Le 2 eUI
5.8.019S (Indian version)
Le 2 2016-10-19 S2_X526-OS-OP-IIXOSOP5801910121S 1.74GB
LeMe Community
Change Log
[Network]
Fixed an issue in which 4G Data is not working in Reliance JIO. (Le Max2)
Fixed an issue in which call drop happens when making VoLTE calls using Reliance JIO 4G network. (Le Max2)/(Le 2)
Fixed an issue in which Reliance JIO Sim can not register IMS. (Le Max2)/(Le 2)
Enabled VoLTE feature. (Le 2)
[Dialer]
Added back call recording function. (Le Max2)
Fixed an issue in which VoLTE HD call unstable and HD Signal disappeared once call started. (Le Max2)
[Video Player]
Fixed an issue in which the Next button is not working in default video player. (Le Max2)
[Music]
Added new music service provided by Hungama. (Le Max2)/(Le 2)
Fixed an issued in which Music stops when unlock music application by fingerprint or by pattern. (Le Max2)
Added service to control center to support third-party music app. (Le Max2)/(Le 2)
Fixed an issue in which no dynamic permission pop-up at first launch. (Le 2)
Added ‘Create Playlist’ option in Playlist. (Le 2)
[Camera]
Optimised focus performance in dark environment. (Le Max2)
Optimised focus performance in macro. (Le Max2)
Fixed an issue in which the focus keep moving in and out when taking photo of text in macro mode. (Le Max2)
Optimized flash brightness. (Le Max2)
Optimized color spot under HRD mode. (Le Max2)
Optimized QR Scanner focus speed. (Le Max2)
Enhanced the auto night mode (Le 2)
Optimized color display in low light conditions. (Le 2)
Fixed an issue in which ghosting may occur when taking photo of moving objects in HDR mode. (Le 2)
Optimized White balance performance. (Le 2)
Fixed an issue in which fingerprint unlock fails after few captures with camera from locker screen. (Le 2)
Optimized SLO-MO recording noise. (Le 2)
Optimized Green color performance under night mode. (Le 2)
Adjusted flash color cast. (Le 2)
Optimized color spot under HRD mode. (Le 2)
Optimized QR Scanner focus speed. (Le 2)
[Phone Manager]
Added auto alert switch in App Battery Usage Alert.(Le Max2)
Optimized network access control logic. (Le 2)
Optimized battery usage alert function. (Le 2)
Added an access to app lock and privacy lock. (Le 2)
Added Virus Scan. (Le 2)
Added Harassment Filter Function. (Le 2)
Added access to manage Trash Message. (Le 2)
[Fingerprint]
Version upgraded, Optimized using experience.(Le Max2)
[Setting]
Added Dual App feature. (Le Max2)
Added Small font option. (Le Max2)
Optimized font display. (Le Max2)
Optimized setup procedure of App lock. (Le Max2)
Added Do not Disturb. (Le Max2)
Optimized setup procedure of privacy lock. (Le Max2)
Added Small font option. (Le 2)
Added Three-finger screenshot function. (Le 2)
Fixed an issue in which font increased after OTA. (Le 2)
Optimised the App lock’s processing logic. (Le 2)
[My LeEco]
Added LeEco Membership (Le Max2)
[Message]
Added default SIM card option for messaging. (Le Max2)/(Le2)
Fixed an issue in which received new message while all messages selected, message stopped.(Le Max2)
Added an access to settings page. (Le 2)
Added SIM info and longer preview in Notification Centre. (Le 2)
Fixed an issue in which received new message while all messages selected, message stopped. (Le 2)
[Screeshot]
Added Three-finger gesture for screenshot function.(Le Max2)
[Ringtone]
Added more ringtones (Le Max2)
[Battery]
Added quick charge switch (Le Max2)
Add Battery Temperature (Le Max2)
[Sound & Vibration]
Added Vibration switch.(Le Max2)
Added Dolby Atmos (Le Max2)
Added separate ringtone setting for dual sim card.(Le Max2)/(Le2)
[Third-party App]
Fixed an issue in which WhatsApp can only send 1 local music file at once.(Le Max2)/ (Le 2)
Fixed an issue in which sound cannot switch from earphone to speaker after unplugged earphone when listening to Whatsapp voice message. (Le 2)
Optimised WhatsApp Notification tone volume. (Le 2)
[System]
Changed minimum battery requirement for upgrade to 30%.(Le Max2)
Fixed an issue in which APN setting is unable to edit.(Le Max2)/(Le2)
Fixed an issue in which JIO network does not work properly.(Le Max2)/(Le 2)
Adjusted ZRAM strategy now default set as off. (Le 2)
Updated Google security patch. (Le 2)
Changed minimum battery requirement for upgrade to 30%. (Le 2)
[Feedback]
Fixed an issue in which the ‘feedback’ app crashes after submitted online feedback. (Le 2)
[Recovery Mode]
Fixed an issue in which ‘no .apk file found’error message pop up when update system in recovery mode. (Le 2)
[Type-C]
Optimised Type-C earphone energy consumption when using GPS. (Le 2)
Fix the issue where there is a pop sound in type-C earphones at dialling. (Le 2)
[Dolby Atmos]
Optimised Dolby Atmos. (Le 2)
Modified Dolby parameter. (Le 2)
[Phone/Contact]
Added back call recording function. (Le 2)
Optimized new contact creating procedure. (Le 2)
Added SIM name on dial button when using Dual Sim. (Le 2)
Added blacklist in Contact setting. (Le 2)
Fixed an issue in which VoLTE HD call was unstable and HD Signal disappeared once call started. (Le 2)
[Recovery Mode]
[Wallpaper]
Fixed an issue in which wallpaper change back to default occasionally. (Le 2)
[Hall Sensor]
Optimised Hall Sensor Int value which fixed auto lock screen issue. (Le 2)
[Wi-Fi]
Fixed an issue in which occasional Wi-Fi signal loss when connecting to open Wi-Fi network. (Le 2)
Fixed an issue in which WLAN displayed instead of Wi-Fi when system language is English. (Le 2)
[Bluetooth]
Fixed an issue in which search function stop working after unpaired. (Le 2)
Fixed an issue in which WeChat cannot play a complete voice message in Bluetooth mode. (Le 2)
Fixed an issue in which Bluetooth function fail to open. (Le 2)
Fixed an issue in which fail to share files. (Le 2)
[Browser]
Fixed an issue in which navigation website changes with phone language setting. (Le 2)
[Note]
Added Privacy lock. (Le 2)
[Clock]
Fixed an issue in which date format incorrect in Dual Clock widget. (Le 2)
Fixed an issue in which dual clock widget cannot be opened when switch from standard view to zoomed view. (Le 2)
Fixed an issue in which some city take longer time to load in dual clock widget. (Le 2)
Fixed an issue in which alarm only have sound but no visual when goes off in multi-task interface. (Le 2)
Adjusted Date format for different regions. (Le 2)
[Gallery]
Fixed an issue in which video cannot be played in hidden album. (Le 2)
[Mail]
Added ‘Long press’ to select all action in Contact detail page. (Le 2)
[Calendar]
Added attachments count in Meeting Event. (Le 2)
