[ROM][S4] Android Sense Best Stock|Jelly Bean|Sense 4+
BehradGH Rom Series Presents
INFO SISTEMA
- Android 4.1.1 (Jelly Bean) + Sense (4+) latest official HTC One S 3.16.401.8 (WWE) firmware
- This is improved version of Stock ROM
- Stable , Clean , SUPER Fast .
CHANGELOG
- Removed software (CPU) rendering - full Adreno 225 (GPU) rendering
- Fully optimized and tweaked
- ROOT ( Working Correctly in v3.0 and upper )
- Newest BusyBox
- RAM optimizations
- OpenVPN support
- Build.prop tweaked
- sysro/sysrw commands support
- Fully de-odexed
- init.d scripts (BusyBox run-parts) support
- Disabled kernel debugging for better performance
- Speed optimizations
- Enabled GPU UI rendering
- Data, cache and system partitions mounting tweaks
- Bloatware applications removed
- Excellent battery life
- All /system applications updated to latest available
- All /data applications updated to latest available
- Improved EXT4 performance
- Most up-to-date system files permissions
- Zipaligned (Improved RAM management)
- Zipalign on boot (for user applications on data partition)
- Aroma Installer 2.56
- Battery Percentage
- APM Mod
- New Modded Rosie.apk ( If you dont like the new one just flash your desired Mod from download section )
INFO ROSIE ( Sense Launcher )
- Landscape Enabled
- Menu Key Enabled
- 4x6 In Portrait
- 7x3 In Landscape
APPLICAZIONI INCLUSE
- All apps updated to last versions always
- Adobe Flash Player
- Adobe Reader
- Adobe AIR
- ES File Explorer
- Facebook
- Twitter
- Goo Manager
- Dropbox
- FlashImageGUI
GOOGLE APP (Opzionali In Aroma Installer)
- Chrome
- Maps
- Play Music
- Play Store
- Youtube
- Google Now
- Google +
- GMail
INSTALLAZIONE
- Scaricare la ROM e copiarla nell' SD card
- Avviare il telefono in recovery (vol down + power)
- selezionare lo zip ed avviare l' installzione con Aroma Installer
- E' possibile eseguire gli wipe in AROMA (opzionale se montiamo gia' una versione precedente della stessa ROM, obligatorio se si proviene da stock o altra custom ROM)
- Reboot
DOWNLOAD
Android Sense Best Stock v3.0 (latest version)
Wifi Fix For Devices With No Wifi After Flashin ROM
Thanks to BehradGH
