DYOS
Ho seguito tutta la guida e arrivati quasi alla fine su LGMobileSupportTool mi da questo errore:
17:38:24 : ******************************************
17:38:24 : [C:\ProgramData\LGMOBILEAX\Phone] Try to delete folder
17:38:24 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
17:38:24 : SetEmerModeAT()
17:38:24 : _IsConnectedPhone Call
17:38:25 : _IsConnectedPhone(0)
17:38:25 : 0 - NotConnected.
17:38:25 : 1 - Normal connect success
17:38:25 : 2 - Emergency connect success
17:38:25 : *****CheckOS Start********
17:38:25 : Microsoft_Windows7_Professional_Service Pack 1
17:38:25 : *****CheckPCSyncPrograms Start*****
17:38:26 : PCSyncPrograms Not Found - OK and ready to upgrade
17:38:26 : Verifying phone connection...
17:38:26 : dwWaitResetTime(40000 ms)
17:38:27 : _IsConnectedPhone Call for 3GQCT
17:38:28 : Phone Mode(0)
17:38:28 : 0 - NotConnected.
17:38:28 : 1 - Normal connect success
17:38:28 : 2 - Emergency connect success
17:38:28 : _IsConnectedPhone Call
17:38:42 : _IsConnectedPhone(1)
17:38:42 : 0 - NotConnected.
17:38:42 : 1 - Normal connect success
17:38:42 : 2 - Emergency connect success
17:38:42 : Phone Mode(1)
17:38:42 : *****GetPhoneType Start*****
17:38:51 : You can't continue the upgrade due to errors.\nFollow the order: (1)Separate the USB cable and battery from the phone; (2)Connect the battery; \n(3) Connect the USB cable to the phone.\n(4)Press the power button on the phone for 3~5 seconds. When the phone is on,\npress the '[Restart]' button for upgrade.\nGo to LG Mobile home and read notices about upgrades.\nTo finish the upgrade, press the 'Finish' button. (_CheckPhoneType() Error)
17:38:51 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
17:38:51 : Page_Error ºÎºÐÀÔ´Ï´Ù
17:38:51 : ¿©±â´Â Retry ºÎºÐÀÔ´Ï´Ù
17:38:51 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
