Features ROM:
Ascend P6 Unicom 10/21/2013
Hidden-text SelectHide
System Advanced Settings category
1 was added into the " test mode " feature
2 adjustable mobile phone network and view wifi, battery information
3 Turn on 2G/3G band lock function
4 "ROM Advanced Settings " – "Test Mode" – " Phone Info " – " Set preferred network type " set to
5 added into the " engineering mode " function
6 can be classified test hardware and software for mobile phones
7 ROM Advanced settings support the white, black theme switching
8 ROM Advanced Settings tab style supports three theme switching
9 Optional text label at the top , bottom and bottom short Minister indicator indicator style
Advanced features like
1 Add "G key functions ", the user can customize the G key functions ambition
2 Click in the status bar shortcut "G key " to jump directly set by the user function
3.Add "Custom Google service function"
4 full Google services enabled by default , users can customize the open, close , and completely remove the Google services
5 by adding " screen assistant " feature, transplanted from Huawei MATE
6 Screen assistant suspended in the top screen , similar to a virtual HOME key IPhone
7 Click the screen will appear aides return key, Home key , lock screen and mute buttons
8 Screen assistant switches automatically remember user settings, since the response of switching state after opening
9 by adding " Music Power " switch function, the user can customize the switch boot music
10 by adding " virtual key right home " function
11 Default button at the bottom of the navigation bar to return to the state the right of abode
12 user-definable virtual return key Left or right hand side
13 Join the navigation bar background color customization
14 Supports two virtual navigation bar menu at the bottom of the background of the custom
15 The default color is black
16 adding "VM virtual machine optimization " function
17 adding " kernel parameter optimization" function
18 adding "battery parameter optimization " function
19 The above three functions support the boot from the response switch status
Ringtones and dial-up classes
1 Add "Call shaking Mute " function
2 When an incoming call, the user can turn off the call by shaking the phone rings
3 Adding " call mute sensitivity adjustment " function
4 Users can customize the sensitivity of the sensor shake , support for 8 -speed adjustable
5 The smaller the number , the stronger the shake sensor sensitivity
6 Adding " Ringtone crescendo " function
7 Calls according to user set time interval increases the ring volume
8 support the largest ring setting, ie the maximum volume crescendo ringtone
9 Supports enhanced interval setting , ie 1 second , 3 seconds or 5 seconds after the increase a volume level
10 adding " two-way conversation recording automatically " feature
11 Monitor the current call state, when outgoing or receive calls when dialed automatically start automatic recording function
12 Turn on automatic recording and recording will automatically turn off when the prompt
13 tips to join the call recording feature custom switch
14 Users can customize whether automatic recording tips
15 Join "on vibrate " function, when turned on outgoing or access phone will vibrate prompts
16 adding " hang shake " function, when the hook when the vibrating alert
Lock screen and SMS categories
1 Adding " unlock interface switching" feature
2 support the user in Google Huawei unlock unlock and native real-time switching between
3 Adding " Huawei unlock vibration settings ", the user can customize the switch to unlock Huawei unlock screen vibration feedback when
4 Huawei unlock vibration settings, support for all unlocked Huawei theme styles
5 Add Volume + / – wake up the screen functions
6 customizable wake-up function on or off the volume
7 Add "New SMS bright screen prompts" function, when a new message is automatically bells screen 5000ms
8 by adding " SMS bubble style settings " function
9 support 8 kinds of style bubble SMS for users to choose settings timely entry into force
Advanced Settings category status bar
1 added status bar shortcut key dual-mode switching function
2 the user can switch the status bar shortcut key is "double line layout " and " Grid Layout"
3 in the official original single 10-key shortcuts based on the status bar and then expanded 10 shortcut keys
4 were added to enhance the shortcut keys are as follows:
( 1 ) Restart option, click the exhaled reboot menu, you can carry out normal restart, fast reboot , reboot to recovery and fastboot mode
( 2 ) access point switch , click exhaled apn switch menu
( 3 ) flashlight switch, click the button to automatically switch flashlight, flashlight icon respond to changes
( 4 ) Dolby sound , Dolby sound settings click exhaled
( 5 ) G key, click the user-defined function exhaled
( 6 ) sound adjustment , a mute button can be completed , ringing and vibration mode switching , better than emui comes with three buttons to switch the sound
Respond to changes in the volume mode button icons , boot from the update icon status after
( 7 ) brightness adjustment, when clicked, will pop brightness adjustment bar
( 8 ) power-saving mode , click on the menu will be exhaled power saving mode
( 9 ) Suspended button, click the button to turn on or off the suspension , boot from the response set , since the update button icon
( 10 ) advanced settings, click Advanced Settings exhaled ROM
5 by adding " at the top of the status bar color settings " function
6 user can freely set the status bar color palette and transparency
7 by adding " digital clock status bar shows" Switch Function
8 by adding " status bar Digital Clock Color Settings " feature
9 by adding " network standard status bar displays" function, the default status bar displays the leftmost operator network standard
10 Users can also customize the status bar switch network standard
11 by adding " status bar network standard color settings " function
12 adding " network standard custom status bar " feature , the user can edit the text operators
13 by adding " status bar displays speed " function is turned on real-time display the current downlink speed
14 The default network speed status bar unrealistic
15 by adding " status bar speed color settings " function
16 by adding " status bar battery icon shows " feature , can be customized switch battery icon
17 by adding " status bar battery icon style setting" function
18 provides 14 power icon style for users to choose settings timely entry into force
19 by adding " status bar shows the percentage of power " function , you can customize the percentage of power switching status bar
20. Adding " the percentage of power status bar color settings " function
21 by adding " status bar signal icon color settings " feature , you can customize the signal , wifi signal icon color
Down the status bar to set the class
1 Adding " drop-down status bar background color set " function , adjustable color and transparency
2 by adding " custom drop-down status bar background " feature
3 The user can specify an image as the background of the drop-down status bar
4 Adding " drop-down status bar weeks and Clock Display" function , you can customize the status bar at the top of the switch down the date and clock
5 by adding " drop-down status bar at the top of regional color settings " feature , you can customize the status bar at the top of the drop-down color and transparency of regional
6 Add " drop-down status bar displays enhanced shortcuts " feature , you can display or hide the status bar shortcuts
