Pagina 2 di 4 primaprima 1234 ultimoultimo
Visualizzazione dei risultati da 11 a 20 su 36
[Huawei Ascend G700][rom] miui v5 4.6.2/4.8.22
  1. #11
    Dec 2014
    Ringraziato 11 volte in 6 Posts
    Here is a MiUi V6 Build 5.5.10 4.2.2
    http://m.romzj.com/rom/31850.htm
    The Rome runs very Good but the Language are not 100% Change by me to German.
    Icons are English
    System UI English .
    The Rest of Rom is Translate by me in German.
    I have Change locale language in Buildprop but not Works.
    Ultima modifica di simonAHGermany; 08-09-15 alle 20:27
    Androidiano VIP L'avatar di Perryd
    Xiaomi, Huawei
    Ringraziato 323 volte in 250 Posts
    Its fake. Use morelocale to change language, this app translate app witch you download but non translate system app
    Inviato dal mio HUAWEI G700-U00 usando Androidiani App
  4. #13
    Dec 2014
    Morelocal 2 not Works . I thought so thats a fake then Miui 6 runs on 4.4 right?
  5. #14
    Xiaomi, Huawei
    I repeat, morelocale set your languange only for app downloaded but non for system app.
    probably the Roma has only the graphics of miui v6. PS: it's ROM and not ROMA
  6. #15
    Dec 2014
    I have a Huawei G700-U00 B152 with Emui 2.0 and when i set language with Morelocal on this Rom all of Rom is translate complete. On this Rom is only English and China with Morelocal Translate the Complete Rom.
  7. #16
    Xiaomi, Huawei
    For expample? Whatsapp is translated or remains in Chinese? If not translate external app its strange but if not translate system's app its nornal...otherwise I can recommend the tool " jbart " to translate the ROM . ( if you know how to use it ). 152 is translated because the whole probably has the German language default . More than that I do not know how to help you to the language problem ...
  8. #17
    Nov 2013
    Ciao a tutti!
    Ho un problema con la rom in quanto non riesco a far connettere la sim in 3g anche settando gli apn in modo corretto. Gli sms e le chiamate funzionano ma internet no... qualcuno sa darmi una mano? ho sbagliato qualcosa io? Magari la rom rende incompatibili alcune bande? Non lo so...
    Ciao!
  9. #18
    Xiaomi, Huawei
    Il 3G funziona se no non avremmo pubblicato la rom... Controlla in impostazioni->reti mobili->3G network se è abilitato
  10. #19
    Nov 2013
    Sono un imbecille
    Non mi ero reso conto che mi è scaduta la promozione di internet...
    Ultima modifica di sannito; 10-09-15 alle 21:56
  11. #20
    Xiaomi, Huawei
    Ecco infatti, posso assicurarti che il 3G funziona
