ViperOneM9 2.1.0 (2nd June)
Additions & Updates
- Added coloring of extended navbar music controls
- Added coloring of extended navbar quicksettings buttons
- Added custom navbar color on homescreen
- Added Back custom statusbar clock and header clock color for html noobs, html deniers, lazy buggers, my mom
- Added kcal Color Control - Compatible wth 1.40 and 1.32 kernel!
- Added custom navbar background
- choose from collection (nearly 200 backgrounds)
- choose from gallery
Fixes & Cleanups
- Fixed Sprint Signal Icons not working
- Fixed Motion Launch Gestures not opening in Settings->Display & Gestures (hopefully)
- Fixed a SystemUI FC some people had
ViperOneM9 2.1.0 is available as OTA. (Settings->About->Software Update / VenomTweaks->Advanced->OTA Update)
Unfortunately the OTA Function is broken in 2.0.0. If you want to use the OTA funtionality you need to flash the OTA Fix in VenomHub first.
Else you can just install the OTA also manually.
OTA for manual flashing:
ViperOneM9 2.0.0 > 2.1.0
Fullroms:
Main Link: AFH US
