Chiudi LG Update prima di avviare la procedura.
Sicuro di aver settato correttamente il webserver ?
Cosa intendi per webserver? Nella guida non lo vedo scritto... Come lo configuro?
Ultima modifica di Buccolieri96; 20-02-12 alle 23:54
segui anche questa Guida
http://forum.xda-developers.com/show....php?t=1473781
L'ho fatto ma mi si blocca al 16% del passaggio upgrade. Posto il log.
14:03:41 : [C:\LGMobileUpgrade] Try to delete folder
14:03:41 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
14:03:41 : Start Date : 2012-02-22 14:03:41
14:03:41 : ---------- QM Testmode ---------
14:03:41 : ***** Check Tool Version *****
14:03:41 : Tool version : 1.5.4.8
14:03:41 : UpgradeDLL version : 1.2.6.7
14:03:41 : Current Dir : C:\ProgramData\LGMOBILEAX\B2C_Client
14:03:41 : LGE USB Driver Version :
14:03:41 : Android PDLV Version :
14:03:41 : Android NDLV Version :
14:03:41 : ******************************************
14:03:41 : [C:\ProgramData\LGMOBILEAX\Phone] Try to delete folder
14:03:41 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
14:03:41 : SetEmerModeAT()
14:03:41 : _IsConnectedPhone Call
14:03:57 : _IsConnectedPhone(1)
14:03:57 : 0 - NotConnected.
14:03:57 : 1 - Normal connect success
14:03:57 : 2 - Emergency connect success
14:04:10 : *****CheckOS Start********
14:04:10 : Microsoft_Windows7_Professional_
14:04:10 : *****CheckPCSyncPrograms Start*****
14:04:10 : PCSyncPrograms Not Found - OK and ready to upgrade
14:04:10 : Checking the connection with the cell phone...
14:04:10 : dwWaitResetTime(40000 ms)
14:04:11 : Phone Mode(1)
14:04:11 : *****GetPhoneType Start*****
14:04:11 : Phone Type : OMAP_IFX
14:04:11 : *****GetPhoneModel Start*****
14:04:12 : Phone read Model : LG-P920
14:04:12 : Server param Model :
14:04:12 : *****GetPhoneBinaryVersion Start*****
14:04:14 : Phone Bin Version : V20A_00
14:04:14 : *****Get ESN / IMEI / MEID Start*****
14:04:18 : ESN/IMEI/MEID : 357116040810957
14:04:18 : Phone type Compare start
14:04:18 : *****Start _GetBatteryLevel*****
14:04:20 : Battery(218)
14:04:22 : *****CheckPCSyncPrograms Start*****
14:04:22 : PCSyncPrograms Not Found - OK and ready to upgrade
14:04:23 : ****************CheckAndDownload****************** **
14:04:23 : ******Extract Start C:\Users\Anthony\Downloads\V21A_00.kdz*****
14:04:23 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
14:04:23 : File Size = 422574676
14:04:52 : Extract kdz file Success.
14:04:54 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\V21A.wdb\n
14:04:55 : WDB(or DZ) FullPath(C:\ProgramData\LGMOBILEAX\Phone\\V21A.wdb )
14:04:55 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LGP920.dll\n
14:04:55 : Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\\LGP920.d ll)
14:04:55 : NNNNN WDB FullPath(C:\ProgramData\LGMOBILEAX\Phone\V21A.wdb)
14:04:55 : NNNNN Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\LGP920.dl l)
14:04:55 : Extract End C:\Users\Anthony\Downloads\V21A_00.cab
14:04:56 : ------------------Model.dll Information-------------------
14:04:56 : Filename : LGP920.dll
14:04:56 : Version : 1.0.0.3
14:04:56 : File size : 262144
14:04:56 : File date : 2011/06/27-21:28:08
14:04:56 : PC Created date: 2012/02/22-14:04:55
14:04:56 : ----------------------------------------------------------
14:04:56 : Connection check start........
14:05:11 : Check phone IMEI/ESN/MEID again.
