[ROM][02/23/12] Virtuous Inquisition v3.5.0 :: AOSP-Experience Senseless ICS (4.0.3)
    Ringraziato 86 volte in 58 Posts
    Per chi volesse provare una rom ICS senza sense, ecco la VIRTUOUS!
    "Virtuous Inquisition is a an ICS (4.0.3) Senseless ROM, meaning essentially all Sense components have been removed in favor of their AOSP counterparts. Everything except the camera app has been replaced. Any work, such as mods or fixes, you would like to contribute would be gladly accepted. The project has one goal, to provide a ROM which is as close-to-AOSP-ICS as possible.
    Based off the HTC 3.24.401.1 TEST RUU.
    Sense has effectively been removed. Some components may be coming back (such as the camera and music player), as they are better than their AOSP counterparts. I'll provide an option for purists who want AOSP-only-no-matter-what."
    • Remaining HTC framework beautifully themed to match ICS by shnizlon.
    • MDJ-SENSE-ICS kernel. 1512MHz
    • Pre-rooted with the latest version of Superuser and modified ramdisk to allow adb remount, mock locations, etc.
    • IO optimizations including the use of ext4 with writeback journaling for all mounts and larger read-ahead buffer for improved sdcard performance.
    • Automated battery calibration. Just plug your phone in after a wipe and charge it to full (preferably overnight), then let our script do the rest.
    • Over the air updates via ROM Manager.
    BUGS NOTI:
    - Camera
    - Mass storage
    Download v. 3.5.0
    link xda: [ROM][02/23/12] Virtuous Inquisition v3.5.0 :: AOSP-Experience Senseless ICS (4.0.3) - xda-developers
    SE TI SONO STATO D'AIUTO........THANKS PLEASE
    _______________________________________________
    SAMSUNG GALAXY S6
  2. Il seguente Utente ha ringraziato peroni86 per il post:
    Guildamx (23-02-12)
    Woo !! Ma non vedo il 3D nei bugs... Vuol dire che nella galleria funziona ??
  5. #3
    Quote Originariamente inviato da lo_stewie Visualizza il messaggio
    non saprei...secondo me, essendo un porting del sensation,no...
    SAMSUNG GALAXY S6
  6. #4
    Okok niente 3D, ma la fotocamera anteriore funziona
  7. #5
    qualcuno la ha provata? mi potrebbe far sapere com'è cosi la flasho pure io
  8. #6
    Quindi anche quella posteriore..giusto? Come va la rom?
    SAMSUNG GALAXY S6
  9. #7
    ho trovato un'altro bug! se dal menu a tendina (quello che si tira giu) accendete, spegnete e riaccendete di nuovo la torcia il telefono si riavvia
