Utente del giorno: Q.dino con ben 4 Thanks ricevuti nelle ultime 24 ore
Pagina 25 di 25 primaprima ... 15232425
Visualizzazione dei risultati da 241 a 248 su 248
[Porting] [ MIUI 8 ML] Letv X500
  1. #241
    Senior Droid L'avatar di korsa5791
    Ringraziato 211 volte in 165 Posts
    Quote Originariamente inviato da Pirat21 Visualizza il messaggio
    Nowa wersja od:
    [AdrPat] Le 1s - MIUI 8 v.6.9.02 International (Latest Version)
    TWRP Recovery Zip
    Rooted
    Xposed included
    Greenify
    Dolby Atmos
    Viper4android
    IOS effects
    26 Languages
    Google services and play store included
    Supports infrared
    Supports fast charge
    EUI audio media included
    Blurred statusbar and notification shade
    Enabled search in statusbar
    Enabled search gesture (swipe up) on the desktop
    Enabled MiDrive in File Explorer
    Added landscape mode for SMS app
    Sunrise/Sunset in the weather app
    Google apps support integrated
    No useless Chinese bloatware apps
    More free RAM (1.8 Gb) due to less background processes
    Unified flat style app icons for both system and 3rd party apps (eg. Play Store icon flat too, unlike official global MIUI)
    Advanced menu with color icons (not just text like in official MIUI releases)
    No any Chinese character under the full system
    Mi Video, Mi Music, Mi Radio, Mi Browser: No any useless Chinese content
    No possibility to re-lock bootloader accidentally with flash any xiaomi.eu release
    Added real 26 languages translation made by Official MIUI Fansites and MIUI Fans
    Added Phone swipe to the right gesture on the lockscreen
    Xperia keyboard
    Added Screen-OFF animation
    Optimized GPS settings for EU
    Optimized Battery consumption
    Optimized RAM consumption
    Theme element edit mode
    Deodexed
    And more, and more ...
    Download:
    https://mega.nz/#!t4MEzARY!hq83pjiZy...jqpNM7XlfI9oVE
    Credo che tu debba postare questa rom da un'altra parte... Modifica...Grazie
    @NiloGlock su può intervenire?
    Sassari
    LG G2, LeMax 2
    Quote Originariamente inviato da korsa5791 Visualizza il messaggio
    Quoto... E cancello
    La discussione corretta è questa: https://www.androidiani.com/forum/sh...d.php?t=492431
    Inviato dal mio LeMax 2 utilizzando Tapatalk
    Smartphone:
  4. Il seguente Utente ha ringraziato NiloGlock per il post:
    korsa5791 (03-09-16)
  5. #243
    Sassari
    LG G2, LeMax 2
    Bravi da vero informazione dellla Rom cancellata non ho parole. Comunque faccio segnalzione al proprietrio del Forum.
    Procedi pure...
    Smartphone:
  6. I seguenti 3 Utenti hanno ringraziato NiloGlock per il post:
    Kikas18 (23-09-16),korsa5791 (03-09-16),Pirat21 (04-09-16)
  7. #244
    Nov 2016
    i have successfully installed and currently using the version " Miui 7 04.06.28 " then i tried flashing the newer version " Miui 8 06/06/30 " but its keep failing, the error messages was:
    unmount of /data failed; no such volume
    unmount of /system failed; no such volume
    Please reboot system now.
    Updating partition details ...... done.
    but its not rebooting to the updated system, so i had to go back to the previous version. I completed 3 wipes before flashing the zip packages. tried several times. Don't understand what is going wrong. Please help!! .
    Sorry I am from outside of Italy, so only understand english.
    Thanks Anyway.
    Regards Mistu,
    Ultima modifica di mistu2012; 08-11-16 alle 07:33
  8. #245
    Quote Originariamente inviato da mistu2012 Visualizza il messaggio
    Thanks Anyway.
    Regards Mistu,
    try updating the TWRP. I remember that the last is 3.0. then try again flash. if it does not, you can try installing the EUI of BB72 you find in the forum and then re-install the MIUI on that. However, checks that you download the zip is not corrupted.
  9. #246
    Nov 2016
    Thanks Managed to install it, its a litle laggy from v7 , but still good enoguh. Thanks for the great work man,. Loved it,
    Heard the source kernel had been released by LeEco and again deleted on the other forum. some good people was able to download before its got deleted, Anyway hoping this will solve the fingerprint issue, The MIUI is perfect on Le 1s except the fingerprint.
    More power to you bro. Hope you will improve this one more when you will be free.
  10. Il seguente Utente ha ringraziato mistu2012 per il post:
    korsa5791 (09-11-16)
  11. #247
    Androidiano L'avatar di butch
    LeTV X500
    Ringraziato 41 volte in 29 Posts
    Ciao @korsa5791, ho appena letto il messaggio di mistu2012 relativo al kernel, mi pare una ottima notizia !
    Pensi di avere tempo per vedere se si può integrare il fingerprint ?
    Grazie, ciao
  12. #248
    Quote Originariamente inviato da butch Visualizza il messaggio
    Grazie, ciao
    Mi dispiace ma non ho più il telefono. E comunque ammetto che il kernel non è il mio forte🤗
