Utente del giorno: carotix con ben 5 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: carotix con ben 17 Thanks ricevuti negli ultimi sette giorni
Utente del mese: Varioflex con ben 58 Thanks ricevuti nell'ultimo mese
Pagina 2 di 13 primaprima 123412 ... ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 126
[ROM] ViperOneM9 6.1.0 • 4.28.401.3 | Tweaks | HUB | Sidebar | Theming | OTA
  1. #11
    HTC DESIRE/ONEX/M7/8/9/10
    Ringraziato 448 volte in 266 Posts
    ViperOneM9 1.7.0 (16th May)
    Additions & Updates
    • Added custom Appdrawer Background image
    • Added custom Appdrawer Color - you will be able to set any transparency too ofc
    • Added custom lockscreen statusbar color
    • Added custom homescreen statusbar color (perfect for people with white/light background)
    • Added 5x5 Folders
    • Added Infinitive Folders
    • Completely rewrite of navbar/statusbar theming behavior
      - works on all apps now that are using the Android Actionbar
      - no overlapping issues.
      - color of navbar even changes when you navigate the different categories in google play and youtube
      - intelligent behavior:
      - apps that use a light colored action bar, like chrome, won't be applied as navbar background,
      since white navigatiobar buttons won't look well on gray background
    • Updated all /system and /data apps (Full ROM only)
    Fixes:
    • Fixed Custom Appdrawer Shortcut
    • Fixed Custom Appdrawer Image
    • Fixed longpress back firing another back event
    • Fixed Horizontal Quicksettings Indicators not taking theme color
    • Fixed disabling pulldown on lockscreen
    • Fixed volume keys music control
    • Fixed Bugreport Full-Log option
    • Fixed issue with not being able to install apps in playstore
    • Fixed kcal for Sprint and Verizon
    Previews:
    Custom Statusbar Color on Homescreen:
    Always wanted to use a white background?
    ..but it would look like on the left picture where you can't see your statusbar icons anymore?
    We got the solution: Custom statusbar color on Homescreen
    Navbar matching theme color:
    Match the color of your navbar with the current theme color of your actionbar.
    It will work on all apps implementing the KK/L Actionbar. On 1.7.0 it will even dynamically change when you navigate through categories in google play or youtube.
    Custom color in appdrawer:
    Bored of the opaque color in your appdrawer? Add some transparency!
  2. I seguenti 2 Utenti hanno ringraziato carminuccio per il post:
    iLuke (17-05-15),kaos80 (17-05-15)
    1.7.0 is available via OTA. Grab it by going to Settings->About->Software Update.
    For people not having that Option. Flash the OTA Workaround from the HUB and read the instructions there,
    Fullroms as usual downloadable on:
    (You might need to ctrl+f5 to clear the cache to see the new links)
    For people having issues with the links not showing:
    Incremantal OTA:
    ViperOneM9 1.6.0-1.7.0
    Fullroms:
    Main: AFH
    Mirror 1: US Sense Host
  5. #13
    Moderatore L'avatar di sirioo
    Naples
    Oneplus 7 8/256
    Ringraziato 1,261 volte in 1,043 Posts
    ViperOneM9 1.9.0 (22May)
    Updates
    • Updated and ported all mods to new HTC Sense Home
    • Updated Google Play Services
    • Updated HTC Mail
    • Updated HTC Keyboard
    • Updated HTC Zoe
    1.9.0 is available via OTA. Grab it by going to Settings->About->Software Update.
