beh non ci vuole molto, basta scarichi setcpu (che puoi avere gratis registrandoti su xda) e lo imposti magari a 1400 (per non esagerare) e vedi come va. però magari lo tieni giusto per prova qualche minuto, poi rimetti a 1000
SyM989 (04-04-11)
Kernel update DOWNLOAD
Decided to update only the kernel... because ROM is basicaly CM7 nightly...
I'll include kernel update.zip with and without SD Card Read speed increase patch!
KERNEL (for CM7 only):
Teamdesire's 2.6.32.28
Battery drain fix included - by teamdesire (allready implemented in CM7)
SMARTASS governor added and tweaked
CPU freq table totaly rewriten with lower voltages
OC up to 1958 MHz – DON'T GO OVER 1800MHz EXCEPT FOR SHOWOFF AT THE BAR I AM IN NO WAY RESPONSABLE FOR DHD SMOKING!!!
Volume boost 20%
SLQB slab allocator added
Allocated more memory to GPU
Corposo update kernel per questa particolare rom
10-04-2011 V3.0 LorDmod kernel
Kernel taken from different source with better primary patches (from Kali-)
Now has new Adreno 205 drivers included like kernel from nightlies (fast as hell)
Remodded from the beginning so it can be set up on my git
Patched to version 2.6.32.36 so you all stop bugging me
KERNEL V3.0
