Cambiare la risoluzione dello schermo (720x480)
    Non pensavo fosse possibile finché non ho trovato questo post:
    (These improvements will only be noticeable for lower-end android phones)
    Here are some ways ive improved my Wildfire's speed
    Be sure to add thanks if it helps or comment if there are any problems
    Change display resolution (720*480)
    To do this you have to use Launcherpro, if you dont have it install it, you can choose to uninstall it after if you want
    *Update* - 13/11/2011
    If you have ADW Launcher you can also do this without using Launcherpro
    ADW Launcher: [Menu]>Add>Custom shortcut>Pick your activity>Settings>Display Resolution
    Skip to number 3)
    1) Hold on the home screen and a pop-up "Add to Home screen should appear"
    Follow these step
    2) Shortcuts>Activities>Settings>Display Resolution
    3) After doing that you be redirected back to your home screen, with a pop-up confirming you choice press "Ok"
    4) The settings icon should be on your screen, tap it then pick "480p (720*480)
    You should notice a speed boost when play a game like 'fruit ninja'
    Basically what this has done is decrease the amount of pixels that your phone renders in the display, this reduces the need for your phone to produce higher quality images. BUT the quality of the display will not suffer, its all a free speed boost.
    Peccato che questa soluzione non funzioni con la cyanogen mod in quanto manca la voce "com.android.settings.framework.app.displayres olut iondialog" da poter settare. Qualcuno sa se è possibile farlo in qualche modo con questa rom?
    p.s. comunque approfitto per ringraziare tutti per il supporto, non ci credevo nemmeno io ma il mio wildfire adesso è una scheggia, un cambiamento inimmaginabile.
    Mar 2011
    Galaxy S4
    Ringraziato 28 volte in 21 Posts
    interessante..sono curioso anche io
    Telefono attuale: REDMI NOTE 5 4/64
    http://www.androidiani.com/forum/image.php?type=sigpic&userid=33680&dateline=130807  5903 + Galaxy S2 + Galaxy S4 + Nexus 5 + LG G2 + HONOR 8 BLU ZAFFIRO + Redmi Note 5 4/64
    Lecce
    HTC Wildfire CM9
    Ma serve solo a far funzionare più velocemente i giochi ?
    Apr 2011
    I pixel sono quelli che sono.
    Forzare la risoluzione potrebbe forse solo permettere l'istallazione di applicativi che non lavorano su quella nativa del Buzz.
    Se venisse cambiata anche per tutte le schede e finestre, ho paura che risulterebbe abbastanza illeggibile poi il sistema.
    Se qualcuno pensa di provare, ci faccia sapere come va.
    Lecce
    HTC Wildfire CM9
    Ma quali pacchetti potrebbe installare ?
    htc wildfire
    Ringraziato 22 volte in 17 Posts
    secondo me non funziona non puoi cambiare la risoluzione a 720*480 quando la risoluzione dello schermo e di 320*240. A me sa di fake( o almeno non funziona sul wildfire )
    Ultima modifica di marcoin; 18-05-13 alle 23:28
