[ROM][CM10.2] Codename Lungo
CODENAME LUNGO
A look in the Future
Goals and more...
More Devices and a wider choice of base ROMS
Want to help Codename Lungo out with future developments? I am always search for people with fresh ideas, ROM Testers or a new device to Develop for!
Interested? just contact me
Panoramica
Codename Lungo è una versione ridotta e leggera di CyanogenMod
un firmware aftermarket per una serie di smartphone basati sul progetto open source Android.
Offre funzionalità non presenti nel firmware basati su Android ufficiali dei venditori di questi smartphone.
Caratteristiche
Maggiore durata della batteria
Tempo di avvio più breve
Interfaccia utente più reattiva
No Bloatware!
Accelerazione hardware
Apex Launcher
Rooted + SuperUser
E molto altro ancora ...
Clean & Fast
Codename Lungo is stripped to the barebones and comes in 2 versions. Because it's stripped you'll automatic have a smoother, cleaner & faster
Custom Launcher
Codename Lungo uses Apex Launcher a Powerful, fast, and highly customizable home replacement for Android™ 4.0+. .
Rooted & SuperUser
is for overcoming limitations that carriers or hardware manufacturers put on devices, resulting in the ability to alter or replace system apps & settings.
Profile Manager
With the Profile Manager you can manage limitless sound profiles! So you can have a different profile for every situation.
Themes Support
Theme manager lets you build a single apk that can theme the ENTIRE system ...
Performance Control
With the Performance Control you can overclock, underclock and edit you power govermor for battery or extreme performance...
Screenshots 2° Post
Changelog 3° Post
Occorrente e Prima Installazione 4° Post
