Utente del giorno: diavolo78 con ben 24 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: bluflight13 con ben 287 Thanks ricevuti negli ultimi sette giorni
Utente del mese: diavolo78 con ben 1154 Thanks ricevuti nell'ultimo mese
[ROM][JB][AOKP] NIK Jelly Bean Evolution by Nikhil Dhayatkar
    Senior Droid L'avatar di bottosac
    Ferrara
    Thanks
    42
    La prima Jelly Bean per Incredible S
    E' una AOKP quindi senza la sense di HTC
    Features :
    - Android 4.1.1
    - CM10 Kernel
    - Superuser & Busybox preinstalled
    - Deodexed
    - Built in performance/init.d configuration
    - Advance Power Menu
    - Brightness Slider On Status Bar - Yes Its In There
    - Quiet hours
    - AOKP Wallpapers
    - Mute Camera Sounds
    - AOKP Statistics
    - Battery Bar
    - Expandable Volume Panel
    - LED Options
    - Clock Location: Right, Center, Disable
    - Battery Icon: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None
    - Toggles: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness
    - More .. See Yourself
    Bugs :
    - Tethering FC's (Try Barnacle wifi tether from playstore * it works )
    - Camera - Front Only Force Closes ( If you try and are not able to revert back follow these steps )
    1.Go to Settings
    2.Go to Apps
    3.Search for System Apps
    4.Go to Gallery
    5.Clear data
    -Video Recorder
    -FC on Launcher after switching a few times from portrait to landscape and back. ( Happens Sometimes )
    Video playback issues try turn off HW overlay
    Flashing Instructions :
    1.Enter recovery
    2.Wipe data/factory reset
    3.Wipe cache / dalvik cache
    4.format system
    5.Install zip from sd card and choose my rom
    Link Download
    Ultime gapps da installare
    Se ti sono stato utile schiaccia il pulsante Thanks qui sotto
    Ferrara
    Thanks
    42
    Ho avuto modo di provarla solo ieri sera. E' veramente ottima, fluida, unico bug rilevato la telecamera frontale.
    Ci sono alcuni tweak ma se volete customizzare ulteriormente potete provare la CodeName sempre JellyBean [3rd Sep][JB 4.1.1] Codename Android ViVo Nightly By Nikhil007 a.k.a Nikhil Dhayatkar - xda-developers
    Incredible S
    Thanks
    7
    Ciao, io volevo chiederti se puoi spiegarmi le differenze tra le 3 nuove rom jelly Bean di nik... Grazie
    Inviato dal mio HTC Incredible S usando Androidiani App
    Ferrara
    Thanks
    42
    Diciamo che la CodeName e la Evolution partono da una base JB AOKP molto simile. Tutte e due hanno il kernel Cyanogen 10. La CodeName ha molte possibilità di tweak mentre la Evolution solo alcune molto basilari. C'è chi preferisce la CodeName per le possibilità di custom altri che preferiscono la Evolution perchè più stabile. Io per ora ho provato solo la Evolution.
    La terza è la ParanoidAndroid ma non ho ancora avuto modo di guardarla
    Thanks
    11
    Con la codename aggiornata da poco mi trovo bene ad eccezione di qualche piccolo bug ma che non pregiudicano il mio usuale utilizzo! Jelly bean permette di rispondere ai messaggi direttamente dalle notifiche e per chi come me scrive tanti SMS e molto comodo e veloce
    Inviato dal mio Incredible S usando Androidiani App
    Ferrara
    Thanks
    42
    Hanno aggiornato la codename rispetto alla versione del 13 settembre?
    Thanks
    11
    Si ho quella del 13 settembre
  • Non puoi inserire repliche
