Ho seguito questa guida, ma non so come fare il punto 12
1) Make sure you meet all requirements mentioned in the previous post
2) Put the latest Sense 4.1 version on you SD-card
3) Make a Nandroid in Recovery (Just incase)
4) Just incase, backup your save games folder to your pc
5) Full wipe your device except your SD-Card in recovery wipe menu
6) Start Elegancia - Sense 4.1 Aroma installation
7) Choose desired Sense 4.1 rom version (Stock or colored themed)
8) Choose full-wipe option
9) Setup your rom installation and choose every desired app or mod to install
10) After installation reboot your device.
11) First initial setup will take several minutes and colored version up to 15min
12) After first initial setup you must go into tweaks app and fix permissions (if not then your doomed)
13) Reboot you device once more when permissions are fixed and your ready to go
Credo di aver trovato, sarà nella barra delle applicazioni-->advance-->fix permissioni?
Dopo qualche minuto di attesa sta fixando... poi si riavvia e ci godiamo questa rom!!!!