    For people not having that Option, go to VenomTweaks->Advanced: OTA Update
    Incremantal OTA:
    ViperOneM9 1.8.0-1.9.0
    Fullroms:
    ViperOneM9 1.9.0
    Mirror 2 NL/EU
    Mirror 3 NL/EU
    Mirror 4 NL/EU
    Device : OP7 Grey GM1903 - 8/256 | Rom : Oos 10.0.5 GM57BA + xXx + Renovate ICE | Kernel: Weeb | Recovery : Twrp 3.3.1.79
    NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
    ****RISPETTA IL REGOLAMENTO DEL FORUM****
  6. I seguenti 2 Utenti hanno ringraziato sirioo per il post:
    iLuke (23-05-15),kaos80 (23-05-15)
  7. #14
    Naples
    Oneplus 7 8/256
    ViperOneM9 1.9.1 (24May)
    Updates & Fixes
    • Updated Google Play Services and fixed all issues related to it
      - Not opening Play Games connected apps
      - Syncing issues
      - Wakelocks / Battery drain
    1.9.1 is available via OTA. Grab it by going to Settings->About->Software Update.
    Incremantal OTA:
    ViperOneM9 1.9.0-1.9.1
    Fullroms:
    ViperOneM9 1.9.1
    * More mirrors will come later on to venomroms.com/htc-one-m9
  8. Il seguente Utente ha ringraziato sirioo per il post:
    kaos80 (25-05-15)
  9. #15
    Senior Droid L'avatar di kaos80
    Ringraziato 65 volte in 51 Posts
    Ragazzi ma mi tocca mettere su il nuovo firmware 1.40.401.5?
  10. #16
    Naples
    Oneplus 7 8/256
    Quote Originariamente inviato da kaos80 Visualizza il messaggio
    oggi uscirà la nuova versione con base 1.40.401.5,devi aggiornare il firmware e poi full wipe e nuova rom
  11. Il seguente Utente ha ringraziato sirioo per il post:
    kaos80 (30-05-15)
  12. #17
    Ok grazie!!
  13. #18
    Administrator L'avatar di iLuke
    Jan 2011
    Ringraziato 5,193 volte in 3,297 Posts
    ViperOneM9 2.0.0 (31st May)
    Additions & Updates
    • Updated International base to 1.40.401.5
    • Added Extended Navbar
      - Toggle Music controls view
      - Toogle Quicksettings view
      - Infinitive swiping
      - Landscape horizontal swipe
      - Portrait vertical swipe
      - Minimum Swipe Distance
      - Customize Quicksettings
      [YOUTUBE]74IZEvR6xw8[/YOUTUBE]
    • Removed flaslight restriction causing not being able to use flashlight below 15% battery
    Fixes & Cleanups
    • Fixed volumebutton music controls not working good on 3rd party players (e.g. Google Play Music)
    • Some cleanups regarding navbar and statusbar theming
    • Fixed Sprint NFC Icon not hiding
    :::::::::::: REGOLAMENTO DEL FORUM | FAQs | TAG BBCode ::::::::::::
  14. Il seguente Utente ha ringraziato iLuke per il post:
    kaos80 (01-06-15)
  15. #19
    Jan 2011
    ViperOneM9 2.0.0 è basata su fw 1.40 quindi è obbligatorio avere il nuovo firmware! Siccome il fw 1.40.401.5 non deriva da aggiornamenti OTA di HTC, c'è bisogno di installarlo manualmente via fastboot.
    Il procedimento richiede l'S-off, e i passi sono i soliti richiesti per il flash del firmware (guida in preparazione, in caso di problemi potete rivolgervi nel thread SOS in rilievo). Info: QUI
    Nota:
    i
    In Aroma c'è l'opzione per installare il kernel 1.32 kernel anche mantenendo la base precedente, questo consentirà alla ViperOneM9 2.0.0 di avviarsi anche sui fw precedenti al 1.40.
    Nonostante questo, l'intallazione del nuovo FW è fortemente consigliata, sopratutto per poter usufruire dei miglioramenti apportati dalla base 1.40.
  16. Il seguente Utente ha ringraziato iLuke per il post:
    kaos80 (01-06-15)
  17. #20
    E mo!?!non ricordo cosa ho selezionato .Cmq il firmware l ho già messo.se qualcuno può confermare che il kernel sia quello giusto ne sarei grato!
