[MOD/SCRIPT]CPU Editor - BEST Battery Life -
    Richtc
    CPU Editor by Smokin1337
    Questo mod aiuta a cambiare facilmente le impostazioni della cpu al volo e supporta i dual-core e i quad-core. Più semplice ed economico delle app che trovate nel play store!
    Questo script modifica le frequenze del processore instantaneamente, non ha quel ritardo tecnico delle app tipo setcpu o cpu master o qualsiasi altra app
    Features:
    Change CPU Governor
    Change CPU Min/Max Frequencies
    Set Dual Core CPU's Independently - Governor and Frequencies
    Force Dual Core - Second Core Online ALL The Time
    View Current Settings For Everything
    Settings applied on boot/reboot
    OnDemand Profiling
    Edit I/O Scheduler
    Edit Cache Size
    CPU Editor for Snapdragon
    Utilizzo:
    Scaricare Emulatore terminale dal play store e aprirlo, digitiamo
    codice:
    codice:
     scrivere "su" senza quote, Invio
     scrivere "cpu" senza quote, Invio
     selezionate i numeri corrispondenti a quello che volete modificare
    Notes:
    An error appears sometimes when enabling or disabling force dual core, it's ok the settings still get applied.
    Settings get applied immediately
    Cores can be set independently, you can make the governors and frequencies different on each core. Could be a great battery saver by limiting the second cores resources.
    Force Dual Core will make the second core stay online all the time
    Some kernels do not have a available_scaling_freq so the available frequencies will not be displayed, look up the settings your kernel has either in your rom thread or kernel thread.
    Sticky Mode will apply the settings you have made on reboot (requires init.d support- which most roms and most devices have)
    OnDemand Profiling allows you to set profiles for ondemand governor, the settings possible are performance, performance and battery, and battery saver. Setting will only apply to ondemand govenor !!
    Per ulteriori info il thread originale
    Ultima modifica di Richtc; 31-07-12 alle 13:15
    Richtc
    Changelog
    v3:
    - Added I/O scheduler
    - Added cache size
    - Added clear all settings ie., disable
    - Made it possible to change cpu frequencies when using a profile
    QC Beta 1:
    -Added quad core support
    -Added daemon like script to monitor cpu's online state
    -Fixed the options for gov and frequencies not showing up on other cpus
    -ALL devices supported this is NOT for quad cores only
    Ultima modifica di Richtc; 31-07-12 alle 13:11
    Androidiano VIP L'avatar di sirio87s
    Jan 2011
    Lucera (FG)
    nokia. poi è arrivato android!
    Ringraziato 132 volte in 115 Posts
    sarebbe ottimo se chiunque utilizzasse questa mod mettesse qui sul forum i parametri che ha inserito!
    USA I TASTI CERCA E THANKS!
    Richtc
    Senz'altro, assieme anche ai dati della batteria e all'esperienza d'uso anche se è molto soggettiva come cosa..più che altro ci sono da fare un sacco di prove..
    Inviato dal mio HTC One S con Tapatalk 2
    Richtc
    aggiornato con nuovo download uscito dalla beta e un bel changelog...please chi lo usa faccia sapere come si trova e se magari ha fatto delle prove
    Richtc
    Installato di fresco sulla leedroid e kernel fusion 2.0, ho dato queste impostazioni:
    Cpu0 governor smartass v2
    Cpu1 governor conservative
    Max freq cpu0 1350000 MHz
    Minima 384000 MHz
    Max freq cpu1 1026000 MHz
    Minima 384000 MHz.
    Scheduler sio
    Domani faccio la prova con queste impostazioni, poi farò varie prove con altri governor e frequenze..
