Visualizzazione dei risultati da 1 a 10 su 21
[Huawei Ideos X5][ROM] Ported dal Desire S [basata su cyanogenmod 10]
    si dice sia un'ottima rom:
    Features
    •Based on the Latest CM sources(ported from DesireS)
    •Used October Shendu Kernel with OC upto 1.8Ghz(Found it best for gaming)
    •Unlocked FPS
    •zipaligned Apks
    •KickAssKernel and V6 script
    •Seeder 2.0.0
    •Pretty Ass Smooth!
    •Every other Features from CM10.0
    Stock
    Download: https://www.dropbox.com/s/45qxead1y5...o_rik_v1.0.zip
    version 1-By Me
    •Initial Release
    uscita nuova versione 1.0.1:
    https://www.dropbox.com/s/6vgif83t7d...ial_v1.0.1.zip
    changelog:
    version 1.0.1-By PrakharKumar
    •LED bug removed
    •CM10 Dialer
    •Fixed camera (now using ShenDu camera)
    •Backlight bug removed
    •New Shendu Kernel(updated december)
    •Most other previous Release Bugs are removed.
    versione 2.0
    http://d-h.st/bT0
    changelog:
    Version 2.0-By PrakharKumar
    •latest ShenDu kernel (28/02/2013).. still 3.0.8(ICS) instead of 3.0.31(JB)
    •4.2 camera (ofcourse, without photosphere)
    •fixed root (to be on the safer side, ShenDu Permission, Superuser & SuperSU, all three are there)
    •removed useless/duplicate/double apps (reduced the ROM's size quite a bit)
    Versione 3.0 by Herna (feat cuvetto e rittik)
    http://d-h.st/O1g
    Changelog
    Version 3.0
    •Latest Shendu Kernel
    •Camera Autofocus Totally fixed
    •Some 3rd party Camera fixed(partially) •Sound/noice fixed from speaker
    •Wifi tethering and hotspots Fixed.
    •RAM Management Partially fixed(Should be better than earlier releases)
    link su xda: [ROM]CyanogenMod 10 {Unofficial} Initial Release - xda-developers
    PS come bug la v3 ha il vivavoce. Bug che comunque a detta di rittik e altri su xda sono stati risolti e che verrà rilasciato un bug fix sotto forma di zip
    Ultima modifica di totocrista; 07-05-13 alle 17:07
    Androidiano VIP L'avatar di cuvetto
    Palermo
    U8800+,SGS2+,Ulefone Paris
    Ringraziato 452 volte in 305 Posts
    ....a detta di chi la usa, sembrerebbe un ottima base......qual che bug qua e la, ma sembrerebbe niente di così tragico....da provare assolutamente!!!!
    Avanti è la vita.....
    Quote Originariamente inviato da cuvetto Visualizza il messaggio
    Aspettiamo che ci metta mano tu
    intanto è uscita la versione 1.0.1:
    Palermo
    Grazie per la fiducia....ci ho smanettato un po' ieri sera ma non ho concluso niente....i problemi con il wifi persistono Soprattutto con l'hotspot, ma a volte anche con il wifi stesso)...per quello che è il mio utilizzo, la ritengo inutile......ma chi non usa il wifi un pensierino può farcelo......
    con che versione non ti va il wifi? la 1.0 o la 1.0.1?
    Palermo
    1.0 o 1.0.1 non cambia molto.....il changelog parla chiaro...la differenza sta solo nel fixare bug con soluzioni già note, un lavoro di 5 minuti, non di più......
    Quindi chi usa il Wi–fi è inutile metterla... Grazie per la dritta...
    Inviato dal mio U8800Pro con Tapatalk 2
  9. #8
    Palermo
    Io ti direi di provarla comunque.....ti fai prima un NANDROID BACKUP e se successivamente non ti piace o non ti funziona, a ripristinare la vecchia ROM ci vogliono 2 minuti, non di più......
    Ti dico questo perchè a quanto pare a qualcuno funziona il wifi......provala e posta la tua testimonianza....
  10. #9
    Installata la versione 2 sul cellulare ed è una bomba ;–)
  11. #10
    L'unico problema è la tastiera che autocrasha ma basta installare la SwiftKey e si risolve tutto...