14:05:11 : *****2nd ESN / IMEI / MEID check Start*****
14:05:15 : 2nd ESN/IMEI/MEID check : 357116040810957
14:05:15 : IMEI check OK.
14:05:15 : Connection check and IMEI check OK....
14:05:15 : *****Check LGCM Programs Start*****
14:05:15 : LGCM Programs Not Found - OK and ready to upgrade
14:05:15 : *****WorkModelDLL Start*****
14:05:16 : strPhoneBinaryPath(C:\ProgramData\LGMOBILEAX\Phone \V21A.wdb)
14:05:16 : strModuleDir(C:\ProgramData\LGMOBILEAX\Phone\)
14:05:16 : strModelDLLPath(C:\ProgramData\LGMOBILEAX\Phone\LG P920.dll)
14:05:16 : _DetachDLL Call
14:05:16 : _DetachDLL Call End
14:05:16 : Call fn_StartUpgrade
14:05:16 : ********* 2Chip Model.dll input Parameter*************
14:05:16 : MODEL_EVENT : 32769
14:05:16 : PhoneBinaryPath : C:\ProgramData\LGMOBILEAX\Phone\V21A.wdb
14:05:16 : ModuleDir : C:\ProgramData\LGMOBILEAX\Phone\
14:05:16 : BootWaitTime : 49500
14:05:16 : UsbHighSpeed : FALSE
14:05:16 : PhoneMode : 1
14:05:16 : NewPhoneBinVersion : V21A_00
14:05:16 : ClearSI : FALSE
14:05:16 : AuthMark : 0
14:05:16 : ********* 2Chip Model.dll input Parameter End*************
14:05:16 : wParam : 2004, lParam = 5
14:05:16 : Step : TYPE_WPARAM_IFX_DN_POS
14:05:32 : wParam : 2004, lParam = 6
14:06:02 : wParam : 2004, lParam = 7
14:06:02 : wParam : 2007, lParam = 0
14:06:02 : Step : TYPE_WPARAM_READ_FILES
14:06:02 : wParam : 2004, lParam = 8
14:06:02 : Step : TYPE_WPARAM_IFX_DN_POS
14:06:08 : wParam : 2004, lParam = 9
14:06:08 : wParam : 2004, lParam = 10
14:06:09 : wParam : 2003, lParam = 97
14:06:09 : Step : TYPE_WPARAM_DOWNLOAD_FILENAME
14:06:09 : wParam : 2004, lParam = 15
14:06:09 : Step : TYPE_WPARAM_IFX_DN_POS
14:06:15 : wParam : 2004, lParam = 16
14:07:45 : wParam : 2010, lParam = 3013
14:07:45 : CleanModelDll() : Free Model.dll
14:07:45 : _DetachDLL Call
14:07:45 : _DetachDLL Call End
14:07:45 : Page_Error ºÎºÐÀÔ´Ï´Ù
14:07:45 : ¿©±â´Â Retry ºÎºÐÀÔ´Ï´Ù
14:07:45 : wParam : 2010, lParam = 3016
Ho letto che per risolvere quel problema bisogna mettere il telefono in download mode. Giusto?
Per rootare il tuo LG con Gingerbread devi seguire questi semplici passaggi:
1) Download di SuperOneClick 2.3.3
2) Attivare la modalità Debug USB. Per farlo vai in Impostazioni > Applicazioni > Sviluppo e metti la spunta su Debug USB.
3) Installare i driver (penso che lo hai già fatto)
4) Aprire SuperOne Click 2.3.3 e in alto a destra selezionare l'Exploit Zerg Rush.
5) Cliccare su root, aspettare che termini la procedura, riavviare l'LG.
Fammi sapere
Avevo gia provato ma il programma si blocca e va in crash al settimo step e in giro su internet ho letto che la 20A non si puo rootare per ora. Ecco perche voglio flasharlo.
Ciao.
Sono Roberto e sono le identiche condizioni di Buccolieri96. Ho fatto le identiche cose che ha fatto lui. Avremo qualche speranza anche noi.
Vabè riprovo e ti faccio sapere.
