simon991
Hi friend ! It seems incredible but I have the same history ! I had an X600, and after I bought the X800 for the same motivation, the DAC.
And I was disappointed too about the audio, cause my old X600 had the dolby atmos and the rom form BB72.
The X800 have not with the stock rom, but it will have the dolby atmos with the Cuoco92 11S v41 Rom ! And it's almost the same as the X600 rom as music volume, the quality with headphones is better on X800, BUT you have to set on the DAC and you have to use some high impedence and high quality headphones, if you compare with the Cuoco's ROM the two smarthphones with dolby atmos turned on and you use some cheaper market headphones with 16ohm of impedence (example with panasonic, or awai ES900) you will have a better sound with the X600, instead if you use some medium imedence headphones but high quality (Denon ah-d600 / Denon ah-d340 for me) you will see that the volume is lower but the quality higher !
Instead with high imedence headphones I haven't tryed yet, but I saw many review (LG V10 that have the same ESS from Sabre) where the audio is not too much high but the quality is really good. You must use FLAC or WAV to see the difference.
Flash the Cuoco92 Rom v41 that you find in this post and use the guide, and you will see the difference.
Sei fortunato, con Vodafone va una bomba davvero, mentre con Tre e Wind io ho una marea di problemi, ho inserito un post con le specifiche nel post riguardante le bande B7 e B20.
Vodafone davvero a me vola, mentre Wind non va in 4G, e H3G ci va con 1mb di down e 15 di up ! (e non ho invertito i valori), Vodafone va con 70 di Down e 15 di Up, almeno a Napoli.
Ho fatto il test in 3G e Vodafone il down è lento tipo 2-3 mb, l' up invece non si smuove proprio e fa andare in crash lo speed tester, con gli altri opertori il 3g va benissimo.
Insomma in poche parole se vuoi vodafone siccome copre il 95% del territorio nazionale con il suo 4G preparati a dire un po' addio alle gite sulle vette sconosciute di montagna dove vi è solo 3G.
Sulla batteria ! Eh... ti dico la mia, finchè ho avuto la rom stock la batteria durava poco e crollava velocemente e c'erano battery drain di programmi inutilizzati e mai aperti ne configurati (Ant keyboard) per esempio oppure Youtube che si ciucciava buon 4% di batteria senza nemmeno aprirlo.
Arrivavo a 2H- 2:30 di schermo.
Ho messo nella disperazione domenica la Cuoco 92 11S v41.
Batteria migliorata !!! Ti dirò sto usando da stamattina alle 11 a tratti spotyfi, musica mail e whatsapp (come se non ci fosse un domani) con qualche messaggio su fb messanger e sono con 1:28 di schermo e rimanente 70% di batteria ! Insomma un miracolo davvero.
Ieri che lo ho usato davvero intensamente tra navigazione gps, bluetooth, adobe pdf, fotocamera, whatsapp, spotyfi, browser, sms, e chiamate (circa 40 min), sono arrivato a 3H di batteria la sera ed aveva ancora il 10%.
Quindi un ottimo risultato per me, non perfetto, non da X600, ma ottimo rispetto alla stock.
Il segreto è usare il Wi-Fi quando puoi perchè consuma MOLTO meno batteria rispetto alla rete, specie se si ha Wind o H3G che "ballano" tra UMTS e HSPDA+ in continuazione sperperando energia.
Spero di essere stato chiaro, se vuoi gli screen dei dati di batteria e rete Vodafone li ho quindi basta che chiedi.
