famonaco
CleanDHD - A Clean Cyanogenmod experience
Introduction
Based on the latest CM7 release by the Cyanogenmod team, i present a barebones Gingerbread +Cyanogenmod ROM for the Desire HD.
Always built from the latest releases and always kept up to date, this rom is for those who like ultimate control over their device with no chaff filling the app drawer.
All removed applications are easily available from download, from the market, for free, giving you ultimate control over what programs reside over your phone!
Features
- Based on CM7 nightly build 23
- Mad Murdocks v9 kernel patch for battery fix
- Latest market and google frameworks
- All wallpapers removed except for one supplied (standard APKs attached to this post)
- Performance enhancements to system
- Battery efficient
- Very fast
- Stock looking
- 190dpi for the true HD look
- Kernel OC support up to 1516 MHz
Download
Download the CWM install ZIP here :
Download CleanDHD_CM_GB-v1.00.zip from Sendspace.com - send big files the easy way
Installation
Perform a nandroid backup in clockwork before you install, should you wish to defer back to your old rom. Install the usual way through clockwork recovery, v3.0.0.6 recommended. Full Wipe (Boot, System, Data, Cache) required if coming from another rom!
Radio Requirements
Version 26.08.03.07_M, available in this thread is recommended for this rom
~~~AFTER INSTALLATION~~
Please follow the instructions below after you install and boot the rom for the first time to aviod problems.
First install bootup, the PIN entry screen and lockscreen will not display correctly, due to the 190dpi. This will automatically correct after the 1st reboot and is of no concern.
- Enter PIN, finish configuration wizard
- DO NOT ENABLE WiFi
- Menu > Cyanogenmod Settings > Display > Automatic Backlight > Enable "Allow Light decrease"
- Reboot
- YOU CAN NOW ENABLE WiFi and configure
- Menu > Wireless & Networks > WiFi Settings > (press menu) Advanced > WiFi Sleep Policy > Set to "Never"
You are now free to configure your phone as you wish
ragazzi provatela mi e' piaciuta molto
