This is Daddyspud (il creatore della DS)
Ive made a small video on how to create ur own update zip
Video >>>>>>> YouTube - creating own update files.avi <<<<<<
# Remove apps
# Adding apps to /system/app
# Adding a framework
First thing u will need to do it download the link below that has all the files needed
MEGAUPLOAD - The leading online storage and file delivery service
Tutorial
Making a Framework Zip
1 open the Framework.zip file
2 go to system/framework/ and then drag ur framework and close
3 drag the Framework.zip and place it on top of RegawMOD Script Editor v1.0 Omegasun(2)
4 once the program loads dont edit the notepad just close it
5 then type 1 and let the program do the work
6 once finished rename it and flash like a normal zip
Removing Apps
1 Open Base of removing apps
2 go to META-INF/com/google/android/update-script and open it with notepad
3 if u watched the video leave all the show progress alone
4 only edit what apps you want to remove etc (delete SYSTEM:app/Calculator)
5 once u have decided on what apps u decided to remove close and save the notepad and click yes to updating the archive
6 if u have removed inportant apps etc.... phone/sms please replace them with other another .apk and put them in system/app n close the winzip
7 drag the base of removing apps and place it on top of RegawMOD Script Editor v1.0 Omegasun(2)
8 once the program loads dont edit the notepad just close it
9 then type 1 and let the program do the work
10 once finished rename it and flash like a normal zip
Adding apps
1 open the base of adding apps
2 U DO NOT NEED TO TOUCH THE UPDATE-SCRIPT
3 simply go to /system/app
4 but all the apps u wont to go into the phone ( please be warned not all apps will work they will install but some will fc)
5 once u added your apps close the winzip
6 drag the base of adding apps and place it on top of RegawMOD Script Editor v1.0 Omegasun(2)
If you have any problems please let me now and ill try to help the bast i can
tra poco ve la traduco per intero
iniziate a smanettare!
