E' uscita la v15
Blind ROMs: ROM | OCT 27 | PACman v15.0 | Android 4.1.2 | Kernel 3
E' uscita la v15
HTC DESIRE HD (cam Samsung)
Rom: ViperDHD 1.2.3 - Sense 4.1 full
Radio: 26.09.04.11_M2
Recovery: 4EXT Touch v1.0.0.5
Changelog :
PACman v15.0 alpha 27/10/2012
(>) Syncd to CM as of 26 Oct
(>) AOKP JB Build 5
(>) PA 2.23
(>) Fix Phablet statusbar gap
(>) Fix Tab UI systembar height
(>) Removed CM10 Weather
(>) Wifi Hotspot Fixed
(>) Possible fix of wifi random disconnect
(>) Possible fix of Data over 3G, Now it works pretty well
(>) Audio fixes
(>) init.d script
- For enable / disable S2W in Saga - Thanks nk111
- zRam - nor sure if it works
(>) Activated screen off animation, was disabled by default
(>) Speaker issue fixed (Confirmed on Saga)
(>) Video Recording Fix added from previous version
(>) Updated egl and hw files
(>) More bug fixes
(>) Kernel
FOR SAGA :
- BlindHawk v1.2 (Thanks Andromadus Team and amidabuddha)
- Patched to 3.0.48
- OC upto 1.8Ghz
- Added V(R) Scheduler
- Default SIO Scheduler
- Added Lagfree Governor
- Added Savagedzen Governor
- Added Lazy Governor
- Default SmartassV2 Governor
More Changes merged from Andromadus Repo till date
FOR ACE/I4G :
- Jellytime R23 Kernel (Thanks Randomblame)
- Patched to 3.0.48
- Various audio/video bug fixes in kernel
- More misc changes
WHAT YOU NEED TO DO AFTER BOOT :
(>) Disable HW Overlays
- It will prevent random reboots using camera, playing video , watching video over youtube
- Graphic glitches (Haven't experienced)
(>) Auto Brightness
- If you choose auto brigtness ,it wont work instantly
Fix : try locking and then unlocking screen it will work
(>) BootAnimation
- If you choose to use a custom bootanimation you need to set it from RomControl as by default its disabled
(>) PowerWidget
- On start up there will be two type of powerwidgets, disable one of them either from ROM Control or System -> Notification Drawer -> Power Widget
KNOWN BUGS :
(o) Front Camera (Saga) , I have compiled the kernel with fix for FFC but I wont release unless Andromadus releases it first. I dont want to piss on their hard work .
(o) Panaroma
(o) More you tell me except above
Ecco il change log.
Ma nessuno la sta provando?
Se se stanco delle solite trollate e vuoi fare davvero sul serio, vieni con noi nel MVR: MANICOMIO VANILLA ROOTBOX.http://www.androidiani.com/forum/off...l-delirio.html.
milza (29-10-12)
Buongiorno a tutti!
Qualcuno sa dirmi se gli mms funzionano?
Inviato dal mio HTC Desire HD usando Androidiani App
L'avevo dimenticata^^
Aggiornata la discussione, aggiunti link al download, aggiunto changelog...
Potrebbe anche uscire, ma non ho capito quando però, la versione basata su PA 3 e quindi con il celebre "pie", speriamo
Aggiornata alla versione: PAC-man v20.0.0 25/02/2013
con PA 3 e quindi credo il celebre "pie"...
Android 4.2.2...
Aroma installer...
Aggiornata alla versione --> PACman v20.0.1 del 26/02/2013
Risolto il bug della fotocamera...
Non è più necessario installare le ParanoidPreferences.
E' necessario installare le gApp considerando che non sono più incluse^^
Buongiorno ragazzi volevo chiedervi una cosa,come è questa rom con la 4.2.2?funziona tutto? cè qualcuno che l'ha provata per qualche giorno e può dare un giudizio a 360 gradi? gps etc..? Grazie a tutti buonagiornata
Mi riservo di provarla meglio, l'ho flashata ieri sera tardi e non ho avuto modo di provarla a fondo per giorni ma...
...ma da una prima prova veloce posso tranquillamente dire che è ottima
meglio della aokp che ho tenuto su una settimana...
Funziona il gps, tranquillamente ha fatto il fix all'esterno in pochi minuti...
Funziona il tethering wi-fi...
Non ho testato il BT perché non ho dispositivi da accoppiare, tipo auricolari, e neanche altri con cui scambiare file...
Per il resto è incredibile, molto fluida, rimane molta ram libera, iperpersonalizzabile...
La mia prima recensione era un po' negativa ma adesso devo ricredermi...
Certo resta sia il menu' prestazioni (CM10) che il performance control (AOKP) ma và, si vive lo stesso :P
Le personalizzazioni Paranoid sono bellissime e si sposano bene con il nostro DHD, ho impostato la phablet UI e mi piace^^
A giorni magari aggiorno queste prime impressioni
Ma intanto un giro ci vale di certo
Scusate ma la rotazione dello schermo non funziona mi pare o no?? però sulla presentazione c'è "-Rotation Fixed" cosa vuol dire??
grazie Alberto
A me funziona, parliamo di rotazione della home...
Abilito la rotazione dalle impostazioni e poi anche dalle impostazioni del launcher (nel mio caso Apex) e rotea tutto :P
Potrebbe esserci il "solito" bug della rotazione dello schermo che si aggiusta flashando una RUU
Ho messo nel primo post il link alla solita procedura da seguire in caso non funzioni
Alcuni lamentano questo bug, altri no.
ciaociao
mazzocc (04-03-13)
