This one has no problem for me. Spanorg's emui 2.3 camera forces close but this one is stable. Probe it and tell me.
Okey.. I see that you cant understand me : ) I make a screen record to see that spanorgs port not even a little stable. As I say I tried already all ports .. and seems that the only one whom can be the best with a little "touches" is niisp`s.. I remove my previous camera and install again the one from your link .. just to prove you that is garbage which I know it before :- )
Here is the link
1. Camera become unresponsive when you change HDR ot something else.. You need to press home and then remove it from recent apps..
2. I show you that the video has no continuous focus .. See how in the begging camera focus .. and then when recording .. cant focus on my USB drive..
3. When I try to push the recorded video, Gallery FC..
4. A lot of lacks at all, everything I say and before for spanorgs ports .. is as is : )
5. Tell me when you download the video to delete it : )
PP: Also seems like spanorgs ports has a little bit poor quality..
Ultima modifica di bmas; 24-01-15 alle 18:08
Not possible. You cant be only one in this earth who hasnt got the same lacks in this port as me. Even the spanorg itself dont deny them.. But may be you made some modifications ..
However .. this is more like spam now .. I come back to my first please/request and you can stay with spanorgs port if is not problem to you to have all this lacks..
I see you talk something about f2fs .. In Mokee when I change Data and Cache to f2fs .. the ROM become the most responsive ever. I cant imagine if AP can work with f2fs .. AP now is so fast .. and if could be f2fs .. will be some performance beast..
Thank you very much for your words... you make me feel so special!
Take a look at xda developers: every body says Camera Emui 1 is ok but Emui 2.3 is unstable: XDA DEVELOPERS
Take a look at HTCMania, the same: HTCMANIA
I'm not using spanorgs port, but when i used to do it, i had no bugs at all. Can you believe it? If i would have so many bugs i would never recommend you this option.
By now, i have a new chinese rom 4.4.4: FIUI, based on cyanogenmod, a great option!
If you agree, we're in an italian forum, let's try respect it and let's talk in italian,we can use google translate.
CIAO P1isti......... giusto per un salutino (non sono sparito sono in stand by causa neo II^ paternità)
ZAO MC!!!!!!
SE MI KLIKKATE GRAZIE QUANDO VI AIUTO, .... MI "RIEMPIO DI GIOIA"...!!!!
Congratulazioni!
Io mi sto trovando bene, prima con la 8.2 ogni tanto crashava, ma era un po' tutto il telefono ad essere impazzito, quindi non lo attribuisco alla fotocamera. Dopo averlo wipato ed aver messo la 9 la situazione è decisamente migliorata.
