste info:
PL/hboot version: failed.
Radio version: failed.
Main software version: failed.
cid: failed.
cpld: failed.
getvar
roduct failed (command write failed (unknown error)).
getvar:mid failed (command write failed (unknown error)).
getvar:security failed (status malformed (1 bytes)).
getvar:build-mode failed (command write failed (unknown error)).
Print of device info SUCCESSFUL.
This device does not have s-off nor eng hboot.
ARE YOU SURE THAT THIS IS THE RIGHT TOOL FOR YOU?.
intendo dire fastboot commander
non ho ancora fatto nulla...che faccio proseguo?
