Brush Notes:
Make sure your phone is brushed into the forum on third-party recovery, and the normal brush
ROM has joined ROOT privileges, for the first time may be prompted to ROOT, click OK to
brush machine takes a few minutes, please be patient brushing, then restart mobile phone
for the first time brush boot is very slow, please be patient phone is switched on, the operation again
write too fancy presentation, like to brush it, EUI5.8 Android version 6.0 (bottom package from Friends of the base)
declined to make any meaningful based on this package streamlining of modification and optimization publishing
production based on the official beta version EUI5.8
new Android 6.0 version, welcome to experience
the removal of unwanted programs and components related to the official
removal system rec restrictions, brushing does not restore official rec
repackaged ROM format is dat, brush fast write complete
optimization of power consumption, standby capacity to improve cell phone
a lot of useless software and resources to streamline the official
to remove the excess part of the system theme, reducing the volume
of the desktop reorder, brushing not messy
to remove the setup upgrade useless related components
open ROOT permissions, use SuperSU authorization
authorization Manager hung on the data, do not uninstall
add bosybox instruction set, advanced users may need
optimization framework to enhance fluency, rapid and smooth
optimize network performance optimization global touch response
improved sliding smoothing effect, touch sensitivity,
a ROM with simple stable mainly, like we like to
follow you for taking the time to release multifunction version
Note:
If the program is not available, go to settings, should manage to find the corresponding program
selection authority, all project-related permissions allow
specific reference to its own official update log
directly by clicking on the post Download Now you can get the address
